2 ADCs in 16F876A Problem
bells_electronics
PostPosted: Sun Jan 24, 2010 8:00 am     Reply with quote
#include <16F876A.h>
#device adc=8
#FUSES NOWDT                    //Watch Dog Timer
#FUSES HS                       //High speed Osc (>4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOLVP                    //No low voltage prgming,
#use delay(clock=4MHz , crystal)
unsigned char adc(void);
unsigned char adc_1;
unsigned char adc_2;
 delay_ms(50);                                   //stabilization time for PIC
 set_tris_a (0b00000111);
 set_tris_b (0x00);
 set_tris_C (0b00000000);
 adc_1 = 0;
 adc_2 = 0;
 setup_comparator(NC_NC_NC_NC);   // not use comparator module
 setup_adc_ports(AN0_AN1_AN3);
    set_adc_channel(0);
    adc_1 = adc();
    set_adc_channel(1);
    adc_2 = adc();
unsigned char adc()
  read_adc(ADC_START_ONLY);
  while(!adc_done());
  return read_adc(ADC_READ_ONLY);
the problem is that ADC1 value is dependent on ADC2 value,
ADC2 working fine independent of ADC1
whatz the heck with ADC1
1)
PIN_A0 = 5v
PIN_A1 = 0v
then i get
adc_1 = 180
adc_2 = 000
2)
PIN_A0 = 5v
PIN_A1 = 2.723v
then i get
adc_1 = 255
adc_2 = 138
3)
PIN_A0 = 1.187v
PIN_A1 = 0v
then i get
adc_1 = 060
adc_2 = 000
4)
PIN_A0 = 5v
PIN_A1 = 5v
then i get
adc_1 = 255
adc_2 = 255
SherpaDoug
PostPosted: Sun Jan 24, 2010 9:34 am     Reply with quote
The A/D multiplexer needs some time to settle after switching channels. I don't have time this morning to figure out how much, but if you wait 100us after switching channels before you start conversion your problem should go away. Study the PIC datasheet or search posts here to find out just how long you must wait.
I usually take a reading, switch channels, do math on the old reading, take the next reading, switch channels, do math, etc.. Doing the math takes longer than the mux settling time.
bells_electronics
PostPosted: Sun Jan 24, 2010 11:23 am     Reply with quote
i put the delay still not working, but it works fine on ISIS
#device adc=8
 set_tris_b (0x00);
 adc_1 = 0;
 adc_2 = 0;
    set_adc_channel(0);
    adc_1 = adc();
    set_adc_channel(1);
    adc_2 = adc();
unsigned char adc()
  while(!adc_done());
PostPosted: Sun Jan 24, 2010 11:47 am     Reply with quote
You don't need to set the TRIS. The compiler does it automatically.
You don't need to do the A/D in steps. Just use read_adc() to do it.
See the example in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
The simulator doesn't model all aspects of hardware A/D operation.
PostPosted: Sun Jan 24, 2010 12:04 pm     Reply with quote
As Sherpa Doug says you must have a delay between the channel set and
the read. It would help a lot if you would read the manual.
The following from page 48 of the current manual:
set_adc_channel(0);  //the next read_adc call will read channel 0
delay_us(10);           //a small delay is required after setting the channel and before read
value=read_adc();   //starts the conversion, reads the result and stores it in value
