sindyvirgo
| How can I set two hardware uart of 18F63J11 |
Posted: Sun Aug 09, 2009 9:26 pm |
Hello ! everybody.
My 18F63J11 work now but it have two uart.
I discovered that they will snatch the resources mutually.
When the word string surpasses 5 that my terminating machine has exceptionally.
How can I set two hardware uart of 18F63J11 ?
Help me please.
#include <string.h>
char buff1,buff2;
#int_RDA
RDA_isr(void)
buff1 = getc();
printf("%c",buff1);
#int_RDA2
RDA2_isr(void)
buff2 = getc();
printf("%c",buff2);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
delay_ms(200);
output_high(pin_b0); <---- This my work LED. It have work now.
for(;;)
printf("Testing..."); <--- Can't runing
delay_ms(300);
My .H file
#include <18F63J11.h>
#device adc=8
#FUSES HS //External Clock with SW enabled 4x PLL
#FUSES NOXINST
#FUSES PRIMARY
#FUSES RESERVED
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8)
dyeatman
Posted: Sun Aug 09, 2009 9:36 pm |
Add a stream definition to each of the USE RS232 definitions and then add the stream names to each of the getc() putc() and printf() commands. Search for stream in the CCS manual for information on the format of the commands. Also, look at the message next to this one titled "undefined identifier STREAM_UART" for info as well.
BTW, using printf() in the ISR is likely to cause problems at some point due to spending too much time in the ISR.... _________________ Google and Forum Search are some of your best tools |
sindyvirgo
Posted: Sun Aug 09, 2009 10:45 pm |
Hello everybody.
18F63J11 have two hardware uart.
I set the stream for uart(A) and uart(B) , but still could not the normal work.
When the word string surpasses 5 that my terminating machine still has exceptionally.
It can work but is not normal.
.H file
| Code: | #include <18F63J11.h>
#device adc=8
#FUSES NOWDT
#FUSES WDT128
#FUSES HS
#FUSES NODEBUG
#FUSES NOXINST
#FUSES STVREN
#FUSES NOPROTECT
#FUSES FCMEN
#FUSES IESO
#FUSES PRIMARY
#FUSES RESERVED
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,STREAM=COM_A)
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8,STREAM=COM_B)
my main .C
char buff1,buff2;
#int_RDA
RDA_isr()
disable_interrupts(INT_RDA2);
buff1 = getc(COM_A);
#int_RDA2
RDA2_isr()
disable_interrupts(INT_RDA);
buff2 = getc(COM_B);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
delay_ms(200);
output_high(pin_b0); <--- 63J11 work LED
for(;;)
fprintf(COM_A,"Testing1..."); <----can't running
fprintf(COM_A,"%c",buff1);
delay_ms(300);
fprintf(COM_B,"Testing2..."); <----can't running
fprintf(COM_B,"%c",buff1);
delay_ms(300);
