PIC18F1220 "no response from ICD data in buffer"
Jerry R
PostPosted: Thu Dec 31, 2009 4:57 pm     Reply with quote
Hello all
New project, new processor here. Getting "Could not single step: No response from ICD data in buffer 04 02 FF..." after a load complete while attempting to debug.
Microcontroller: PIC18F1220 using internal oscillator at 4MHz
CCS PCWH v 3.249
ICDU-40 firmware 2.23
simple code to start:
#include "\\Jerry-e1e8dd780\patriot (f)\PROJECTS\Yale Safe Zone\C Code\SafeZone (Rev XA).h"
   setup_adc_ports(sAN0|sAN1|sAN2|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_4,255,1);
   setup_ccp1(CCP_PWM_FULL_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
   setup_oscillator(OSC_4MHZ|OSC_INTRC);
  while (True)
      output_high (K1_DRIVE);                               //K1 On
      delay_ms(250);
      output_low (K1_DRIVE);                               //K1 On
      delay_ms(250);
      output_high (K2_DRIVE);                               //K1 On
      delay_ms(250);
      output_low (K2_DRIVE);                               //K1 On
      delay_ms(250);
This ICD response is new to me. Any suggestions are most helpful and appreciated.
PostPosted: Thu Dec 31, 2009 5:14 pm     Reply with quote
Post the .h file, or at least post the #fuses and the #use delay() statements.
Jerry R
PostPosted: Thu Dec 31, 2009 5:21 pm     Reply with quote
Sorry:
Here's the *.h file:
#include <18F1220.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC                    //Internal RC Osc
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTB                   //Boot block not write protected
#define K1_DRIVE   PIN_A7
#define PROX_IN   PIN_B0
#define K2_DRIVE   PIN_B2
#define LED_DIM   PIN_B3
#define HOLD_IN   PIN_B4
Thanks!
bkamen
PostPosted: Thu Dec 31, 2009 10:01 pm     Reply with quote
Ok, that's a nightmare include path.
Have you tried putting the include in the same directory as the source for simplicity?
All those spaces and backslashes give me the willies.
Just a thought.
-Ben
Jerry R
PostPosted: Fri Jan 01, 2010 7:28 am     Reply with quote
I'll give it a try. Thanks
bkamen
PostPosted: Fri Jan 01, 2010 11:02 am     Reply with quote
BTW,
I think you can turn off IESO if you're only using one clock source.
Especially only using the internal one.
-ben
Jerry R
PostPosted: Fri Jan 01, 2010 1:00 pm     Reply with quote
All tips performed. Still getting "Could not single step: No response from ICD data in buffer 04 02 FF..." after "Loading" and "Busy" responses from ICD-U40.
Using ICD utility, both ICD and Target return "Test Passed"
Double checked wiring around PIC18F1220 and ICD to board connections.
I can find no reference to the "Could not single step ... " error message. Anyone know what this is really saying?
bkamen
PostPosted: Fri Jan 01, 2010 1:06 pm     Reply with quote
I use an ICD2&3, so I can't check.
So, there's always testing on another PIC (different family number). If other PIC's work, perhaps something is wrong with your PIC. I know that part has a funny pinout for the ICSP pins.
I'd also double check my hardware connections (in case you haven't already).
I'm assuming your doing ICSP? If so, what is the hookup schematic like? Do you have any extra stuff hanging off the criticial Vpp/MCLR and PGC/PGD pins?
-Ben
Jerry R
PostPosted: Fri Jan 01, 2010 1:40 pm     Reply with quote
Hi Ben:
You'd think we'd have other things to do on New Year's day except play with widgets Very Happy
Thanks for taking the time to help me debug this thing. All your suggestions are good. Thanks!
OKay! the plot thickens. I flashed code into the target using the ICD utility and the target plays as the code directs it to. Relays, as directed by the simple code, merrily chatter away. So I think the hardware is good. I'm betting that the ICD error has something to do with it thinking that the code is bad.
I've had the "pleasure" of using the CCS C and ICD-U40 to create a bunch of stuff, but, so far, I've never had a problem with debugging code once the ICD connects successfully to the target.
Keep your ideas coming if you have them. I might reinstall the CCS IDE to see if that fixes anything.
Again, thanks!
Jerry R
PostPosted: Sat Jan 02, 2010 9:17 am     Reply with quote
Solved!
Re-installed ICD software fixed the problem. Thanks all for your input!
bkamen
PostPosted: Sat Jan 02, 2010 1:03 pm     Reply with quote
You can change your original message subject --- I always edit to read "[SOLVED]"
so they are easy to spot for others...
Just a thought for you...
Glad things are back to working!
-Ben
