		| Author | Message |
		| Grimmtooth
				| Need help tracing an assembly call |
				|  Posted: Fri Aug 07, 2009 6:44 pm |   |
				| I'm looking to trace the c compiler's assembly structures and calls to look for speed optimization opportunities. Unfortunately, I have yet to figure out how to trace calls like the one that follows:
  	  | Code: |  	  | 00848:  BCLR.B  43.0 0084A:  MOV     W6,W0
 0084C:  MOV     W7,W1
 0084E:  MOV     #100,W2
 00850:  MOV     #0,W3
 00852:  CALL    32A
 00856:  ADD     W0,[W5],[W5]
 00858:  ADDC    W1,[++W5],[W5]
 Is there a way to search for the assembly call to 32A or find it manually? Initially, I thought it was a call to a program address, having run  a search, I found that is not the case.
 Anyone have suggestions how I can trace the compiler function call?
		| PCM programmer
				|  Posted: Fri Aug 07, 2009 7:03 pm |   |
				| To see the all the ASM code for the program in the .LST file, you need to comment out the #nolist statement at the start of the .H file for your PIC.
 Example:
  	  | Quote: |  	  | //////// Standard Header file for the PIC18F452 device /////////
 #device PIC18F452
 //#nolist
 Then re-compile and look for your routine again.
		| Grimmtooth
				|  Posted: Mon Aug 10, 2009 12:36 pm |   |
				| I'm using a pic24f and my header is as follows:
  	  | Code: |  	  | #include <24FJ128GA010.h>
 #FUSES DEBUG                    //Debug mode for use with ICD
 #FUSES NOCOE                    //Device will reset into operational mode
 #FUSES ICSP2                    //ICD uses PGC2/PGD2 pins
 #FUSES NOWINDIS                 //Watch Dog Timer in Window mode
 #FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
 #FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
 #FUSES PR_PLL                   //Primary Oscillator with PLL
 #FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
 #FUSES NOOSCIO                  //OSC2 is clock output
 #FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
 #use delay(clock=32000000)
 I didn't see a #nolist preprocessor  command on the list. Is this a default functionality that I need disable? Also, the assembly I am looking for is not a user-defined function, but a compiler called function used to compile a loop written in c. I am just trying to verify how it implemented the program from c.
		| PCM programmer
				|  Posted: Mon Aug 10, 2009 12:53 pm |   |
				| I don't have the PCD compiler, but in PCB, PCM, and PCH, the #nolist line would be near the top of the .h file for PIC.  Look in this file:
		| Grimmtooth
				|  Posted: Mon Aug 10, 2009 5:44 pm |   |
				| I was able to track down the nolist command and comment it out, but it didn't change the call structure of the compiler. For example, the c expression here in assembly has 2 calls to functions, but I can't find anything relating to call 22E or call 32A.
 Is there a way to single step through the assembly code instead of the c code? If so, perhaps I can follow the trace that way.
  	  | Code: |  	  | ....................             data[a]-=(21*data[b]+11)/64; 0073E:  MOV     A96,W4
 00740:  MUL.UU  W4,#4,W0
 00742:  MOV     #862,W4
 00744:  ADD     W0,W4,W5
 00746:  MOV     A98,W4
 00748:  MUL.UU  W4,#4,W0
 0074A:  MOV     #862,W4
 0074C:  ADD     W0,W4,W0
 0074E:  MOV     W0,W4
 00750:  MOV     #0,W3
 00752:  MOV     [W4++],[W3++]
 00754:  MOV     [W4++],[W3++]
 00756:  MOV     W0,W2
 00758:  MOV     W1,W3
 0075A:  MOV     #15,W0
 0075C:  MOV     #0,W1
 0075E:  CALL    22E
 00762:  MOV.D   W0,W6
 00764:  ADD     W6,#B,W6
 00766:  ADDC    W7,#0,W7
 00768:  BCLR.B  43.0
 0076A:  MOV     W6,W0
 0076C:  MOV     W7,W1
 0076E:  MOV     #40,W2
 00770:  MOV     #0,W3
 00772:  CALL    32A
 00776:  MOV     [W5],W4
 00778:  SUB     W4,W0,[W5]
 0077A:  MOV     [++W5],W4
 0077C:  SUBB    W4,W1,[W5]
		| PCM programmer
				|  Posted: Mon Aug 10, 2009 5:51 pm |   |
				| What happens if you load the .LST file and do a search for that address ? Do you see it ?
 If not, in MPLAB, go to the View menu and look at the Disassembly listing
 and/or the Program Memory window.
 If the code is actually there, you'll at least see it in the Program Memory
 window.
 However, I don't have the PCD compiler, so I can't verify this for myself.
 This advice is based on the PCM and PCH compilers.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
