GPIO0 & GPIO1 for PIC12f675
Lukas
PostPosted: Mon Aug 31, 2009 10:23 am     Reply with quote
Hi I'm a new user of CCS, and I've a little problem with the GPIO0 and GPIO1 of the PIC12f675.
When I write a program, for example to have the outputs high, if I use the GPIO5 or GPIO4 the things works perfect but on GPIO0 and GPIO1 the signal stay always down
Down here is an example of code :
   setup_vref(FALSE);
   set_tris_a( 0b00001100);
   setup_adc_ports( ALL_ANALOG );
for(;;)
set_adc_channel( 2 );
delay_ms(2);
value = read_adc(ADC_START_AND_READ);
if (value<Uvp)
    output_high(PIN_A5);
    output_high(PIN_A1);
    output_high(PIN_A0);
    output_high(PIN_A4);
There are some special settings that I have to do for those pins?
PostPosted: Mon Aug 31, 2009 12:10 pm     Reply with quote
Post your compiler version. It's a 4-digit number in this format: x.xxx
It's given at the top of the .LST file, which will be in your project directory.
PostPosted: Mon Aug 31, 2009 3:45 pm     Reply with quote
I'm surprised GPI4 is working.
In the PIC processors there are more hardware modules than I/O pins, that's why you have to assign a function for many of the pins. For example GPI1 can be either a digital I/O pin, analog in, comparator input or Vref input.
What functionality do you think this call assigns to the pins with possible analog function?
Check the header file 12f675.h for the allowed parameters.
Lukas
PostPosted: Tue Sep 01, 2009 2:18 am     Reply with quote
Hi, thanks for the advises I've solved the problem! Very Happy
(now i assigned every pin to a specific function and all works properly)
Thank you very much
