namcuibap
| Can anyone help me on motor control using dsPIC! |
Posted: Wed Jan 06, 2010 3:14 am |
I am studying about application of single phase matrix converter in controlling motor drive by using dsPIC30F6010A.
My control method is that Sin PWM. A input voltage with frequency we can change, this signal will pass over some circuit and finally it will occur pulses to control IGBT/Diode switches.
I attached diagrams of this method.
Can you help me in convert this idea to dsPIC30F by using CCS? I find it very hard to do because I don't know much about CCS as well as MPLAB.
I always appreciate your help.
Thank you so much!
http://www.fileden.com/files/2008/8/23/2061812/luu_do.pdf |
