yo4hsp
| mul 16x16 |
Posted: Sat Nov 07, 2009 5:55 am |
For my FIR filter, I need a multiplier. I use pic18f2455 and I found on his datasheet (pp 98). This is asm code for hardware multiplier.
#asm
MOVF ARG1L, W
MULWF ARG2L ; ARG1L * ARG2L ->
; PRODH:PRODL
MOVFF PRODH, RES1 ;
MOVFF PRODL, RES0 ;
MOVF ARG1H, W
MULWF ARG2H ; ARG1H * ARG2H ->
; PRODH:PRODL
MOVFF PRODH, RES3 ;
MOVFF PRODL, RES2 ;
MOVF ARG1L,W
MULWF ARG2H ; ARG1L * ARG2H ->
; PRODH:PRODL
MOVF PRODL, W ;
ADDWF RES1, F ; Add cross
MOVF PRODH, W ; products
ADDWFC RES2, F ;
CLRF WREG ;
ADDWFC RES3, F ;
MOVF ARG1H, W ;
MULWF ARG2L ; ARG1H * ARG2L ->
; PRODH:PRODL
MOVF PRODL, W ;
ADDWFC RES2, F ;
CLRF WREG ;
ADDWFC RES3, F ;
BTFSS ARG2H, 7 ; ARG2H:ARG2L neg?
BRA SIGN_ARG1 ; no, check ARG1
MOVF ARG1L, W ;
SUBWF RES2 ;
MOVF ARG1H, W ;
SUBWFB RES3
SIGN_ARG1
BTFSS ARG1H, 7 ; ARG1H:ARG1L neg?
BRA CONT_CODE ; no, done
MOVF ARG2L, W ;
SUBWF RES2 ;
MOVF ARG2H, W ;
SUBWFB RES3
#endasm
This code is not running in my CCS compiler, with errors:
"This must be a Microchip mnemonic such as MOVLW or BTFSC". I have only the BTFSS, and this mnemonic is defined on my ccs compiler. What is the problem?
Then, I tried this asm code on mplab, and it works.
Thanks |
yo4hsp
Posted: Sat Nov 07, 2009 5:56 am |
I need a 16x 16 multiplier with sign. For up side code, the formula is:
RES3:RES0 = ARG1H:ARG1L • ARG2H:ARG2L
= (ARG1H • ARG2H • 216) +
(ARG1H • ARG2L • 28) +
(ARG1L • ARG2H • 28) +
(ARG1L • ARG2L) +
(-1 • ARG2H<7> • ARG1H:ARG1L • 216) +
(-1 • ARG1H<7> • ARG2H:ARG2L • 216)
Thanks |
FvM
Posted: Sat Nov 07, 2009 7:08 am |
Generally, you can expect your C compiler to know how to imlement signed int16 mupltiply.
What's the purpose of a DIY assembler implementation? |
| mul 16x16 with sign |
Posted: Mon Nov 09, 2009 2:14 am |
I need to multiply two large numbers with sign (on 16 bits), and the
results will be on 32 bits. I try the hardware multiply (pic18f2455
datasheet) and I receive lots of errors from unrecognized mnemonics.
I used pic18f2455. |
bungee-
Posted: Mon Nov 09, 2009 3:17 am |
Like:
signed int16 a,b;
signed int32 c;
c= a*b;
Posted: Mon Nov 09, 2009 10:19 am |
var = _mul(x,y);
This is a built in function, that multiplies two 8 bit values, producing a 16bit result, or two 16bit values, producing a 32 bit result - exactly what you want...
A lot more efficient than using 32bit internal arithmetic.
yo4hsp
| multiply 16 x 16 with sign |
Posted: Mon Nov 09, 2009 12:55 pm |
ok, but "var = _mul(x,y);" is for unsigned numbers. in my filter i have a lots of coefficients and samples signed. whas i have to use??? so, i need "mul" or anything like multiplier for signed numbers with 16 bits, and results on 32 bits...
thanks, |
Posted: Mon Nov 09, 2009 1:43 pm |
If you look at your assembler example, all it does is test the top bits to verify the possible results that give a signed result.
Posted: Mon Nov 09, 2009 2:34 pm |
Thanks, I see the testing for sign:
(-1 • ARG2H<7> • ARG1H:ARG1L • 2^16) +
(-1 • ARG1H<7> • ARG2H:ARG2L • 2^16)
I hope is another function for multiply with signed numbers like "_mul" for unsigned. |
Posted: Mon Nov 09, 2009 3:41 pm |
I think you missed the point. Ttelmah gave you a hint to solve your problem.
Let me establish a bit more: It is basic mathematics to create signed multiply when you have a routine for unsigned multiply. Only the couple of if-statements from your assembly program... |
Posted: Tue Nov 10, 2009 3:10 am |
and, as a further hint, the CCS #bit directive, gives an 'assembly efficient' way of testing/clearing individual bits in a variable...
yo4hsp
| thanks |
Posted: Sun Nov 15, 2009 4:42 am |
thanks..
here my code, butt is still with errors. i think my mcu is slow for my application.
signed int32 inmultit;
signed int32 inmultire (signed int16 ARG1H, int16 ARG1L, signed int16 ARG2H, int16 ARG2L)
{ int32 PRODH = 0;
int32 PRODL = 0;
int32 PRODN = 0;
int32 PRODM = 0;
PRODH = _mul( (int16)ARG1H, (int16)ARG2H); //primii 2 octeti (0 si 1) va fi pe 16 biti
PRODM = _mul( (int16)ARG1H, (int16)ARG2L); //cei 2 octeti de mijloc (1 si 2)
PRODN = _mul( (int16)ARG1L, (int16)ARG2H); //cei 2 octeti de mijloc (1 si 2)
PRODL = _mul( (int16)ARG1L, (int16)ARG2L); //ultimii 2 octeti (2 si 3) va fi pe 16 biti
inmultit = _mul( (int16)PRODH, (int16)0x10000) + _mul( (int16)PRODM, (int16)0x100) + _mul( (int16)PRODN, (int16)0x100 ) + (int16)PRODL
- _mul( ( _mul (!bit_test(ARG1H, 3), (int16)ARG2H) ), (int16)0x10000)
- _mul( ( _mul (!bit_test(ARG1H, 3), (int16)ARG2L) ), (int16)0x100 )
- _mul( ( _mul (!bit_test(ARG2H, 3), (int16)ARG1H) ), (int16)0x10000)
- _mul( ( _mul (!bit_test(ARG2H, 3), (int16)ARG1L) ), (int16)0x100 );
return inmultit;
Posted: Sun Nov 15, 2009 5:42 am |
| Quote: | inmultit = _mul( (int16)PRODH, (int16)0x10000) + _mul( (int16)PRODM, (int16)0x100) + _mul( (int16)PRODN, (int16)0x100 ) + (int16)PRODL
- _mul( ( _mul (!bit_test(ARG2H, 3), (int16)ARG1H) ), )
- _mul( ( _mul (!bit_test(ARG2H, 3), (int16)ARG1L) ), (int16)0x100 ); | Here I am losing you... What are you trying to do?
Can you show the original mathematical equation?
This is a bug. After the cast you will only yield the lowest 16 bits, which is 0x0000 == 0
11 multiplications will be slow and can be made a lot faster when you know that multiplying by 0x10 is the same as shifting left by 4 bits. Multiplying by 0x100 is shifting left by 8 bits, etc. |
