ROBOTICAR
problem with A/D |
Posted: Mon Sep 24, 2007 3:54 am |
I write a micro voltmeter with 16f877 and simulate it in the PROTEUS.
but when I make this hardware, LCD represent 0/41 or 0/65 or 0/34 or 0/48 Volt instead 0/5 volt . I use a 1uF capacitor on A/D pin . but LCD don't represent correct number of volt . can you help me? |
Posted: Mon Sep 24, 2007 12:15 pm |
Here's a demo program that shows how to display the A/D voltage
on the LCD, from 0 volts to 5.00 volts.
#include <16F877.H>
#device adc=10
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include "flex_lcd.c"
int16 adc_value;
float volts;
lcd_init();
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_value = read_adc();
volts = (float)(adc_value * 5)/1023.0;
printf(lcd_putc, "\f%3.2f", volts);
mutthunaveen
Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
Posted: Thu Aug 27, 2009 9:41 am |
Code: | printf(lcd_putc, "\f%3.2f", volts); |
hi this is really fine but i dont understand one thing in this what is 3.2 in this line |
Posted: Thu Aug 27, 2009 9:52 am |
Minimum of 3 characters output, with 2 after the decimal place.
Hence the .00, in the final value PCM programmer gives.
SET
Posted: Thu Aug 27, 2009 9:56 am |
See:
http://en.wikipedia.org/wiki/Printf
So '3.2' means *at least* 3 digits before the decimal point (adding spaces if reqd) and *at least* 2 digits after the decimal point. |
mutthunaveen
i got it |
Posted: Thu Aug 27, 2009 10:11 pm |
you are right ........ thanks bro |
djole_nisam_ja
Posted: Wed Dec 23, 2009 7:33 am |
I have a problem calibrating with this code.
At first I used it in original for couple of measurements.
After some time it started to give me results on LCD shifted for 1 space to the right.
Example: instead of showing 1.43 it showed 0.14
so I had to change this line:
Code: | volts = (float)(adc_value * 5)/1023.0; |
into this line:
Code: | volts = (float)(adc_value * 50)/1023.0; |
What happened and how to solve this? |
meereck
Posted: Wed Dec 23, 2009 7:57 am |
Just one follow-up question
I am always confused whether it should be /1023 or /1024.
Which one is correct?
cheers |
Posted: Wed Dec 23, 2009 8:50 am |
SET wrote: | See:
Replying here to this old post first, but it is important to get this right....
No.
Not in C.
The first number is the 'minimum field width', _not_ the digits in front of the decimal place. In Fortran, or some of the standard 'maths' languages (CoBol for example), 3.2, would imply 3digits in front of the DP, but not in C.....
The 'answer' to /1023, or 1024, is actually quite complex!....
It depends on the ADC involved. Normally, with a linear ADC, going from 0, to 1023 output values, Just like the stair, where there would be 1024 levels, but only 1023 'risers', you would need to divide by 1023.
However the PIC ADC, is slightly 'odd' in this regard, which is why it is common to get the division wrong. The first oddity, is that unlike most ADC's, the change from a reading of '0', to '1', occurs at 1/nobits of the full scale, not at a half bit, which would be normal. Similarly, at the full voltage end, the transition occurs one bit 'below' the full voltage, not at half a bit below. Effectively it behaves as if it has one extra 'count', with it's steps spaced as if it had 1025 levels, instead of 1024, but with the two end levels giving the same reading, and shifted half a bit 'up'.
So the 'best fit' transfer function for the PIC, is:
Vout=((counts+0.4999999)/1024)*Vref
This gives the best fit to the actual PIC ADC transfer function, but you need to besure to only digits, or you will not see '0', and overshoot at the top by half a bit....
djole_nisam_ja
Posted: Wed Dec 23, 2009 9:26 am |
Ttelmah wrote: | SET wrote: | See:
No.
Not in C.
Thanks for your quick reply. I tried it on my 18F4520.
Vref=5V
but I still need to multiply with 50 instead with 5.
Code: | Vout=((counts+0.4999999)/1024)*50 |
instead of
Code: | Vout=((counts+0.4999999)/1024)*5 |
and transfer function is not quite accurate, because it is still inaccurate for greater voltage while for lower voltage it is quite accurate
Example:
for Vout=0.63 real voltage is 0.63 but
for Vout=2.58 real voltage is 2.61
for Vout=3.34 real voltage is 3.48 |
Posted: Wed Dec 23, 2009 10:48 am |
I'd suggest that the problem is elsewhere. The accuracy of your Vref, or the source impedance of the circuit itself, or possibly noise on the circuit (because the PIC ADC, is capacitive, it tends to integrate noise on the incoming voltage, while voltmeters may tend to record 'peak' values).
Using a high accuracy Vref, and oversampling 16*, I have got good correlation between the PIC ADC, out to five digits, with a freshly calibrated Fluke DVM.....
However using the supply for Vref, often gives problems, since the PIC also tends to integrate noise on the supply line. This tends to give a lower than expected reading, and might be what you are seeing.
mkuang
Posted: Wed Dec 23, 2009 11:25 am |
SET wrote: | See:
No, it means at least 3 digits before the decimal point, adding leading zeros if required (not spaces) and exactly 2 digits after the decimal point.
In addition, the Thevenin equivalent impedance as seen by the PIC A/D pin should be less than 10k (or is it 5K, you have to check the datasheet) or you may get the accuracy you are looking for. |
djole_nisam_ja
Posted: Wed Dec 23, 2009 12:15 pm |
Ttelmah wrote: | I'd suggest that the problem is elsewhere. The accuracy of your Vref, or the source impedance of the circuit itself, or possibly noise on the circuit (because the PIC ADC, is capacitive, it tends to integrate noise on the incoming voltage, while voltmeters may tend to record 'peak' values).
Could you please explain me what did you mean by "it tends to integrate noise on the incoming voltage" and by "oversampling 16*".
I am using Vref from my UNI-DS3 Development Board which I bought from Mikroelektronika, you think that could be a reason for this or something else? |
djole_nisam_ja
Posted: Wed Dec 23, 2009 12:24 pm |
[quote="mkuang"] SET wrote: | See:
Excuse me mkuang, could you give me a help a bit.
Do you say that if I measure voltage on ADC pin (with voltmeter), I am actually not measuring the whole voltage (which measures the PIC) because of the ADC pin´s resistance? |
Posted: Wed Dec 23, 2009 12:52 pm |
Quote: | Do you say that if I measure voltage on ADC pin (with voltmeter), I am actually not measuring the whole voltage (which measures the PIC) because of the ADC pin´s resistance? | Right. You would need an oscilloscope to watch the input voltage at the sampling moment, which
is actually dropping due to the source resistance and the ADC's input impedance. The voltmeter is too
slow to follow it.
Your previous statement about a voltage factor 5 versus 50 is still confusing. You may want to dump the
actual ADC code and check the calculation by pencil and paper method. From the shown code, I can't follow
a factor of 50. |
