Does anyone know the correct syntax for using DATA keyword i
regan
PostPosted: Thu Jan 30, 2003 3:42 am     Reply with quote
I'm using PCH on a PIC18F452 and I need to insert some data in an ASM section. What is the correct syntax for using the DATA directive? I want to insert 0xFFFF immediately following some instructions but I can't get the compiler to accept it. The website says that v3.139 supports it.
I've tried:
data 0xFFFF
data 65535
data 0xFF,0xFF
data 255,255
The compiler returns the error "Expecting an identifier"
What else can I try?
thanks,
Regan.
___________________________
Original Post ID: 11132
Re: Does anyone know the correct syntax for using DATA keywo
PostPosted: Thu Jan 30, 2003 1:05 pm     Reply with quote
:=I'm using PCH on a PIC18F452 and I need to insert some data in an ASM section. What is the correct syntax for using the DATA directive? I want to insert 0xFFFF immediately following some instructions but I can't get the compiler to accept it. The website says that v3.139 supports it.
:=I've tried:
:= data 0xFFFF
:= data 65535
:= data 0xFF,0xFF
:= data 255,255
:=The compiler returns the error "Expecting an identifier"
Historically, CCS hasn't supported assembler directives
in #asm blocks. But they must be reading this board (or
you emailed them), because it's in vs. 3.138:
<a href="http://www.ccsinfo.com/cgi-bin/update.cgi?software=VERSIONS" TARGET="_blank">http://www.ccsinfo.com/cgi-bin/update.cgi?software=VERSIONS</a>
Original Post ID: 11138
