Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
driver for CMA3000 VTI technologies 3axis accelerometer I2C
Post new topic   Reply to topic    CCS Forum Index -> Code Library
ivan
PostPosted: Sun Nov 15, 2009 10:53 am     Reply with quote
Hi to all
I write this driver for CMA3000 VTI technologies 3axis accelerometer in I2C mode this is only device I found work down to 1.8V. I hope can be useful for someone.
#ifndef pin_SDA
#define pin_SDA  PIN_e0
#define pin_SCL  PIN_e1
#use i2c(master,sda=pin_SDA,scl=pin_SCL)
//register
#define WHO_AM_I   0x00   //Identification register  R  Output
#define REVID      0x01   //ASIC revision ID, fixed in metal  R  Output
#define CTRL       0x02   //Configuration (por, operation modes) RW  Conf
#define STATUS     0x03   //Status (por, EEPROM parity)  R  Output
#define RSTR       0x04   //Reset Register  RW  Conf
#define INT_STATUS 0x05   //Interrupt status register  R  Output
#define DOUTX      0x06   //X channel output data register  R  Output
#define DOUTY      0x07   //Y channel output data register  R  Output
#define DOUTZ      0x08   //Z channel output data register  R  Output
#define MDTHR      0x09   //Motion detection threshold value register RW  Conf
#define MDFFTMR    0x0A   //Free fall and motion detection time register RW  Conf
#define FFTHR      0x0B   //Free fall threshold value register  RW  Conf
#define I2C_ADDR   0x0C   //I2C device address  R  Conf
//------------------------  0Dh-19h    Reserved
int1 cma3k_ready()
   int1 ack;
   i2c_start();            // If the write command is acknowledged,
   ack = i2c_write(0x38);  // then the device is ready.
   i2c_stop();
   return !ack;
void write_cma3k(int8 adr,int8 data)
   while(!cma3k_ready());
   i2c_start();
   i2c_write(0x38);
   i2c_write(adr);
   i2c_write(data);
   i2c_stop();
int8 read_cma3k(int8 adr)
  int8 ret;
   i2c_start();
   i2c_write(0x38);
   i2c_write(adr);
   i2c_start();
   i2c_write(0x39);
   ret=i2c_read(0);
   i2c_stop();
   return ret;
void init_cma3k()
   output_float(pin_scl);
   output_float(pin_sda);
   write_cma3k(RSTR,0X02);
   write_cma3k(RSTR,0X0A);
   write_cma3k(RSTR,0X04);      //RESET ASIC
   write_cma3k(CTRL,0b10000011);// INIT CONF
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
