demetrix80
| SD card (raw mod) |
Posted: Fri Jan 08, 2010 7:55 am |
Hi to all,
I'm an Italian student. I'm working to a project for my electronic engineering thesis. I must store every data string that I get to a sd card. I use the sd card as a storage memory (raw), therefore I think that no is necessary to use Fat16 or 32 system (is correct?).
I make an example: I included the mmcsd.c driver and I used the mmcsd_write_byte for storage a character. After, I read this character with mmcsd_read_byte and I receive the data correctly. A this point I tryed to store a character string of 10 byte using the function mmcsd_write_data(a, n, p), but when I try to receive the data with mmcsd_read_data, I receive nothing.
Please you can help me?
Best regards
Demetrio |
| Re: SD card (raw mod) |
Posted: Fri Jan 08, 2010 9:13 am |
| demetrix80 wrote: | | I must store every data string that I get to a sd card. I use the sd card as a storage memory (raw), therefore I think that no is necessary to use Fat16 or 32 system (is correct?). | Yes, this is correct, you can do without a file system.
For the problems in storing and reading of the string data I don't know without further information. A possible problem could be the third parameter, check this to be a pointer.
If you don't know how to solve the problem it is best when you post a small program demonstrating your problem. Make the program small, max. 20 lines, and post the complete program including #fuses so we can copy/paste it directly in our compiler. |
demetrix80
Posted: Fri Jan 08, 2010 12:46 pm |
Hi ckielstra, thanks for reply.
The code for test the sd write/read is below:
#include "C:\Users\Demetrio\Documents\PIC-C\sd card\sd.h"
#include <float.h>
#include <math.h>
#include <stdio.h>
#include <string.h>
#include <mmcsd.c>
int32 address=0;
int16 b;
char *dato="Test";
char *rec;
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
mmcsd_init();
// TODO: USER CODE!!
while(true)
b=strlen(dato);
mmcsd_write_data(address, b, dato);
mmcsd_read_data(address, b, &car);
printf("%s\n\r", *car);
The fuses is:
#include <18F4455.h>
#device adc=8
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES ICPRT //ICPRT enabled
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
I've resolved using a "for" cicle, reading every single character, with mmcsd_read_byte function, and copying into a string, but this not the best solution . Ideally use the mmcsd_read_data.
Follow my solution:
for (i=0; i<=b; i++)
a=address+i;
mmcsd_read_byte(a, &rec);
car[i]=rec;
car[i+1]='\0';
printf("%s\n\r", car);
Best regards
Demetrio |
