Wireless bootloader
Robotan
Wireless bootloader
PostPosted: Tue Dec 15, 2009 11:32 am     Reply with quote
I am currently working on a project that could benefit from a bootloader. I want to make it more convenient by allowing the updates to be done over a bluetooth connection. I have a bluetooth module connected and working at a baud of 115200. Unfortunately the hardware serial port is dedicated to other hardware, so the bluetooth module is connected to pins that use software serial routines.
Really I'm just looking for suggestions from those with more experience in this area. Do you think this is doable? Which bootloader should I use? Since I have multiple serial devices connected, I use streams, but how would this come into play with the bootloader? Can I specify a particular stream to use when loading the hex file?
Your input is appreciated,
Rob
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Dec 15, 2009 4:38 pm     Reply with quote
Do you currently use bluetooth only to transmit or also to receive? My problem with receiving serial data through software UARTs always was that they consume a disproportionate amount of CPU time, especially when baud rates are high.
Read the label, before opening a can of worms.
Robotan
PostPosted: Tue Dec 15, 2009 8:17 pm     Reply with quote
I use bluetooth for both transmit and receive, but this would only be intensive during loading a new program. While the program runs, the bluetooth isn't used much, only to set a few parameters if needed. So I'm not concerned about a software UART hogging the CPU. The question is: would a software UART be reliable enough to use with a bootloader? If so, where should I start?
asmallri
PostPosted: Fri Dec 18, 2009 3:25 am     Reply with quote
It depends on how you envisage the bootloader being used. My bootloaders and the user application are ships in the night. The PIC is running either the bootloader or the user application. In my system to pass control to the bootloader the PIC must be reset. Once the bootloader is in control it has 100% access to all resources on the PIC. Putting this into your context, if your bootloader used this approach then there would be no problem uing a software based UART. However, if your bootloader shares code with the application, such a startup code, then all bets are off.
Regards, Andrew
