| PWM low frequencies not working |
Posted: Sat Aug 22, 2009 11:12 am |
Hello, Hoping someone can tell that I am doing some stupid here. I can not figure out why i can't get a 20 hz PWM to work. I am using the following code and compiler 4.083.
I am using the following calaulation for the PR2:
//16*16*(193+1)*4/4e6 = period = .049 (s)
//f = 20.4 hz
The code is not giving a 20 hz output. Any ideas on what I'm doing wrong?
#include <18F4520.h>
#fuses INTRC,NOPROTECT,MCLR,NOBROWNOUT,BORV45,NOWDT,WDT128,NOPUT,NOSTVREN,NODEBUG
#fuses NOLVP,NOWRT,NOCPB,NOWRTB,NOWRTC,NOCPD,NOWRTD,NOEBTR,NOEBTRB
#fuses NOXINST //extended cpu
#fuses CCP2B3 //multiplex ccp2 to rb3
#include <lcd_picdem2_2.c>
//ccp2 to rb3 ccp2mx : multiplex ccp2 to rb3: use fuse
void main(){
int8 i = 0, j = 0;
lcd_init();
set_tris_b(0x00);
set_tris_c(0x00);
//tested
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_1,32,1);//32.25 khz to get 7 bits resolution for duty cycle//see equeation
//f = 20.4 hz
setup_timer_2(T2_DIV_BY_16,194, 16);
while(1){
}//while
}//main
Posted: Sat Aug 22, 2009 11:31 am |
The PWM frequency formula is in this thread and in the PIC data sheet:
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
If you still have a problem, then tell us your overall purpose and why
you need a PWM frequency of 20 Hz. |
Posted: Sat Aug 22, 2009 5:35 pm |
Ahhhh, postscaler confusion.
The purpose is just for fun stuff. Blinking some led arrays (visibly). Wanted to have some routines that required minimal software control. I see Ttelmah and you have pointed out some good methods in the linked posts. I will implement some of them.
Thanks for the amazing support, as always. |
