Timer1 external clock problem
Goto page 1, 2  Next
PostPosted: Mon Jan 11, 2010 2:26 pm     Reply with quote
I couldn't use timer1 external clock. I want to use 32.768Khz crystal for my counter. I have read a sample code for this operation:
#include <16F877.h>
#FUSES XT                       //High speed Osc (> 4mhz)
int a;
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT); //32768Hz external Timer1 oscillator
  set_timer1(0);
  a=get_timer1();
  printf("%d",a);
PostPosted: Mon Jan 11, 2010 2:52 pm     Reply with quote
int a;
a=get_timer1();
printf("%d",a);
Timer1 is 16 bits wide. You should declare 'a' as 'int16'.
To display a 16-bit unsigned value, you should use "%lu" in the
printf statement. Also, you should add "\n\r", so it goes to a newline
after displaying the timer value.
Example program:
http://www.ccsinfo.com/forum/viewtopic.php?t=29957&start=4
If that doesn't help, then post a description of the crystal circuit
that is connected to the Timer1 oscillator pins. These are different
pins than the normal main oscillator pins.
Also post your compiler version.
theasus
PostPosted: Tue Jan 12, 2010 8:57 am     Reply with quote
I have changed my code but i couldn't succeed and my schematic is;
My code is;
#include <16F877.h>
unsigned int16 a;
set_timer1(0);
a=get_timer1();
printf("%lu",a);
delay_ms(2000);
I think the problem can be related with my simulation program,Proteus.Or is there any different reason?
mkuang
PostPosted: Tue Jan 12, 2010 9:09 am     Reply with quote
Instead of this:
Try this:
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1| 0x8);
This manually enables bit 7 (T1OSCEN) of the T1CON register instead of using the T1_CLK_OUT (which I am not sure whether it actually enables the oscillator).
PostPosted: Tue Jan 12, 2010 12:01 pm     Reply with quote
I have changed my code but I couldn't succeed.
Post your compiler version.
theasus
PostPosted: Tue Jan 12, 2010 1:05 pm     Reply with quote
My compiler verison is 4.068.
PostPosted: Tue Jan 12, 2010 1:15 pm     Reply with quote
I installed vs. 4.068 and compiled the program shown in your post
with the schematic. I programmed it into a 16F877 on my PicDem2-Plus
board. It works. I did add a "\n\r" in the printf statement, so it would
go to a new line after each value is displayed in the TeraTerm window
on my PC.
Here's the output. It's correct. You have a delay of 500 ms after you
clear the timer. During that time, it will count up to about 16384.
Then you read the timer every 2 seconds. During that time, it will do
65536 counts, which puts it right back at about 16384 again. That's
what we see below, so it's working.
16384
16384
16385
16384
16384
16385
16384
16385
16385
theasus
PostPosted: Tue Jan 12, 2010 1:51 pm     Reply with quote
Ok thanks for your help I will try this code in real hardware.
Thanks for considering...
PostPosted: Tue Jan 12, 2010 5:03 pm     Reply with quote
Just a thought.... Is this your first program in Proteus?
What I remember from playing with Proteus is that it doesn't look at the connected crystal, this part of the PIC processor is not simulated. What you have to do is right-click on the PIC processor and enter the desired clock frequency in one of the property fields.
theasus
PostPosted: Wed Jan 13, 2010 12:45 am     Reply with quote
By clicking right on the PIC processor you can change only the processor clock frequency. You can't change the external clock which is connected to RC0- RC1 oscillator frequency. I have already connected 4Mhz crystal to OSC1-OSC2 pins and this determines the processor clock frequency. The main problem in Proteus adding second external oscillator for Timer1.
PostPosted: Wed Jan 13, 2010 2:07 pm     Reply with quote
I just checked, for the main oscillator you have to configure the clock using the properties dialog (press ctrl-E when mouse is over the processor), at least in my ISIS version 6.9.
I'm no Proteus expert, so I don't know about the second oscillator support.
princez
external oscillator problem
PostPosted: Mon Aug 01, 2011 1:31 pm     Reply with quote
hay, I am having an external oscillator problem on Proteus. I am using Isis version 7, but I am unable to simulate my code on Proteus with an external oscillator. The hex file I generated was on CCS.
Here's my code,
#include<18f4550.h>
#fuses HS,NOWDT
#use delay (oscillator=20M)
#use rs232 (baud=9600,parity=N,xmit=pin_c6,rcv=pin_c7,stream=com1,bits=8)
int i;
while(true)
   fprintf(com1,"hello");
   putc(13);
   i=getenv("CLOCK");
   fprintf(com1,"%d",i);
Can anyone please tell me if I have written a right code ?? Or there's anything missing in it. Also on actual hardware, is there any way to determine what's the baud rate of my controller or its clock speed?
PostPosted: Mon Aug 01, 2011 2:31 pm     Reply with quote
Last question first..you should be able to read the SFR associated with baud rate and figure out the 'speed'.....
First question last... Get RID of Proteus ! As you've just found out it's full of bugs, quirks and bad DRCs....in no way will it ever 'simulate' the real world !
princez
PostPosted: Wed Aug 03, 2011 9:30 am     Reply with quote
how to do this ?? will it tell the circuit baud rate ? Confused
asmboy
PostPosted: Fri Aug 05, 2011 9:53 am     Reply with quote
the best thing you can do is try with real circuits not this shaky simulator.
LOSE proteus - it is a great way to waste time
Goto page 1, 2  Next
Page 1 of 2
