		| View previous topic :: View next topic   |
			Jim Hearne
  Joined: 22 Dec 2003 Posts: 109 Location: West Sussex, UK
				| OSCCAL on 10F200, random values at power up ? |
				 Posted: Thu Aug 27, 2009 2:36 am     |
				Hi all.
I'm having a strange problem with pic 10F200's
Using PCWH 4.093 and a CCS Mach-X programmmer.
These chips have an option for clock out on port GP2, this is selected by bit zero of the osccal register.
The initial problem was that the chips would randomly power up with clock out enabled.
I had to clear bit zero of osccal to stop this.
Then i noticed that the clock speed varies from one power up to the next.
This coupled with the oscout problem suggests that either the compiler or the program isn't initalizing osccal correctly but i can't see anything wrong with the code.
I shouldn't have to have line 25 i'm sure.
I've read the blank chips which seem to have the oscal value at the end of memory and checked it again after they've been programmed and it's still the same value, always with bit zero cleared. (oscout off).
Can anybody spot anything ?
Thanks.
Jim
 	  | Code: | 	 		  #include <10F200.h>
#FUSES WDT, NOMCLR, PROTECT
//////// Fuses: MCLR,NOMCLR,PROTECT,NOPROTECT,WDT,NOWDT
#byte port_b = 0x06
#byte osccal = 0x05
#bit CLK3    = port_b.0
#bit CLK1    = port_b.1
#bit CLK2    = port_b.2
#bit RESET   = port_b.3
#use fast_io(B)
#define PERIOD     50  //=20khz
#define DEADBAND    5
#define INSTRUCTION 1 // clock is 4mhz which equals 1us per instruction.
#define TIME1 DEADBAND-INSTRUCTION
#define TIME2 (PERIOD/2)-(DEADBAND*2)-INSTRUCTION
 osccal = osccal & 0xfe; // without this line the chip will randomly power up with fosc4 output enabled on GP2 (B.2)
 setup_wdt(WDT_18MS | DISABLE_PULLUPS | DISABLE_WAKEUP_ON_CHANGE);
 setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
 set_tris_b(0b00001000);
 CLK1=1;
 CLK2=1;
 CLK3=1;
     delay_cycles(TIME1-3); // -3 extra instructions to allow for restart wdt and loop back to start.
     CLK2=0;
     delay_cycles(TIME2);
     CLK2=1;
     delay_cycles(TIME1);
     CLK1=0;
     CLK3=0;
     CLK3=1;
     CLK1=1;
     restart_wdt();
Asm
 	  | Code: | 	 		  MPASM
CCS PCB C Compiler, Version 4.093, 44429               27-Aug-09 09:14
               Filename: \\Server2005\c\Work\All Products\microvision\boiler probe interface\code\clock gen iss2 pcb 10f200.lst
               ROM used: 44 words (17%)
                         Largest free fragment is 212
               RAM used: 2 (12%) at main() level
                         2 (12%) worst case
               Stack:    0 locations
0000 0025       00001 MOVWF  05
0001 0A02       00002 GOTO   002
                00003 .................... #include <10F200.h>
                00004 .................... //////// Standard Header file for the PIC10F200 device ////////////////
                00005 .................... #device PIC10F200
                00006 .................... //#nolist
                00007 .................... //////// Program memory: 256x12  Data RAM: 16  Stack: 2
                00008 .................... //////// I/O: 4   Analog Pins: 0
                00009 .................... //////// C Scratch area: 10   ID Location: 0100
                00010 .................... //////// Oscilator Calibration Address: 05
                00011 .................... //////// Fuses: MCLR,NOMCLR,PROTECT,NOPROTECT,WDT,NOWDT
                00012 .................... ////////
                00013 .................... ////////////////////////////////////////////////////////////////// I/O
                00014 .................... // Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
                00015 .................... //                         PORT_x_PULLUPS(), INPUT(),
                00016 .................... //                         OUTPUT_LOW(), OUTPUT_HIGH(),
                00017 .................... //                         OUTPUT_FLOAT(), OUTPUT_BIT()
                00018 .................... // Constants used to identify pins in the above are:
                00019 ....................
