Sanity Check: Pointers
bkamen
PostPosted: Wed Sep 16, 2009 4:09 pm     Reply with quote
Ok, this isn't working and from so many other examples, I can't seem to fish out why (other than a bug)
I have a function:
unsigned int rx_fifo_access (unsigned int *mode, char *c, unsigned int channel=0, unsigned int len=1 ) {
and inside, I set c with:
c = uart_rx_fifo[channel].buffer[out];
I've run the debugger and see this is fetching and assigning c with the right value.
upon exit of the function, the value of C is not passed back.
I'm calling it like this:
rx_fifo_access(READ, c, addr);
(I've also tried rx_fifo_access(READ, &c, addr) )
where c is declared as unsigned int c;
Now, I've determined that it's because I'm set in the code to
#device *=16
when I debug I notice that my pointer switches from an 8bit char to a 16bit int and then just dies on the return.
If I make my passed parm a 16bit variable, then it works.
So is this a bug?
I'm using PCH 4.099
PostPosted: Wed Sep 16, 2009 4:22 pm     Reply with quote
Post a short, complete, compilable example program so we can test it.
bkamen
PostPosted: Wed Sep 16, 2009 4:37 pm     Reply with quote
Here's what I'm running it on.. .adjust to your own as you like except to stay in the 18F family (to keep using PCH)
#include <18F97J60.h>
#device *=16 ICD=TRUE
#use delay(clock=41666700)
#fuses H4_SW
#fuses NOWDT,NOPROTECT,NODEBUG,NOIESO,WDT32768
#fuses NOFCMEN   // change this eventually to FCMEN
#opt 10
#use rs232(UART1, STREAM=USER, baud=115200, ERRORS)
void pointer_test ( char * c ) {
     c = 32;
void main (void) {
  char c;
  pointer_test(c);
  fprintf(USER, "%c", c);
  while (1);
I'm feel I'm just not doing this right...
bkamen
PostPosted: Wed Sep 16, 2009 4:55 pm     Reply with quote
Nevermind, I think I got it.
This works:
#device *=16
#fuses H4_SW
#opt 10
void pointer_test ( char *c ) {
   int x=0;
    *c = 32;
   x = 1;  // this is just so I can step through MPLAB's Debug mode.
void main (void) {
  char c=0;
  pointer_test(&c);
  while (1);
If you're not used to passing around pointers... and don't do it for a while... it gets messy.
-ben
