giustraman
| lcd & pic16f648a |
Posted: Thu Oct 15, 2009 1:41 am |
I am trying to program the PIC16F48a to drive an LCD to display temperature. The program doesn't compile :(. Are the CCS internal LCD controller functions compatible with the PIC16F648a?
Particularly, I'm realizing a receiver circuit to display the measure of environment temperature.
This is the receiver code:
#include "C:\Documents and Settings\Administrator\Desktop\ricevitore\16f648.h"
#define LCD_ENABLE_PIN PIN_D0
#define LCD_RS_PIN PIN_D1
#define LCD_RW_PIN PIN_D2
#define LCD_TYPE 2
#include <lcd.c>
int1 stato_bit, stato_id, parita;
int1 vett[48];
int i, j, k1, k2, count, count_k, pos_id;
#int_CCP1
void CCP1_isr(void)
set_timer0(0);
delay_us(500);
stato_bit=input_state(pin_B3);
if(stato_bit)
vett[j]=1;
vett[j]=0;
if(j==47)
j=0;
j++;
if (get_timer0()<255)
disable_interrupts(INT_TIMER0);
#int_TIMER0
void TIMER0_isr(void)
stato_id=false;
parita=false;
void controllo_id (int1 v[48])
for(k1=0;k1<32;k1++)
count_k=0;
for(k2=k1;k2<k1+15;k2++)
if((v[k2]==1)&&(v[k2+1]==0))
count_k++;
if(count_k==8)
stato_id=true;
pos_id=k1;
stato_id=false;
void controllo_parita (int1 v[48])
for(i=0;i<48;i++)
if(vett[i]==1)
count++;
if(count%2==1)
parita=false;
parita=true;
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8); // va in overflow ogni 2ms
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
// set_pwm1_duty(0);
setup_vref(FALSE);
enable_interrupts(INT_CCP1);
setup_oscillator(OSC_4MHZ);
lcd_init();
controllo_id (vett);
if(stato_id==true)
controllo_parita(vett);
if((pos_id==0)&&(stato_id==true)&&(parita==true))
// comandi lcd
delay_us(1);
And these are the error messages:
Undefinied identifer set_tris_d
about:
set_tris_lcd(LCD_READ); / set_tris_lcd(LCD_WRITE);
Someone can help me?? Thank a lot! |
Posted: Thu Oct 15, 2009 2:49 am |
You are telling the LCD code, to use PORTD for the LCD control:
Your PIC, _does not have a PORTD_.
Yes, the LCD code will work with a 648, if it is setup to use the pins the chip has. _but_, not if you try to use pins that are not there....