                00020 .................... #define PIN_B0  48
                00021 .................... #define PIN_B1  49
                00022 .................... #define PIN_B2  50
                00023 .................... #define PIN_B3  51
                00024 ....................
                00025 .................... ////////////////////////////////////////////////////////////////// Useful defines
                00026 .................... #define FALSE 0
                00027 .................... #define TRUE 1
                00028 ....................
                00029 .................... #define BYTE int8
                00030 .................... #define BOOLEAN int1
                00031 ....................
                00032 .................... #define getc getch
                00033 .................... #define fgetc getch
                00034 .................... #define getchar getch
                00035 .................... #define putc putchar
                00036 .................... #define fputc putchar
                00037 .................... #define fgets gets
                00038 .................... #define fputs puts
                00039 ....................
                00040 .................... ////////////////////////////////////////////////////////////////// Control
                00041 .................... // Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
                00042 .................... // Constants returned from RESTART_CAUSE() are:
                00043 .................... #define WDT_FROM_SLEEP  0x00
                00044 .................... #define WDT_TIMEOUT     0x08
                00045 .................... #define MCLR_FROM_SLEEP 0x10
                00046 .................... #define NORMAL_POWER_UP 0x18
                00047 .................... #define COMP_FROM_SLEEP 0x50
                00048 .................... #define PIN_CHANGE_FROM_SLEEP 0x90
                00049 ....................
                00050 ....................
                00051 .................... ////////////////////////////////////////////////////////////////// Timer 0
                00052 .................... // Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
                00053 .................... //                              SET_TIMER0() or SET_RTCC(),
                00054 .................... //                              GET_TIMER0() or GET_RTCC()
                00055 .................... // Constants used for SETUP_TIMER_0() are:
                00056 .................... #define RTCC_INTERNAL   0
                00057 .................... #define RTCC_EXT_L_TO_H 32
                00058 .................... #define RTCC_EXT_H_TO_L 48
                00059 ....................
                00060 .................... #define RTCC_DIV_1      8
                00061 .................... #define RTCC_DIV_2      0
                00062 .................... #define RTCC_DIV_4      1
                00063 .................... #define RTCC_DIV_8      2
                00064 .................... #define RTCC_DIV_16     3
                00065 .................... #define RTCC_DIV_32     4
                00066 .................... #define RTCC_DIV_64     5
                00067 .................... #define RTCC_DIV_128    6
                00068 .................... #define RTCC_DIV_256    7
                00069 ....................
                00070 ....................
                00071 .................... #define RTCC_8_BIT      0
                00072 ....................
                00073 .................... // Constants used for SETUP_COUNTERS() are the above
                00074 .................... // constants for the 1st param and the following for
                00075 .................... // the 2nd param:
                00076 ....................
                00077 .................... ////////////////////////////////////////////////////////////////// WDT
                00078 .................... // Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
                00079 .................... //                            RESTART_WDT()
                00080 .................... // WDT base is 18ms
                00081 .................... //
                00082 ....................
                00083 .................... #define WDT_18MS        8
                00084 .................... #define WDT_36MS        9
                00085 .................... #define WDT_72MS       10
                00086 .................... #define WDT_144MS      11
                00087 .................... #define WDT_288MS      12
                00088 .................... #define WDT_576MS      13
                00089 .................... #define WDT_1152MS     14
                00090 .................... #define WDT_2304MS     15
                00091 ....................
                00092 .................... #define DISABLE_PULLUPS            0x40  // for 508 and 509 only
                00093 .................... #define DISABLE_WAKEUP_ON_CHANGE   0x80  // for 508 and 509 only
                00094 .................... #ifndef PIN_CHANGE_FROM_SLEEP
                00095 .................... #define PIN_CHANGE_FROM_SLEEP      0x90  // for 508 and 509 only
                00096 .................... #endif
                00097 ....................
