frierray
| PWM1 and Timer1 problems |
Posted: Thu Aug 06, 2009 1:19 pm |
All,
I was wondering if I could get some input from the group. The following is a small part of some PWM code. The PWM users PWM1 and Timer 2.
// Set up PWM
set_pwm1_duty(0); // This sets the on time
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1, 127, 1); // Set Parms
I am also using Timer 1 to determine the time a switch is pressed.
Problem is; when I enable the interrupts (enable_interrupts(GLOBAL);) the PWM for loop runs the first time and then stops. Is it valid to use the PWM1 and Timer1 for two different functions?
I am using a 18f252 and compiler 4.073.
Thanks, Ray
The following is some of the code I have written.
void main (void)
// Set up int for t1 for switch timer
// T1 timer used for key switch management
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1); // T1 clk = 20 MHz
set_timer1(TIMER1_PRESET);
// Main system loop
if(!input(sw_left)) // look for Left Switch low
Miliseconds = 0;
clear_interrupt(INT_TIMER1);
delay_ms(10); // debounce
if(input(sw_left)) // look for Left Switch high
move_back(); // move carirer to home
if(Miliseconds > 500)
while(!input(sw_left)){}
hard_stop(); // Stop now
void move_back(void)
carrier_stat=1; // 0 = stop, 1 = moving home, 2 maving DR
// Set direction = back to home
output_bit(direction, back); // Set Direction = Back)
ramp_up();
void move_forward(void)
carrier_stat=1; //
output_bit(direction, forward); // Set Direction = Back)
ramp_up();
void ramp_up()
// Set up PWM
ml=0; // reset ml counter
motor_speed=50; // motor speed start
for (ml=51;ml<=254;++ml) // loop for ramp up
motor_speed=((motor_speed*sp_factor)); // Set motor to x%
set_pwm1_duty(motor_speed); // This sets the on time
delay_ms(5); // loop timer 5 ms
motor_speed=motor_speed+1; // inc the loop 1
Posted: Thu Aug 06, 2009 2:57 pm |
| Quote: | clear_interrupt(INT_TIMER1);
enable_interrupts(GLOBAL); |
You don't have (or didn't post) a #int_timer1 interrupt routine.
You need one. |
frierray
Posted: Thu Aug 06, 2009 3:14 pm |
PCM Programmer;
I forgot to include it with the post. Here it is:
#define TIMER1_PRESET (65536 - 5000) // Interrupt every 5000 counts
// t1 timer used for key switch management
#int_timer1
void timer1_isr(void)
miliseconds++;
I am using it to count milliseconds. In my code I need to know if a button is pressed and released or held down. If the count is > 500, it is assumed the button is held. There is a different action taken if it is pressed and released or held.
The PWM is controlled by a for loop. (If there is a better way to do this, please let me know) However, the for loop works great until I turn on the enable_interrupts(GLOBAL); After that the for loop only starts one pass and then stops. Control returns to my button code.
Any thoughts you have would be a big help.
Ray
void ramp_up()
// Set up PWM
