dc_eng
Posted: Thu Jul 23, 2009 6:31 am |
Here is what happened.
I move the KILLBILL variable to bottom of declarations... works.
Than I move back the KILLBILL variable to middle.... NOT to working.
Than I move KILLBILL variable to top of my declarations... works.
Than I increase KILLBILL variable to array of 50... NOT working.
Than I move increased number of KILLBILLs to bottom... NOT working.
the sym file below NOT working
000 @SCRATCH
001 @SCRATCH
001 _RETURN_
002 @SCRATCH
003 @SCRATCH
004 @SCRATCH
005-006 strtok.save
007-00A _Randseed
00B STEP_DELAY_MOTOR_UP
00C STEP_DELAY_MOTOR_DOWN
00D HOLD_TIME_MOTOR_UP
00E HOLD_TIME_MOTOR_DOWN
00F CENTER_POINT_OF_MOTOR_UP
010 CENTER_POINT_OF_MOTOR_DOWN
011 VIB_TO_CUP_UP_DELAY
012 CUP_UP_TO_CUP_DOWN_DELAY
013 CUP_DOWN_TO_MAIN_DOOR_DELAY
014 AD_SETTLING_TIME
015 CHANNEL_ID
016 SLOW_DISCHARGE_ANGLE
017-034 VIB_INTENSITY
035-052 VIB_DURATION
053 STEP_DELAY_MOTOR_MAIN_A
054 STEP_DELAY_MOTOR_MAIN_B
055 STEP_DELAY_MOTOR_MAIN_C
056 STEP_DELAY_MOTOR_MAIN_D
057 HOLD_TIME_MOTOR_MAIN_D
058-059 AD_COEFF
05A PROGRAM_ID
05B-05C PID_OFFSET
05D STEP_CNTUP
05E STEP_CNTDW
05F VIB_CNT
060 PHASE_UP
061 PHASE_DW
062 PHASE_VIB
063 STEP_OUTPUT
064-065 DELAY_TICKS_UP
066-067 DELAY_TICKS_DOWN
068-069 DELAY_TICKS_VIB
06A-06B DELAY_TICKS_AD
06C-06D TIMER0_CNT
06E-06F TARGET_TIMER
070-071 TIMER0_IS
072-075 DATA485_
076 FUNC485_
077-07A CHID485_
07B-C31 MODBUS_PACKET
C32 AD_COM_REG
C33 AD_STATUS_REG
C34-C37 AD_DATA_REG
C38-C3B AD_DATA_REGT
C3C-C3F AD_MODE_REG
C40-C43 AD_CONF_REG
C44-C47 AD_FILTER_REG
C48 AD_DAC_REG
C49-C4C AD_OFFSET_REG
C4D-C50 AD_GAIN_REG
C51-C54 AD_TEST_REG
C55-C58 AD_DATA_REGZERO
C59-C5C AD_DATA_REGAV
C5D-C66 U_DATA
C67-C75 P_NAME
C76.0 RCV_TOGGLE
C76.1 COMMUNICATION_TYPE
C76.2 SEQUENTIAL_DISCHARGE
C76.3 AVERAGE_CONTROL
C76.4 ON_START_BOTH_UP_DOWN
C76.5 AUTOMATIC_VIBRATOR_INTENSITY
C76.6 DISCHARGE_OF_MAIN_DOOR
C76.7 FEEDING_MACHINE
C77 CNT1
C78 SOFTWARE_VERSION
C79-C7C GENERAL_PARAMETERS
C7D NUMBER_OF_DEFFERENT_PRODUCTS
C7E DISCHARGE_PER_PACKAGE
C7F.0 HOLD_MAIN_DOOR_ON_MULTIPLE_DISCHARGE
C80 NUMBER_OF_CHANNELS
C81 REJECT_SIGNAL