                00098 ....................
                00099 .................... #list
                00100 ....................
                00101 .................... #FUSES WDT, NOMCLR, PROTECT
                00102 .................... //////// Fuses: MCLR,NOMCLR,PROTECT,NOPROTECT,WDT,NOWDT
                00103 ....................
                00104 .................... #use delay(clock=4000000)
                00105 .................... #byte port_b = 0x06
                00106 .................... #byte osccal = 0x05
                00107 ....................
                00108 .................... #bit CLK3    = port_b.0
                00109 .................... #bit CLK1    = port_b.1
                00110 .................... #bit CLK2    = port_b.2
                00111 .................... #bit RESET   = port_b.3
                00112 ....................
                00113 .................... #use fast_io(B)
                00114 ....................
                00115 .................... #define PERIOD     50  //=20khz
                00116 .................... #define DEADBAND    5
                00117 .................... #define INSTRUCTION 1 // clock is 4mhz which equals 1us per instruction.
                00118 ....................
                00119 .................... #define TIME1 DEADBAND-INSTRUCTION
                00120 .................... #define TIME2 (PERIOD/2)-(DEADBAND*2)-INSTRUCTION
                00121 ....................
                00122 .................... void main()
                00123 .................... {
0002 0CDF       00124 MOVLW  DF
0003 0002       00125 OPTION
0004 0064       00126 CLRF   04
                00127 ....................  osccal = osccal & 0xfe; // without this line the chip will randomly power up with fosc4 output enabled on GP2 (B.2)
0005 0405       00128 BCF    05.0
                00129 ....................  setup_wdt(WDT_18MS | DISABLE_PULLUPS | DISABLE_WAKEUP_ON_CHANGE);
0006 0070       00130 CLRF   10
0007 0061       00131 CLRF   01
0008 0C0F       00132 MOVLW  0F
0009 0002       00133 OPTION
000A 0004       00134 CLRWDT
000B 0210       00135 MOVF   10,W
000C 0002       00136 OPTION
                00137 ....................  setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
000D 0C07       00138 MOVLW  07
000E 0002       00139 OPTION
                00140 ....................  set_tris_b(0b00001000);
000F 0C08       00141 MOVLW  08
0010 0006       00142 TRIS   6
                00143 ....................
                00144 ....................  CLK1=1;
0011 0526       00145 BSF    06.1
                00146 ....................  CLK2=1;
0012 0546       00147 BSF    06.2
                00148 ....................  CLK3=1;
0013 0506       00149 BSF    06.0
                00150 ....................
                00151 ....................  while(1)
                00152 ....................      {
                00153 ....................      delay_cycles(TIME1-3); // -3 extra instructions to allow for restart wdt and loop back to start.
