Deark
(write / read _program_memory) in 18f2550 |
Posted: Sat Aug 08, 2009 11:01 am |
I have a problem with the function Write_program_memory and Read_program_memory, I do not know how to use this function and I need to write into the flash memory of pic18f2550.
When compiling the code in CCS, this gives no errors, the problem is to simulate in Proteus 7.2. Also present problems in hardware.
This is the code in CCS:
#include "yy.h"
#include <lcd.c>
#fuses NOWDT,HS, NOPROTECT,NOBROWNOUT, NOPUT, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
int16 write_data, read_data;
setup_adc_ports(NO_ANALOGS);
write_data = 0x55;
write_program_memory(0x4000, write_data, 2);
read_program_memory(0x4000, read_data, 2);
printf(lcd_putc,"%2X ", read_data);
I want you to help me in my problem.
I very much appreciate your help. |
Posted: Sat Aug 08, 2009 11:18 am |
Your middle parameter is wrong in both function calls. Read the CCS
manual. It says the middle parameter must be a pointer:
Quote: |
write_program_memory( )
Syntax: write_program_memory( address, dataptr, count );
Parameters:
address is 16 bits on PCM parts and 32 bits on PCH parts.
dataptr is a pointer to one or more bytes
count is a 8 bit integer
read_program_memory( )
Syntax: read_program_memory (address, dataptr, count );
Parameters:
address is 16 bits on PCM parts and 32 bits on PCH parts. The least
significant bit should always be 0 in PCM.
dataptr is a pointer to one or more bytes.
Deark
Posted: Sat Aug 08, 2009 11:59 am |
Can you give me an example of use of function Write / read program_memory? please. |
Posted: Sat Aug 08, 2009 12:18 pm |
You need to study the C language and learn how to create a pointer
to an integer variable. It's done by pre-fixing the variable name with
an Ampersand (&) character. Example:
Quote: | write_program_memory(0x4000, &write_data, 2);
read_program_memory(0x4000, &read_data, 2); |
Deark
Posted: Sat Aug 08, 2009 3:47 pm |
Thank you very much! Now we have no errors in the Proteus 7.2 simulator .
We know that pointers are a variable that save memory address of other variable. Can how this help us? |
Posted: Sat Aug 08, 2009 7:39 pm |
I'm not sure what you are asking. Do you need any other help ? |
Posted: Sun Aug 09, 2009 2:28 am |
Deark wrote: | Thank you very much! Now we have no errors in the Proteus 7.2 simulator .
Not quite.
A pointer, _is_ the address of a variable.
You can have variables that are themselves pointers, and use these to contain the addresses of variables. However in this case, you don't need the variable.
If you look at the manual entry for the read and write functions, the second entry, _needs_ to be the address in memory (pointer) to where you want to store the value.
The '&' operation, returns the pointer 'to' a variable, which is what the functions need. You could perfectly well declare a pointer variable, and put the address into this, but you don't need to. What you need to do, is pass the address to the function. Nothing more.
The functions need to know 'where' to put the data, hence they need the address.
