gomond
| 10 bit Analog CSV into buffer properly to write to SDCARD |
Posted: Sat Sep 26, 2009 6:27 pm |
I am attempting to write AN0-->AN4 into a buffer and then out to an SD_CARD using f_write() (BE sd card library).
Is it possible to use fprintf() with the BE_SD library as I noticed that in the ELM version f_printf() is implimented.
This is what I have tried so far with mixed results and various methods.
//Analog functions
//char * anabuf;
unsigned long anabuf[12];
struct {
unsigned long zero;
unsigned long one;
unsigned long two;
unsigned long three;
unsigned long four;
}analoginput;
void Service_Analog_Inputs(void)
FIL fdst; // file structures
FRESULT result; // FatFs function common result code
WORD btw, bw; // File R/W count
char mesg[64];
set_adc_channel(0);
delay_us(10);
//analoginput.zero = read_adc();
itoa(read_adc(),10,anabuf[0]);
set_adc_channel(1);
delay_us(10);
//analoginput.one = read_adc();
itoa(read_adc(),10,anabuf[2]);
set_adc_channel(2);
delay_us(10);
//analoginput.two = read_adc();
itoa(read_adc(),10,anabuf[4]);
set_adc_channel(3);
delay_us(10);
//analoginput.three = read_adc();
itoa(read_adc(),10,anabuf[6]);
set_adc_channel(4);
delay_us(10);
//analoginput.four = read_adc();
itoa(read_adc(),10,anabuf[8]);
anabuf[1]=",";anabuf[3]=",";anabuf[5]=",";anabuf[7]=",";anabuf[9]=",";
anabuf[10]="\r";anabuf[11]="\n";
//sprintf(anabuf,"%uL,%uL,%uL,%uL,%uL\r\n",analoginput.zero,analoginput.one,analoginput.two,analoginput.three,analoginput.four); // used with *anabuf
printf(anabuf);
if (logging)
btw = strlen(anabuf);
result = f_write(&fdata, anabuf, btw, &bw);
f_sync(&fdata);
//printf("%s\n\r",anabuf);
lcd_gotoxy(1,2);
printf(lcd_putc,"%d\n",passes);
passes ++;
if (result)
f_get_error_mesg(result,mesg);
printf("Error writing to the data file\r\n");
printf(lcd_putc,"\nFILE SYSTEM ERROR - %s",mesg);
//return (result);
else printf("Error dataloging not enabled\r\n");
//return(FR_OK);
// printf("Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\n\r",\
// analoginput.zero,analoginput.one,analoginput.two,analoginput.three,analoginput.four);
Its probably real simple to do correctly, but if I don't ask I will never know. |
asmallri
Joined: 12 Aug 2004 Posts: 1660 Location: Perth, Australia
Posted: Sat Sep 26, 2009 8:44 pm |
The driver does not implement f_printf directly. Here is one way you would do this using sprintf to build your formatted string and f_write to output it.
| Code: | sprintf(mesg,"Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\r\n",\
f_write(&fdata, (void*)mesg, strlen(mesg), &bw); |
_________________ Regards, Andrew
gomond
Posted: Sat Sep 26, 2009 9:59 pm |
Thanks Andrew that worked, though at the start of the file there is a series of chars that pad the start for some obscure reason.
in HexEdit They are:
(0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00)
In wordpad:(blank line +11 spaces)
Blank Line
___________Analog values are: 0=1023, 1=5, 2=1, 3=5, 4=1020
//Analog functions
struct {
unsigned long zero;
unsigned long one;
unsigned long two;
unsigned long four;
}analoginput;
BYTE Service_Analog_Inputs(void)
//FIL fdst; // file structures
char mesg[64];
char anabuf[64];
set_adc_channel(0);
delay_us(10);
set_adc_channel(1);
delay_us(10);
set_adc_channel(2);
delay_us(10);
set_adc_channel(3);
delay_us(10);
set_adc_channel(4);
delay_us(10);
sprintf(anabuf,"Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\r\n",\
//printf("DEBUG: %s",anabuf);
if (logging)
result = f_write(&fdata, (void*)anabuf, strlen(anabuf), &bw);
f_sync(&fdata);
lcd_gotoxy(1,2);
printf(lcd_putc,"Samples: %d\n",passes);
passes ++;
if (result)
return (result);
return(FR_OK);
Andrew how difficult is it to timestamp the start of each line using the Software RTC?
Greg O.
asmallri
Posted: Sat Sep 26, 2009 10:50 pm |
Try this.
use sprintf to build your string.
Once this is done use memcpy to copy the newly built string to another string (call it dummy).
Then use f_write operating on dummy.
Let me know how you get on with it. _________________ Regards, Andrew
gomond
Posted: Sat Sep 26, 2009 11:27 pm |
Hi Andrew same result.
| Quote: |
blank line (0c)
_11 NULLS_1023,1,4,2,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,1,21
1023,1,4,2,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,2,21
Snippets...
char anabuf[26];
char dummy[26];
sprintf(anabuf,"%Lu,%Lu,%Lu,%Lu,%Lu\r\n",\
memcpy(dummy,anabuf,26);
result = f_write(&fdata, (void*)dummy, strlen(dummy), &bw);
f_sync(&fdata);
asmallri
Posted: Sat Sep 26, 2009 11:40 pm |
Where ever you open the file, immediately after opening the file write a hello world string to the file. _________________ Regards, Andrew
gomond
Posted: Sat Sep 26, 2009 11:54 pm |
I have copied the logging_start(), logging_stop() and OpenDataFile() functions over to the Sample FAT.c example.
and I am using logger_start(); to open the file and leaving it open until logger_stop();
I have emailed you the file as I dont know if you wanted of your IP posted.
Thanks again
Greg. |