C82 MAIN_DOOR
C83-C84 TARGET_WEIGHT
C85-C86 UPPER_LIMIT
C87-C88 LOWER_LIMIT
C89-C8A C1TARGET_WEIGHT
C8B-C8C C2TARGET_WEIGHT
C8D-C8E C3TARGET_WEIGHT
C8F-C90 C4TARGET_WEIGHT
C91 C1MAX_DEVIATION
C92 C2MAX_DEVIATION
C93 C3MAX_DEVIATION
C94 C4MAX_DEVIATION
C95-C98 DISABLED_CHANNELS
C99 SEQUENTIAL_DISCHARGE_DELAY
C9A REMOVE_TARE_PERIOD
C9B DISCHARGE_NUMBER_UP_TO_TARE
C9C NOT_IN_COMBINATION_LIMIT
C9D FILLING_PERCENTAGE
C9E-CA1 DATA485
CA2 FUNC485
CA3-CA6 CHID485
CA7-CA8 KILLBILL
CA9-CAA KILLBILL1
CAB-CAC KILLBILL2
CAD-CAE KILLBILL3
CAF-CB0 KILLBILL4
CB1-CB2 KILLBILL5
CB3-CB4 KILLBILL6
CB5-D18 KILLBILL7
D19-D1A CONT_.CNT16
D19 MAIN.@SCRATCH1
D1A MAIN.@SCRATCH2
D1B-D1E WRITE_AD_OFFSET_REG.AD_OFFSET_REG_
D1B-D1C atoi.s
D1B FEED_PRODUCT_FROM_CUP_UP.temp
D1B-D1E WRITE_AD_GAIN_REG.AD_GAIN_REG_
D1B-D1E ADJUST_GENERAL_PARAMETERS.GENERAL_PARAMETERS_
D1B DISCHARGE_CHANNEL.temp
D1B REFRESH_CHANNEL_IDS.CNT1
D1B-D1E ADJUST_TARGET_WEIGHT_C3C4.TWEIGHT_
D1B MAKE_CALIBRATION.CNT1
D1B-D1C atoi32.s
D1B TEST_VIBRATOR.CNT1
D1B GET_READY_FOR_START.CNT1
D1B-D1E ADJUST_MAX_DEVIATION.MAX_DEVIATION_
D1B-D1E ADJUST_TARGET_WEIGHT_C1C2.TWEIGHT_
D1B @GETCH_1_.@SCRATCH1
D1B FUNCTION_DECODE.@SCRATCH1
D1B SEND_CHANNEL_ID.@SCRATCH1
D1B GET_GR.@SCRATCH1
D1B CONT_.@SCRATCH1
D1B MAIN.@SCRATCH3
D1C ADJUST_SEQUENTIAL_DISCHARGE_DELAY.SEQUENTIAL_DISCHARGE_DELAY_
D1C SAVE_PROGRAM.PROGRAM_ID_
D1C ADJUST_STEP_DELAY_MOTOR_MAIN_D.STEP_DELAY_MOTOR_MAIN_D_
D1C ADJUST_STEP_DELAY_MOTOR_MAIN_C.STEP_DELAY_MOTOR_MAIN_C_
D1C ADJUST_CHANNEL_DISABLE.CHANNEL_DISABLE_
D1C-D1D WRITE_AD_MODE_REG.AD_MODE_REG_
D1C TEST_MOTOR_UP.CNT1
D1C ADJUST_STEP_DELAY_MOTOR_MAIN_A.STEP_DELAY_MOTOR_MAIN_A_
D1C ADJUST_STEP_DELAY_MOTOR_DOWN.STEP_DELAY_MOTOR_DOWN_
D1C ADJUST_HOLD_TIME_MOTOR_UP.HOLD_TIME_MOTOR_UP_
D1C-D1F ADJUST_MAX_DEVIATION_C1C2C3C4.DEVIATION_C1C2C3C4_
D1C DELETE_PROGRAM.PROGRAM_ID_
D1C TEST_MOTOR_DOWN.CNT1
D1C READ_DAC_REG.CNT1
D1C REMOVE_TARE.CNT1
D1C ADJUST_VIB_TO_CUP_UP_DELAY.VIB_TO_CUP_UP_DELAY_
D1C ADJUST_VIBRATOR_DURATION.VIB_DURATION_
D1C SET_PROGRAM.PROGRAM_ID_
D1C ADJUST_NOT_IN_COMBINATION_LIMIT.NOT_IN_COMBINATION_LIMIT_
