kaps123
Low voltage "LF" chips can be used as normal ? |
Posted: Sun Jul 26, 2009 10:48 pm |
Dear All,
I Need Help!
I want to know whether the chips designated "LF" (low voltages devices, Example :PIC18LF2580 ) can be used as normal "F" designated chips (Example: PIC18F2580). I know the vice-versa is not true. Whether all the ports, I2C, SPI, SERIAL and so on, etc. of "LF" chips function as standard "F" chip at +5. I mean are there any restrictions or limitations? Can I replace PIC18F2580 from the circuit and use PIC18LF2580 at + 5V ? I searched the datasheet but didn't find anything important regarding this.....
Amit |
bungee-
Posted: Mon Jul 27, 2009 1:40 am |
You can. If F version of chip works, the LF version will too.  |
Posted: Mon Jul 27, 2009 6:31 am |
If you are using Brownout you likely need to change the BOR level setting. _________________ Google and Forum Search are some of your best tools!!!! |
magestik
Posted: Mon Jul 27, 2009 6:46 am |
It's written on page 8 (1.3) of the datasheet.
"F" accomodate an operating VDD range of 4.2V to 5.5V.
"LF" function over an extended VDD range of 2.0V to 5.5V.
There are frequency restrictions, see figure (28-1) on page 358. |
Posted: Mon Jul 27, 2009 8:27 am |
On most chips, the 'LF', is identical to the standard version, except with a warranted extended voltage range. Frequency limitations at the lower end, but otherwise identical.
There are a few recent chips though, where actual operational differences exist. Commonly with the ADC.
The data sheet is your friend.
The 2580, doesn't have such a problem.
kaps123
Posted: Mon Jul 27, 2009 8:54 pm |
Thank You so much .... |
