Hussien Guest
Help in using I2C |
Posted: Sat Aug 08, 2009 3:30 am |
Hello every one...
I want a help in I2C, I tried to make a connection between PIC16F877A and 24AA26 by I2C, to save a float data on it, but there is an error.
And thanks alot....
Please check the following code :
Code: | #use i2c(master,scl=PIN_C3,sda=PIN_C4,force_hw)
#INT_SSP
void I2C_wrt(long int address,float data1)
i2c_start();
i2c_write(0b00000000); // call address for slave (in general)
i2c_write(address);
i2c_write(data1); // Data1 to device
i2c_stop();// Stop condition
float I2C_rd(void)
float data;
i2c_start();
i2c_write(0b00000000); // general call address for slave
i2c_start(); // send a restart sequence
i2c_write(0b00000001);
data = i2c_read(0); // Data to PIC16F877
i2c_stop(); // Stop condition
return(data);
adfkk Guest
Answer |
Posted: Sat Aug 08, 2009 3:52 am |
Your data type to be stored is float which I think is 4 bytes long.
Thus, you have to divide your signle float data into four 8-bit variable(for example, int).
After you have divided the float into 4 int, store them in 4 different EEPROm address.
Hope this helps |
Hussien Guest
Posted: Sat Aug 08, 2009 4:49 am |
Thank for your reply...
I tried to convert the float into int but no result...the dividing code is:
Code: | float *data1;
int data2[],data3[],data4[],data5[];
int j;
for (j=0;j<=8;j++)
data2[j]=data1[j];
for (j=9;j<=16;j++)
data2[j]=data1[j];
for (j=17;j<=24;j++)
data2[j]=data1[j];
for (j=25;j<=32;j++)
data2[j]=data1[j];
I don't know if the last code is right; because I'm beginner in ccs...
thanks |
Posted: Sat Aug 08, 2009 7:15 am |
No.
Nothing to do with CCS. This wouldn't work in any C....
If you have a pointer to a value, and increment it, it advances to the next value.
To use pointer arithmetic to get the bytes, you need to convert the pointer type, it an int*.
Then, you have declared data2 (and the other data variables), as a pointer to an integer (in C, an array, and a pointer, are basically the same thing), but have not allocated any storage to hold the array. You then start writing vues into the addresses held by these pointers, destroying random areas of your memory...
There are multiple ways to do this:
1) Look at the internal 'make8' and 'make32' functions. These allow you to extract the 8bit values, and put them back together again.
2) Use pointer arithmetic, but convert the pointer types.
float val;
int8 * ptr;
ptr=&val;
You can then access ptr[0]...ptr[3] as the four bytes of 'val'.
3) Use a union. A search here will find a lot of examples.
Advantage is that this is nearly 'generic' C, rather than make8, being CCS specific.
Hussien Guest
Posted: Sat Aug 08, 2009 10:31 am |
Thank alot.... |
