		| Author | Message |
		| kazama
				| eb500 bluetooth module (Updated With USART Code...Need help) |
				|  Posted: Thu Sep 03, 2009 4:00 pm |   |
				| hi guys, I'm currently making the bluetooth integration with my robot after finished my sensor problem. I'm using this bluetooth http://www.a7eng.com/products/bluetooth/productpages/eb500-ser.htm.
 Actually I don't have any experience on setting the bluetooth using pic16f877a. But I found a bluetooth driver that I think can be use in my project.
 http://www.ccsinfo.com/forum/viewtopic.php?t=31248&highlight=bluetooth.
 But I found out that the driver may be used for serial port bluetooth module.  Is there any other drivers for this module? I already search at the another forum, but got no result.
 Also I just want to know on how to write up a code for the pic to create a connection (handshake) between module and laptop. I heard that we can set it by only adjust the ic settings at the module or do some basic stamp which I don't know what software should I use to program the basic stamp. hopefully someone can give me some idea on how to do the connection between laptop and module.
		| kazama
				| Here my code |
				|  Posted: Wed Sep 16, 2009 2:49 am |   |
				|  	  | Code: |  	  | #include <16f877a.h>
 #fuses hs,nowdt,noprotect,nolvp
 #use delay (clock=20000000)
 #byte TXSTA=0x98
 #byte RCSTA=0x18
 #byte SPBRG=0x99
 #byte TXREG=0x19
 #byte RCREG=0x1A
 #byte PIR1=0x0C
 #bit TXEN=TXSTA.5
 #bit BRGH=TXSTA.2
 #bit SYNC=TXSTA.4
 #bit CREN=RCSTA.4
 #bit SPEN=RCSTA.7
 #bit TXIF=PIR1.4
 #bit RCIF=PIR1.5
 #byte portc=7
 unsigned char a;
 void display(unsigned char c)            // subrountine to display the text on the screen
 while (TXIF == 0);
 TXREG = c;
 unsigned char receive(void)               // subrountine to receive text from PC
 while (RCIF == 0);
 a = RCREG;
 return a;
 void init(void)                        // subroutine to initialize
 SPBRG=0x81;
 BRGH=1;
 TXEN=1;
 CREN=1;
 SPEN=1;
 SYNC=0;
 set_tris_c(0x01000000);
 init();
 while(true)                        // wait for 'ok' to be entered
 a = receive();
 if (a == 'd')break;
 display('H');
 could someone check the code. i'm using eb500 bluetooth module driver and PIC16F877A. i can see the 'H' on the hyperterminal. help me please
