How stored a float variable in the eeprom of pic
pilar
PostPosted: Fri Sep 25, 2009 4:33 pm     Reply with quote
Hi need to store float variable (Valor_ADC0) in the eeprom of pic, how I can do it??
Here is my code:
#include <18F452.h>
#DEVICE ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
void main() {
   int32 Buffer_ADC0;
   float Valor_ADC0;
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_DIV_32);
   set_adc_channel(0);
   delay_us(10);
while (TRUE){
    set_adc_channel(0);
   delay_us(4);
    Buffer_ADC0 = read_adc();
    delay_us(10);
    Valor_ADC0 =  (float)Buffer_ADC0 *(0.0529);
    printf("%4.2f \r\n", Valor_ADC0);
PostPosted: Fri Sep 25, 2009 4:36 pm     Reply with quote
Look in this file for routines to do this:
c:\program files\picc\drivers\internal_eeprom.c
Or look at this FAQ article:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
PostPosted: Sat Sep 26, 2009 3:04 am     Reply with quote
Also though, look at the write life limitations of the EEPROM.
The code shown, will probably kill the EEPROM, in a couple of hours, and 'worst case' (maximum operating temperature, and a bad chip example), could do it in under ten seconds....
The EEPROM, is _not_ designed to hold values that are changing fast/frequently. You need to rethink the approach, if you want to store a value being read fast. Either use RAM, and store it to the EEPROM, only when power goes off, or use an external memory without the limitations (FRAM).
PostPosted: Sat Sep 26, 2009 6:16 am     Reply with quote
Another option, if you're always sending it to a PC ( the print line..), is to have the PC store the data for you.
Jay
pilar
PostPosted: Mon Sep 28, 2009 8:49 am     Reply with quote
Hi, I tried using the examples that you refer me but I can not write or read the float data correctly in eeprom, someone could tell me what my mistake?.
The maximum value of the ADC input is 5V equivalent to 13.45.
#include <18F452.h>
#DEVICE ADC=8
int j;
float data;
void Write_Float_Eeprom(address, float data)
   int8 i;
   for(i = 0; i < 16; ++i){
     write_eeprom(address + i, *((int8 *)(&data) + i));
float Read_Float_Eeprom( address)
   int8 i;
   float data;
     *((int8 *)(&data) + i) = read_eeprom(address + i);
   return data;
void Init_EEprom(){
   for(j = 0; j < 16; ++j){
        write_eeprom(j,0xff);
void main() {
   int32 Buffer_ADC0;
   float Valor_ADC0;
   set_adc_channel(0);
   delay_us(10);
   Init_EEprom();
   set_adc_channel(0);
   delay_us(4);
   delay_us(10);
   Write_Float_Eeprom(0,Valor_ADC0);
   delay_us(200);
   Read_Float_Eeprom(0);
   printf("%4.2f \r\n", data);
while (TRUE);
FvM
PostPosted: Mon Sep 28, 2009 9:30 am     Reply with quote
Are there any indications of float occupying 16 bytes with CCS C? It doesn't, you're definitely writing out of bounds.
Also Read_Float_Eeprom() goes to nowhere in your code.
PostPosted: Mon Sep 28, 2009 9:44 am     Reply with quote
Let's explain what Fvm is saying about read_float_eeprom.
You have a global variable called 'data'. You don't write to this anywhere.
You have a local variable called 'data'. You write to this, and then to twelve more bytes in memory, 'beyond' this, potentially destroying other variables.
You then return a value in this, and don't store the return anywhere.
Not surprising if you don't see what you expect...
pilar
PostPosted: Mon Sep 28, 2009 9:48 am     Reply with quote
How do I write variables to EEPROM that are not a byte?
The following is an example of how to read and write a floating point number from/to EEPROM. The same concept may be used for structures, arrays or any other type.
n is an offset into the eeprom.
For example if the first float is at 0 the second
For floats you must increment it by 4.
one should be at 4 and the third at 8.
WRITE_FLOAT_EXT_EEPROM(long int n, float data) {
int i;
for (i = 0; i < 4; i++)
write_ext_eeprom(i + n, *((int8*)&data + i) ) ;
float READ_FLOAT_EXT_EEPROM(long int n) {
int i;
float data;
*((int8*)&data + i) = read_ext_eeprom(i + n);
return(data);
Sad I'm lost, I do not understand ???
PostPosted: Mon Sep 28, 2009 9:58 am     Reply with quote
Look, the example shows exactly what you need. Four bytes, not 16.
Then if a function _returns_ a value, you need to retrieve this in your program. So:
your_variable=READ_FLOAT_EXT_EEPROM(0);
not just calling the function...
Then, key change that needs to be made. The example, uses the functions to talk to an _external_ eepom, you need to use the functions for the internal eeprom instead.
The functions you have written, are correct, _except_ for trying to use 16bytes, instead of 4, and you are not reading the returned value.
pilar
PostPosted: Mon Sep 28, 2009 10:18 am     Reply with quote
Very Happy hi Ttelmah, thank you, now it is working....
pilar
PostPosted: Mon Sep 28, 2009 10:55 am     Reply with quote
Sorry by my insistence, but now I need to convert this float value to a string Valor. I tried to use the itoa but I can not get the correct value. Which is my mistake?
char Valor[6];
delay_us(200);
buffer = Read_Float_Eeprom(0);
itoa(buffer,10, Valor);
PostPosted: Mon Sep 28, 2009 12:25 pm     Reply with quote
The 'i', in 'itoa', is for _integer_....
You can sprintf to a string, or for a fixed precision (faster), multiply your float by (say) 100, and convert this to integer, then just add a decimal point (for sprintf, look at %w).
pilar
PostPosted: Mon Sep 28, 2009 2:27 pm     Reply with quote
thanks..