D1C ADJUST_STEP_DELAY_MOTOR_MAIN_B.STEP_DELAY_MOTOR_MAIN_B_
D1C ADJUST_FILLING_PERCENTAGE.FILLING_PERCENTAGE_
D1C READ_OFFSET_REG.CNT1
D1C REFRESH_CHANNEL_IDS.CNT2
D1C READ_GAIN_REG.CNT1
D1C ADJUST_CENTER_POINT_OF_MOTOR_UP.CENTER_POINT_OF_MOTOR_UP_
D1C ADJUST_CENTER_POINT_OF_MOTOR_DOWN.CENTER_POINT_OF_MOTOR_DOWN_
D1C ADJUST_AD_SETTLING_TIME.AD_SETTLING_TIME_
D1C ADJUST_CUP_DOWN_TO_MAIN_DOOR_DELAY.CUP_DOWN_TO_MAIN_DOOR_DELAY
D1C ADJUST_STEP_DELAY_MOTOR_UP.STEP_DELAY_MOTOR_UP_
D1C ADJUST_HOLD_TIME_MOTOR_MAIN_D.HOLD_TIME_MOTOR_MAIN_D_
D1C-D1D @DIV1616.P1
D1C ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.CUP_UP_TO_CUP_DOWN_DELAY_
D1C-D1F WRITE_AD_FILTER_REG.AD_FILTER_REG_
D1C ADJUST_VIBRATOR_INTENSITY.VIB_INTENSITY_
D1C ADJUST_SLOW_DISCHARGE_ANGLE.SLOW_DISCHARGE_ANGLE_
D1C ADJUST_HOLD_TIME_MOTOR_DOWN.HOLD_TIME_MOTOR_DOWN_
D1C GET_AD.CNT1
D1C WRITE_AD_DAC_REG.AD_DAC_REG_
D1C ADJUST_REMOVE_TARE_PERIOD.REMOVE_TARE_PERIOD_
D1C FUNCTION_DECODE.@SCRATCH2
D1C GET_READY_FOR_START.@SCRATCH1
D1C DISCHARGE_CHANNEL.@SCRATCH1
D1C FEED_PRODUCT_FROM_CUP_UP.@SCRATCH1
D1C TEST_VIBRATOR.@SCRATCH1
D1C MAKE_CALIBRATION.@SCRATCH1
D1C GET_GR.@SCRATCH2
D1C MAIN.@SCRATCH4
D1D STORE_DATAS.CNT1
D1D @PRINTF_X_56.P1
D1D READ_DATA_REG.CNT1
D1D WRITE_AD_DAC_REG.CNT1
D1D-D20 atoi32.result
D1D atoi.result
D1D REFRESH_CHANNEL_IDS.CNT3
D1D RESTORE_DATAS.CNT1
D1D READ_OFFSET_REG.@SCRATCH1
D1D READ_GAIN_REG.@SCRATCH1
D1D FUNCTION_DECODE.@SCRATCH3
D1D DISCHARGE_CHANNEL.@SCRATCH2
D1D FEED_PRODUCT_FROM_CUP_UP.@SCRATCH2
D1D ADJUST_CHANNEL_DISABLE.@SCRATCH1
D1D ADJUST_SEQUENTIAL_DISCHARGE_DELAY.@SCRATCH1
D1D ADJUST_REMOVE_TARE_PERIOD.@SCRATCH1
D1D ADJUST_FILLING_PERCENTAGE.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_UP.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_DOWN.@SCRATCH1
D1D ADJUST_HOLD_TIME_MOTOR_UP.@SCRATCH1
D1D ADJUST_HOLD_TIME_MOTOR_DOWN.@SCRATCH1
D1D ADJUST_CENTER_POINT_OF_MOTOR_UP.@SCRATCH1
D1D ADJUST_CENTER_POINT_OF_MOTOR_DOWN.@SCRATCH1
D1D ADJUST_VIB_TO_CUP_UP_DELAY.@SCRATCH1
D1D ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.@SCRATCH1
