I2C works with internal osc?
kukac24
PostPosted: Mon Jan 25, 2010 2:33 pm     Reply with quote
Could somebody tell me, that the HW I2C works with internal oscillator?
I try it with 18f4520 and 18f2520 and a DS1307. Pull ups are on the each lines, everything is ok by the HW side.
Thank you in advance!
PostPosted: Mon Jan 25, 2010 3:02 pm     Reply with quote
It should work. Just try it.
PostPosted: Mon Jan 25, 2010 3:29 pm     Reply with quote
I2C is full asynchronous and not relying any kind of timing accuracy. Why it shouldn't work?
bkamen
PostPosted: Tue Jan 26, 2010 1:23 am     Reply with quote
Async??
What's SCL for then?
:D
PostPosted: Tue Jan 26, 2010 3:00 am     Reply with quote
Yes, he just got the 'a' in by mistake. Smile
I2C, is technically a 'data/strobe synchronous' transfer. It is timed by the SCL line, and couldn't at heart 'give a hoot' about the stability of the clock (within some limits set by individual devices).
It'll run quite happily off chips using basic RC oscillators far worse than the internal RC oscllator.