0014 0000       00154 NOP
                00155 ....................      CLK2=0;
0015 0446       00156 BCF    06.2
                00157 ....................      delay_cycles(TIME2);
0016 0C04       00158 MOVLW  04
0017 0030       00159 MOVWF  10
0018 02F0       00160 DECFSZ 10,F
0019 0A18       00161 GOTO   018
001A 0000       00162 NOP
                00163 ....................      CLK2=1;
001B 0546       00164 BSF    06.2
                00165 ....................      delay_cycles(TIME1);
001C 0A1D       00166 GOTO   01D
001D 0A1E       00167 GOTO   01E
                00168 ....................      CLK1=0;
001E 0426       00169 BCF    06.1
                00170 ....................      delay_cycles(TIME1);
001F 0A20       00171 GOTO   020
0020 0A21       00172 GOTO   021
                00173 ....................      CLK3=0;
0021 0406       00174 BCF    06.0
                00175 ....................      delay_cycles(TIME2);
0022 0C04       00176 MOVLW  04
0023 0030       00177 MOVWF  10
0024 02F0       00178 DECFSZ 10,F
0025 0A24       00179 GOTO   024
0026 0000       00180 NOP
                00181 ....................      CLK3=1;
0027 0506       00182 BSF    06.0
                00183 ....................      delay_cycles(TIME1);
0028 0A29       00184 GOTO   029
0029 0A2A       00185 GOTO   02A
                00186 ....................      CLK1=1;
002A 0526       00187 BSF    06.1
                00188 ....................      restart_wdt();
002B 0004       00189 CLRWDT
                00190 ....................      }
002C 0A14       00191 GOTO   014
                00192 .................... }
002D 0003       0193 SLEEP
Configuration Fuses:
   Word  1: 0FE7   NOMCLR PROTECT WDT
SYMBOL TABLE
  LABEL                             VALUE
osccal                            00000005
port_b                            00000006
CLK3                              00000006
CLK1                              00000006
CLK2                              00000006
RESET                             00000006
_RETURN_                          00000011
Allocation:                       0000EEEF
main                              00000002
MEMORY USAGE |
				 Posted: Thu Aug 27, 2009 2:01 pm     |
				 	  | Quote: | 	 		  | The initial problem was that the chips would randomly power up with clock out enabled.  |
Read this section of the 10F200 data sheet.  You probably erased the
MOVLW xx  instruction at the end of ROM, or programmed it with some
other value than the factory value.  Or the MachX did it.
 	  | Quote: |
9.2.2 INTERNAL 4 MHz OSCILLATOR
In addition, a calibration instruction is programmed into
the last address of memory, which contains the calibration
value for the internal oscillator. This location is
always uncode protected, regardless of the code protect
settings. This value is programmed as a MOVLW xx
instruction where xx is the calibration value and is
placed at the Reset vector. This will load the W register
with the calibration value upon Reset and the PC will
then roll over to the users program at address 0x000.
The user then has the option of writing the value to the
OSCCAL Register (05h) or ignoring it.
OSCCAL, when written to with the calibration value, will
“trim” the internal oscillator to remove process variation
from the oscillator frequency. |
Read the value of the last ROM address in the PIC, with your
programmer.  What is it ?
Also check to see if the MachX has a setting that will preserve
this value (it probably should do it automatically).
If you have erased the OSCCAL value at the end of ROM, then you could
fix it by adding the ROM statement shown below.  This puts the opcode for
a MOVLW 0x00 statement at the end of ROM.   That will turn off the
FOSC/4 output, and it will set OSCCAL for the center frequency.
#include <10F200.h>
#FUSES NOWDT, NOMCLR, NOPROTECT
#rom 0xFF = {0xC00}  // Put MOVLW 0x00 at end of ROM
			Jim Hearne
				 Posted: Fri Aug 28, 2009 3:29 am     |
				Hi PCM,
You seem to be correct, the programmer isn't preserving the osccal value at 0x1FFF
I've tested a couple of chips before programming and then read them back.
Before:
 	  | Code: | 	 		  Chip one: 0x0c16
Chip two: 0x0c20 |
After
 	  | Code: | 	 		  Chip one: 0x0064
Chip two: 0x0fff |
I'm not quite sure what it's doing but it's not correct.
The ccsload software for the machx had no specific options for the calibration, there is a calibrate chip button but it just comes back saying "Fail".
The help for this says
 	  | Quote: | 	 		  Calibrate – Only appears for chips that have a calibration constant in program memory.
This function will recalculate the calibration constant and store it in memory.
Note that for these chips the CCSLOAD software does not change this constant on writes or erases.  |
Which implies that it should be preserving the calibration value.
Time for another email to CCS i guess :-(
Thanks for you help,
Jim |
			Jim Hearne
				 Posted: Fri Aug 28, 2009 3:59 am     |
				Oh, forgot, all the chip does is generate 3 clock signals but we'd like to keep them as accurate as is possible with the on chip osc so really want to keep the calibrated oscilator.
Jim |
