Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
I need 2*16 lcd driver with custom char
facia
PostPosted: Wed Oct 28, 2009 3:46 am     Reply with quote
I need 2*16 flexible lcd driver with custom char.
Thanks...
PostPosted: Wed Oct 28, 2009 3:06 pm     Reply with quote
Here's an example of using custom LCD characters with the flex lcd driver:
#include <16F877.H>
#include "flex_lcd.c"
#define UP_ARROW   0
#define DOWN_ARROW 1
#define DEGREES    2
void lcd_load_custom_chars(void);
int8 temperature;
lcd_load_custom_chars();
temperature = 72;    // In degrees Fahrenheit
// Octal numbers 000 to 007 must be used with the "escape"
// backslash to display a custom char with printf.
// The line below displays the degrees symbol with \002.
// The "F" is for Fahrenheit. The "%3d" displays the
// temperature. The \f clears the LCD before displaying
// anything.
// Display temperature on top line of LCD.
printf(lcd_putc, "\f    %3d \002F \n", temperature);
// Display up/down arrows on right side of LCD.
lcd_gotoxy(16,1);  // Go to last position on top row
lcd_putc(UP_ARROW);
lcd_gotoxy(16,2);  // Go to last position on bottom row
lcd_putc(DOWN_ARROW);
// Functions
// This table holds the data for the LCD custom chars.
// Only 3 chars were created below.  The 5 other blank
// chars can be edited to create more custom chars.
const int8 lcd_custom_chars[] =
// Char Number 0 -- Up Arrow
0b00000100,  // .....O..
0b00001110,  // ....OOO.
0b00011111,  // ...OOOOO
0b00000000,  // ........
// Char Number 1 -- Down Arrow
// Char Number 2 -- Degrees
0b00001100,  // ....OO..
0b00010010,  // ...O..O.
// Char Number 3 -- Blank
// Char Number 4 -- Blank
// Char Number 5 -- Blank
// Char Number 6 -- Blank
// Char Number 7 -- Blank
0b00000000   // ........
int8 i;
// Set address counter pointing to CGRAM address 0.
lcd_send_byte(0, 0x40);
// Load custom lcd character data into CGRAM.
// It can only hold a maximum of 8 custom characters.
for(i = 0; i < sizeof(lcd_custom_chars); i++)
    lcd_send_byte(1, lcd_custom_chars[i]);
// Set address counter pointing back to the DDRAM.
lcd_send_byte(0, 0x80);
facia
PostPosted: Wed Oct 28, 2009 6:20 pm     Reply with quote
Thanks,
I've solved otherwise before your reply.
This code for Turkish characters
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_C6
#define LCD_DB5   PIN_C3
#define LCD_DB6   PIN_C4
#define LCD_DB7   PIN_C5
#define LCD_E     PIN_C7
#define LCD_RS    PIN_B7
#define LCD_RW    PIN_A3
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   1
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0xc,                    // Display on
 1,                      // Clear display
 6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void turkce()
int i,s,adres=64;
const byte karakter_[8][8]=
{ 0,14,16,16,17,14, 4, 0},//ç
{14, 0,15,17,15, 1,14, 0},//ğ
{ 0, 0,12, 4, 4, 4,14, 0},//i
{10, 0,14,17,17,17,14, 0},//ö
{ 0,15,16,14, 1,30, 4, 0},//ş
{10, 0,17,17,17,17,14, 0},//ü
{14,17,16,16,17,14, 4, 0},//Ç
{15,16,16,14, 1,30, 4, 0},//Ş
for(i=0;i<=7;i++)
lcd_send_byte(0,adres);
for(s=0;s<=7;s++) {
lcd_send_byte(1,karakter_[i][s]);
adres=adres+8;
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 60 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
   turkce();
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
   address = lcd_line_two;
   address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
    case '\n':
       lcd_gotoxy(1,2);
    case '\b':
       lcd_send_byte(0,0x10);
    case 'ç':
       lcd_send_byte(1,0x00);
    case 'ğ':
       lcd_send_byte(1,0x01);
    case 'ı':
       lcd_send_byte(1,0x02);
    case 'ö':
       lcd_send_byte(1,0x03);
    case 'ş':
       lcd_send_byte(1,0x04);
    case 'ü':
       lcd_send_byte(1,0x05);
    case 'Ç':
       lcd_send_byte(1,0x06);
    case 'Ş':
       lcd_send_byte(1,0x07);
    default:
       lcd_send_byte(1,c);
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif
Quirk
PostPosted: Sun Nov 08, 2009 3:19 am     Reply with quote
#include <16F877.H>
#define UP_ARROW   0
#define DEGREES    2
int8 temperature;
// anything.
I cannot get the the UP_ARROW to display with printf when \000 is used. \001 and \002 work fine. Does anybody understand why this is?
FvM
PostPosted: Sun Nov 08, 2009 3:55 am     Reply with quote
Obviously \000 can't work in a string, because it's the string terminator. Usually a printable character is used
instead and replaced with \000 in the printer driver, as shown above.