D1D ADJUST_AD_SETTLING_TIME.@SCRATCH1
D1D ADJUST_SLOW_DISCHARGE_ANGLE.@SCRATCH1
D1D ADJUST_VIBRATOR_INTENSITY.@SCRATCH1
D1D ADJUST_VIBRATOR_DURATION.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_MAIN_A.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_MAIN_B.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_MAIN_C.@SCRATCH1
D1D ADJUST_STEP_DELAY_MOTOR_MAIN_D.@SCRATCH1
D1D ADJUST_HOLD_TIME_MOTOR_MAIN_D.@SCRATCH1
D1D TEST_MOTOR_UP.@SCRATCH1
D1D TEST_MOTOR_DOWN.@SCRATCH1
D1D TEST_VIBRATOR.@SCRATCH2
D1D REMOVE_TARE.@SCRATCH1
D1D MAKE_CALIBRATION.@SCRATCH2
D1D GET_AD.@SCRATCH1
D1D GET_GR.@SCRATCH3
D1D SET_PROGRAM.@SCRATCH1
D1D SAVE_PROGRAM.@SCRATCH1
D1D MAIN.@SCRATCH5
D1E @PRINTF_X_56.P1
D1E WRITE_AD_MODE_REG.CNT1
D1E atoi.sign
D1E SEND_RS485.CNT1
D1E-D1F @DIV1616.P1
D1E RECV_RS485.CNT1
D1E RESTORE_DATAS.TEMP1
D1E READ_DATA_REG.@SCRATCH1
D1E STORE_DATAS.@SCRATCH1
D1E FUNCTION_DECODE.@SCRATCH4
D1E DISCHARGE_CHANNEL.@SCRATCH3
D1E FEED_PRODUCT_FROM_CUP_UP.@SCRATCH3
D1E REFRESH_CHANNEL_IDS.@SCRATCH1
D1E ADJUST_SEQUENTIAL_DISCHARGE_DELAY.@SCRATCH2
D1E ADJUST_REMOVE_TARE_PERIOD.@SCRATCH2
D1E ADJUST_FILLING_PERCENTAGE.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_UP.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_DOWN.@SCRATCH2
D1E ADJUST_HOLD_TIME_MOTOR_UP.@SCRATCH2
D1E ADJUST_HOLD_TIME_MOTOR_DOWN.@SCRATCH2
D1E ADJUST_CENTER_POINT_OF_MOTOR_UP.@SCRATCH2
D1E ADJUST_CENTER_POINT_OF_MOTOR_DOWN.@SCRATCH2
D1E ADJUST_VIB_TO_CUP_UP_DELAY.@SCRATCH2
D1E ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.@SCRATCH2
D1E ADJUST_AD_SETTLING_TIME.@SCRATCH2
D1E ADJUST_SLOW_DISCHARGE_ANGLE.@SCRATCH2
D1E ADJUST_VIBRATOR_INTENSITY.@SCRATCH2
D1E ADJUST_VIBRATOR_DURATION.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_MAIN_A.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_MAIN_B.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_MAIN_C.@SCRATCH2
D1E ADJUST_STEP_DELAY_MOTOR_MAIN_D.@SCRATCH2
D1E ADJUST_HOLD_TIME_MOTOR_MAIN_D.@SCRATCH2
D1E TEST_MOTOR_UP.@SCRATCH2
D1E TEST_MOTOR_DOWN.@SCRATCH2
D1E TEST_VIBRATOR.@SCRATCH3
D1E MAKE_CALIBRATION.@SCRATCH3
