bells_electronics
errors in "ex_usb_serial" ?? |
Posted: Wed Jan 27, 2010 4:20 am |
While compiling the example "ex_usb_serial.c" of CCS I got the following errors
Quote: |
***Error 119”ex_usb_serial.c”Line42(8,39):USB CDC Library requires PIC18
***Error 24”D:\PICC\devices\18F4550.h” Line2(9,19):Unknown device type --Try PCH
Posted: Wed Jan 27, 2010 5:32 am |
USB serial, only works for the PCH 'PIC18' compiler. It sounds as if you are trying to use this with perhaps the PCM (PIC16) compiler.
It only supports (directly), the PIC18F452 (using an external peripheral chip), or the 18F4550, using it's internal USB peripheral. It is fairly easy to modify for the other USB enabled PICs (2550 for example), but the amount of storage involved for USB, makes it almost impossible to use for smaller PIC16 chips.
You need the PCH compiler, to use this example.
