Langton
| PCD: Fuse Problem |
Posted: Sun Nov 29, 2009 6:11 pm |
Compiler: 4.085
OS: Vista
device: 33FJ64GP206
I've had issues trying to get the Real Ice to work with this and was instructed by a Microchip Tech support guy to switch the comm channels over however whenever I use either ICS0,ICS1,ICS2 or ICS3 I get this...
*** Error 111 "IngressEBC.c" Line 3(7,68): Unknown keyword in #FUSES "ICS1"
1 Errors, 0 Warnings.
Any ideas??? |
Posted: Mon Nov 30, 2009 12:44 am |
As a generally suggestion, to know the CCS C recognized fuses, read the CCS documents. The "vaild fuses" in the
CCS IDE tells, they are also listed in the device header.
Unfortunately, the PCD fuses keywords have been changed from V4.084 to V4.085. ICSPx is the new syntax. This has been
apparently done, because the ICSx mapping was wrong (not according to Microchip datasheet usage) before. If I remember
right, ICSPx is congruent with the datasheet now. |
Posted: Mon Nov 30, 2009 1:32 pm |
You the man
I changed it to ICSP2 and it worked a treat, previously I was just going buy the header file
Thanks heaps, you've made my day |
