bertronicom
Joined: 17 Nov 2004 Posts: 26 Location: University of Cantabria -SPAIN
| ¿¿ is P¡C 18f26k20 really programmable ?? |
Posted: Fri Sep 25, 2009 3:21 am |
I can't program P¡C 18f26k20 with ICD-U40 and CCS load, whereas a colleague have programmed the same chip with WinPIC.
Any suggestion please!! |
vinniewryan
Posted: Fri Sep 25, 2009 9:27 am |
what error are you getting when trying to program it? You may also want to post your compiler version. _________________ Vinnie Ryan |
dbotkin
Joined: 08 Sep 2003 Posts: 197 Location: Omaha NE USA
Posted: Sun Sep 27, 2009 7:28 am |
| The most likely problem is that your ICD-U40 doesn't support 3.3V devices, and the 18f26k20 won't program at 5V. I ran into the same thing when I tried programming 18f46k20s with my ICD-U40. |
Posted: Sun Sep 27, 2009 7:42 am |
| ICD-U40 can program 3.3V devices, e.g. PIC24F. There have been problems with previous programming software versions, but it's O.K. at least with CCSLOAD. |
dbotkin
Posted: Sun Sep 27, 2009 7:58 am |
| Not all of them, and certainly not mine. Older versions won't do 3.3V devices. He may have a %V-only device that needs to be upgraded by CCS before it will work with J/K devices. |
bertronicom
| problems debugging 18f26k20 by using ICD-U64 |
Posted: Thu Oct 01, 2009 9:20 am |
I have purchased an unit ICD-U64 (software 4.019, firmware 2.73, hardware rev2).
By using CCSload I can programming a PIC18f26k20 but I can't debug this part with debugger in PCWH.
Any suggestion please? |
