dk-info
Joined: 13 Apr 2009 Posts: 5 Location: Melbourne, Florida
| Simple LCD interface, 4-bit using Project Wizard example |
Posted: Tue Aug 04, 2009 9:40 am |
I built a simple LCD interface circuit, using a PIC16LF84A @ 4MHz with port b dedicated to the 4-bit interface and a working 2x16 LCD display.
Using the Project Wizard, I selected "use LCD" driver, ticked off the "example code" box, and it added the following statement:
| Code: | | lcd_putc("\fReady....\n"); |
Looking at the lcd_putc() procedure in LCD.C (the LCD driver code) it is clearly displays a single character at a time. The procedure lcd_putc() should only output one character, in this statement the '\f'. Here is the the lcd_putc() code:
| Code: | void lcd_putc(char c) {
switch (c) {
// Clear the display
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
// move the cursor to line 2, first character
case '\n' : lcd_gotoxy(1,2);
// move the cursor to the left one character
case '\b' : lcd_send_byte(0,0x10);
default : lcd_send_byte(1,c);
} // end switch(c)
} // end procedure lcd_putc() |
How is this statement supposed to display the "Ready..." message? Am I missing something?
My display doesn't output anything at this point, and in addition to a code question I may have wiring problems but I would like to understand what the example was expected to do.
David |
Wayne_
Posted: Tue Aug 04, 2009 9:55 am |
Am I the first
CCS compiler has a special built in ability.
When presented with a function with a single char parameter and called with a const string the CCS compiler will iterate throught the string calling the function once for each char.
If you look in the LCD file you will also notice that there is an equivilant but slower function for sending strings.
So yes it will work! |
bkamen
Posted: Tue Aug 04, 2009 11:37 am |
Also remember that \f and \n are understood by the compiler to be escaped chars. (or in other words, what's the hex/dec equiv of this defined escape sequence)
So you don't want to send a '\' and an 'n', but those are understood to be a single ASCII non-viewable char.
typically \r\n means to send a CR/LF combo.
If you'd like to read all about it:
http://en.wikipedia.org/wiki/Newline
lastly, if you think about it (and read the datasheet for the LCD's controller), all transactions to the LCD are 1byte at a time. In the case of a character LCD, that might be a Char at a time, with a graphics LCD, that might be 1dot (or multiple) at a time.
In the case of the nibble wide bus (4bits) each char/byte takes 2 transactions!!
Posted: Tue Aug 04, 2009 11:47 am |
| Wayne_ wrote: | Am I the first
OK, that's cool. which file contains that routine? I looked in LCD.C and only found:
lcd_putc()
lcd_init()
lcd_getc()
lcd_gotoxy()
lcd_read_byte()
lcd_send_nibble()
lcd_send_byte()
I wrote a "lcd_puts()":
| Code: | void lcd_puts(char *inString) {
unsigned char index = 0;
while (inString[index] != NULL) {
lcd_putc(inString[index++]);
} // end while(there are characters to output)
} // end procedure lcd_puts(inString) |
This code works on another C-Compiler (Dev C/C++on my PC in console mode) . Like I said, I may have a wiring problem (solder-less breadboards can be flaky, along with the builder ;) or a port location problem. I will try it and report back.
Thanks for the reply,
David |
bkamen
Posted: Tue Aug 04, 2009 11:51 am |
To elaborate what Wayne said already, CCS has already done the work for you...
printf(lcd_putc, "This is my string\r\b");
or even
unsigned char string[20];
sprintf(string, "My reading: 0x%02X\r\n", somevar);
printf(lcd_putc, "%s", string);
This is in the CCS manual under printf and sprintf
-Ben
P.s. START SIMPLE to get your LCD working. A lot of the problems start with wiring. Make sure you have all the lines hooked up. In a lot of cases (because the Hitachi 44780) was so popular, you need, E, RS, RW, D4:7 for 4 bits. If you don't have the contrast and +5/GND hooked up right, it won't work either. :D _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
Wayne_
Posted: Wed Aug 05, 2009 2:01 am |
| Quote: | | If you look in the LCD file you will also notice that there is an equivilant but slower function for sending strings. |
Yes sorry about that, I was thinking of something else. |
dk-info
| Thanks for the LCD help! |
Posted: Wed Aug 05, 2009 9:39 am |
Thanks to all who helped, the simple LCD is now working. The short points:
Make sure to un-comment the (#define use_portb_lcd TRUE) port definition in lcd.c when using a device with the lcd connected to port b
In the project wizard, do not select both the LCD driver, and the "use LCD" options.
Insure the Vee voltage is set to make the characters viable. (A 10k pot between Vdd and Vss works great)
Insure the interface code matches your interface, (i.e. nibble/byte)
Insure the control signals and data bits are within the same port, and match the structure "lcd_pin_map"
This is a great forum, and with the kind help of the forum members, made a frustrating experience easier.
David |
