problem with flex_lcd.c Guest
| is not working with me?! |
Posted: Sun Oct 04, 2009 8:11 am |
Hey
I have a problem , my LCD is not working with the flex_lcd.c driver.
I use pickit2 debug express and my pic number is 16f887A
and my lcd module is Displaytech Ltd LCD MODULE 162F BC BC.
#define LCD_DB4 PIN_B0
#define LCD_DB5 PIN_B1
#define LCD_DB6 PIN_B2
#define LCD_DB7 PIN_B3
#define LCD_E PIN_B5
#define LCD_RS PIN_B4
#define LCD_RW PIN_B6
plz hlp |
Posted: Sun Oct 04, 2009 1:32 pm |
| Quote: |
The Pickit2 uses pins B6 and B7 for Programming and Debugging.
Don't use those pins for the LCD. Choose another pin for LCD_RW. |
Posted: Sun Oct 04, 2009 3:04 pm |
thanks
I have another problem.
I think my pic is burned
coz when I turn the power supply
it was 11 volts and something
and when I build the program they said
"PKWarn0003: Unexpected device ID: Please verify that a PIC16F887 is correctly installed in the application. (Expected ID = 0x2080, ID Read = 0x0)
does my pic burned?  |
Posted: Sun Oct 04, 2009 3:18 pm |
| Probably. Get a new PIC. |
Posted: Sun Oct 04, 2009 4:01 pm |
OOOOOOOOOOOH!!
nooo
I'm going crazy
this mean
I must waaaaaaaait for at least one or two weeks
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW 1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine. For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
if(address)
output_high(LCD_RS);
output_low(LCD_RS);
delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 60 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_LCD_RW
delay_ms(5);
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
address = lcd_line_two;
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
lcd_send_byte(0,0x10);
default:
lcd_send_byte(1,c);
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#include <16F887.h>
#use delay(clock = 4000000)
#include "flex_lcd.c"
lcd_init(); // Always call this first.
while(1){
output_high(PIN_B5);
output_low(PIN_B5);
printf(lcd_putc, "Hello World.");
If I connect RW with the GND
how the connections will be?
and there is any error in my main code?? |
Posted: Sun Oct 04, 2009 4:24 pm |
| Quote: | // If you only want a 6-pin interface to your LCD, then
#define USE_LCD_RW 1 |
It says what you should do. Comment out the line above.
| Quote: | while(1){
output_low(PIN_B5);
printf(lcd_putc, "\fHello World.");
If you write to the LCD in a loop, then add \f in the printf to clear the
lcd screen before writing each time, as shown above in bold. |
Posted: Tue Oct 06, 2009 3:50 am |
there is any manual for understand all this staff and language you are talking about?
I mean for example "define LCD_DB4 PIN_B0"
Thanks |
Posted: Tue Oct 06, 2009 7:39 am |
That is not a language.
means nothing...
#define (note the '#' - syntax is _everything_), is a _macro_, in the C language, saying 'when you see the following text, replace it with the next text'.
So:
means, when the text 'LCD_DB4' is seen, replace it with 'PIN_B0'.
The 'meaning' of 'PIN_B0', is specific to CCS, and is itself 'defined' in the include file for the processor.
The LCD controller itself, has eight 'data' lines called DB0 to DB7. Look at the datas sheet. When you use 4bit mode to talk to the LCD, only the top 4 of these are used, DB4 to DB7. The defines are saying what physical pin on the PIC is connected to what pin on the LCD, assigning 'names' to these, for the LCD driver to use.
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Tue Oct 06, 2009 8:44 pm |
Always buy 2 MCU's when experimenting. (or 3 if you're prone to burning stuff up)
Go to Borders and pick up any book on programming in C.
Personally, (more for laughs and reference) I have the original:
"The C Programming Language" from Kernighan and Ritchie.
ISBN 0-13-110362-8
Cheers,
DeadPostPoster Guest
| Wired Wrong |
Posted: Sun Jan 10, 2010 3:16 pm |
I know this post is dead, but, I wanted to point something out for anyone that stumbles across it.
The error: PKWarn0003: Unexpected device ID: Please verify that a PIC16F887 is correctly installed in the application. (Expected ID = 0x2080, ID Read = 0x0)
This error usually indicates that you wired the header circuit for your ICSP wrong.
It's worth a look! |
