		| View previous topic :: View next topic   |
			snowbell Guest
				| RS232 interrupts |
				 Posted: Mon Dec 14, 2009 9:27 am     |
I've tried the example EX_SISR.c but it didn't seem to work properly for me. It doesn't print the characters which I entered through Hyperterminal. It only prints "Running..." and "Buffered Data =>". I tried printing an 'a' as shown in the code below, and it managed to print it only the first time I tried to do the interrupt. Anyone can help me with this? Thanks.
#if defined(__PCM__)
#include <18F2620.h>
#use delay(clock=12000000)
#elif defined(__PCH__)
#elif defined(__PCD__)
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, UART1A)
#endif
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   next_in=(next_in+1) % BUFFER_SIZE;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   next_out=(next_out+1) % BUFFER_SIZE;
   return(c);
void main() {
   enable_interrupts(int_rda);
   #if defined(__PCD__)
   enable_interrupts(intr_global);
   #else
   enable_interrupts(global);
   #endif
   printf("\r\n\Running...\r\n");
               // The program will delay for 10 seconds and then display
               // any data that came in during the 10 second delay
   do {
      delay_ms(10000);
      printf("\r\nBuffered data => ");
      while(bkbhit)
        putc( bgetc() );
        putc('a');
   } while (TRUE);
			snowbell Guest
				 Posted: Mon Dec 14, 2009 10:12 am     |
				| By the way, i'm using compiler version 4.057. Thanks. |
			snowbell Guest
				 Posted: Tue Dec 15, 2009 12:25 am     |
				I've also tried this very simple code of receiving a char and then displaying it on HyperTerminal. It still doesn't display, the char that I entered in HyperTerminal. It can print "Start:" and only show 'a' the first time, after that, it seems to hang. Can anyone help please. Thanks.
#include <18F2620.H>
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
char c;
printf("Start: ");
        c = getc();
        putc(c);
   putc('a');
			bkamen
  Joined: 07 Jan 2004 Posts: 1617 Location: Central Illinois, USA
				 Posted: Wed Dec 16, 2009 1:17 am     |
				it's always a good idea to TEST to see if there is a char in the RX buffer before doing a getc().
In CCS-C that's most easily accomplished with kbhit();
Also, what kind of data are you receiving, ASCII or binary?
 -Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do.  :D |
			LegolasMicrochip
				 Posted: Tue Dec 22, 2009 6:58 am     |
				It actually does not hang, in fact its waiting for the character. Until or unless it does not receive a new character it would keep waiting on the getc().
So if you would type a character through your hyperterminal then it would display 'a' again.
Also verify that your circuit is correct. |
				| to make it clearer and faster try this hack |
				 Posted: Tue Dec 22, 2009 4:43 pm     |
// useless ->   delay_ms(10000);
      printf("\r\nBuffered data =>\r ");
do {
         while(bkbhit)
      {         putc( bgetc() );         putc('a');    }
   } while (TRUE);
U only see the setup print out -  once and the delay does NOTHING useful anyway IF the ISR is actually working - each line with CR U send will be on a line of its own - minus all the 'a's |
