lm35 temperature sensor
Goto page 1, 2  Next
evaang2003
PostPosted: Mon Jun 22, 2009 3:54 am     Reply with quote
Hi, I now trying to use pic16f877a and lm35 to read temperature.
Below is the code written:
       int16 temp_adc;
       float temp;
        setup_adc(ADC_CLOCK_DIV_8);
        setup_adc_ports(PIN_A1);
        set_adc_channel(1); //read analog input from channel 1
         printf ( LCD_PutChar, "Temperature is" );
            temp_adc = read_adc();
            temp = 5.00*temp_adc*100.00/1023.00;
            lcd_display_char(2, 0, ' ');
            printf ( LCD_PutChar, "%f%cC  ", (float)temp, DEGREE_SYM);
            delay_ms(3000);
However, it always give me 5.00 degree celcius reading even the actual temperature is around 24 degree.
Can anyone tell me why?
bungee-
PostPosted: Mon Jun 22, 2009 4:03 am     Reply with quote
Paste the complete code.
Did you measure the voltage on output pin of LM35?
aasief
PostPosted: Mon Jun 22, 2009 4:09 am     Reply with quote
Show me the LM35 circuit and what is your voltage coming out of your LM35 circuit into the pic
PostPosted: Mon Jun 22, 2009 4:37 am     Reply with quote
The 877a, does not support setting just pin A1, as an analog input. The only 'single pin', that can be set to analog on it's own, is AN0 Look in the 16F877A.h include file, at the definitions allowed. Section headed:
// Constants used in SETUP_ADC_PORTS() are:
evaang2003
PostPosted: Mon Jun 22, 2009 7:41 pm     Reply with quote
the complete code is only involve lcd driver and main function. plus some include header file as below:
#include <16f877a.h>
#device ADC=10
#fuses XT, NOWDT, NOPROTECT, NOLVP
as for circuit, I only connect the voltage output pin of lm35 to AN0 and connect the rest to respective power supply and ground. (sorry not posting the schematic).
I have test the component individually.
The voltage output of lm35 is pproportional to 10mV/degree celcius.
When a potentiometer is replaced with lm35 to adjust the voltage output to pic, it shows the analog of pic is working fine.
However, when lm35 and pic16f877a is put together, the reading I get is 5.00 degree celcius. Why?
I have changed the adc setup to setup_adc_ports(AN0).
evaang2003
PostPosted: Mon Jun 22, 2009 8:11 pm     Reply with quote
hi, everybody, I finally found the problem.
I didn't include the #device ADC=10 into the file that I compile.
That's why I always get the wrong reading.
Thanks for everyone that have try to help me before.
thanks.
PostPosted: Tue Jun 23, 2009 1:36 am     Reply with quote
I'm glad you've found the problem, but this is exactly the reason why we _always_ ask to post the complete program.
serie
View user's profile Send private message Yahoo Messenger ICQ Number
Re: lm35 temperature sensor
PostPosted: Tue Sep 01, 2009 9:43 pm     Reply with quote
hi, I have tried to compile your program using CCS C compiler but it have an error on lcd_putchar. May I know why? and what kind of compiler that you used?
PostPosted: Wed Sep 02, 2009 6:14 am     Reply with quote
Because he never posted the complete program as requested. It is missing (at least) the LCD include line. However, there is other LM35 code in this forum that is complete. I would suggest using search to find it...
sysysy
PostPosted: Tue Nov 30, 2010 9:02 am     Reply with quote
May i know what mean by set the clock_div to 8?
how about set it to other value like 16 or 64?
how the things take effect?
Regards,
sysysy
PostPosted: Tue Nov 30, 2010 9:42 am     Reply with quote
_Read the chip's data sheet_.....
The ADC requires a clock.
This must be within a certain 'range' of values for the ADC to work correctly.
This line allows you to specify what division is used (out of a limited 'set' of values), to generate the clock.
Data sheet tells you:
What the range of clock values is allowed to be.
Recommended division ratios for several clock rates.
etc. etc...
PostPosted: Tue Nov 30, 2010 9:59 am     Reply with quote
I think ..
to speed up things...
replace
with
temp_adc *0.488758 (5.00*100.00/1023.00)=.488758 if my math is right
as floating point operations take a lot of time, esp. division.
gpsmikey
PostPosted: Tue Nov 30, 2010 12:05 pm     Reply with quote
For what it's worth, if you have room on the display, during the "debug phase", I always try and display the raw data being read as well as the result. Makes it much easier to debug when you see the raw data read is not what is expected.
mikey
mikey
sysysy
PostPosted: Wed Dec 01, 2010 7:55 am     Reply with quote
temtronic wrote:
I think ..
replace
with
may i know what does ur formula mean by? can explain abit?
PostPosted: Wed Dec 01, 2010 9:48 am     Reply with quote
The original formula was
can be rewritten as
temp=temp_adc*5*100.00/1023.00
which is the same as
temp=temp_adc * (500.00/1023.00)
temp=temp_adc * .488xxxxxx
Be aware that anytime you can reduce floating point operations,you'll speed up the overall program.
In this case I got rid of a huge time killer, FP division !
Goto page 1, 2  Next
Page 1 of 2