D1E GET_AD.@SCRATCH2
D1E GET_GR.@SCRATCH4
D1E SAVE_PROGRAM.@SCRATCH2
D1F-D20 ADJUST_MAX_DEVIATION.TEMP1
D1F WRITE_AD_GAIN_REG.CNT1
D1F @delay_ms1.P1
D1F RESTORE_DATAS.TEMP2
D1F atoi.base
D1F WRITE_AD_OFFSET_REG.CNT1
D1F @PRINTF_U_56.P1
D1F-D20 @MUL1616.P2
D1F-D20 ADJUST_TARGET_WEIGHT.TARGET_WEIGHT_
D1F STORE_DATAS.@SCRATCH2
D1F SEND_RS485.@SCRATCH1
D1F RECV_RS485.@SCRATCH1
D1F DISCHARGE_CHANNEL.@SCRATCH4
D1F FEED_PRODUCT_FROM_CUP_UP.@SCRATCH4
D1F ADJUST_GENERAL_PARAMETERS.@SCRATCH1
D1F ADJUST_VIBRATOR_INTENSITY.@SCRATCH3
D1F ADJUST_VIBRATOR_DURATION.@SCRATCH3
D1F TEST_MOTOR_UP.@SCRATCH3
D1F TEST_MOTOR_DOWN.@SCRATCH3
D1F MAKE_CALIBRATION.@SCRATCH4
D1F GET_AD.@SCRATCH3
D20 atoi.index
D20 RESTORE_DATAS.TEMP3
D20 @PRINTF_U_56.P1
D20 WRITE_AD_FILTER_REG.CNT1
D20 @DIV1616.@SCRATCH1
D20 WRITE_AD_OFFSET_REG.@SCRATCH1
D20 WRITE_AD_GAIN_REG.@SCRATCH1
D20 STORE_DATAS.@SCRATCH3
D20 SEND_RS485.@SCRATCH2
D20 ADJUST_GENERAL_PARAMETERS.@SCRATCH2
D20 ADJUST_VIBRATOR_INTENSITY.@SCRATCH4
D20 ADJUST_VIBRATOR_DURATION.@SCRATCH4
D20 TEST_MOTOR_UP.@SCRATCH4
D20 TEST_MOTOR_DOWN.@SCRATCH4
D20 GET_AD.@SCRATCH4
D21 WRITE_AD_COM_REG.AD_COM_REG_
D21 @delay_us1.P1
D21-D22 ADJUST_MAX_DEVIATION.TEMP2
D21 atoi.c
D21 @DIV88.P1
D21 atoi32.sign
D21-D22 @MUL1616.P1
D21 RESTORE_DATAS.TEMP4
D21 WRITE_AD_FILTER_REG.@SCRATCH1
D21 STORE_DATAS.@SCRATCH4
D21 ADJUST_GENERAL_PARAMETERS.@SCRATCH3
D21 ADJUST_TARGET_WEIGHT.@SCRATCH1
D21 ADJUST_VIBRATOR_INTENSITY.@SCRATCH5
D21 ADJUST_VIBRATOR_DURATION.@SCRATCH5
D21 GET_AD.@SCRATCH5
D22 atoi32.base
D22 @DIV88.P1
D22-D25 @PRINTF_L32U_56.P2
D22 WRITE_AD_COM_REG.CNT1
D22 @MUL88.P1
D22 atoi.@SCRATCH1
D22 STORE_DATAS.@SCRATCH5
D22 RESTORE_DATAS.@SCRATCH1
D22 ADJUST_GENERAL_PARAMETERS.@SCRATCH4
D22 ADJUST_TARGET_WEIGHT.@SCRATCH2
D23 @MUL88.P1
D23 atoi32.index
D23 @MUL1616.@SCRATCH1
D23 atoi.@SCRATCH2
D23 RESTORE_DATAS.@SCRATCH2
D23 @DIV88.@SCRATCH1
D23 ADJUST_TARGET_WEIGHT.@SCRATCH3
D23 ADJUST_MAX_DEVIATION.@SCRATCH1
D24-D25 @PRINTF_LU_56.P1
D24 atoi32.c
D24 RESTORE_DATAS.@SCRATCH3
D24 ADJUST_MAX_DEVIATION.@SCRATCH2
D25 atoi32.@SCRATCH1
D25 RESTORE_DATAS.@SCRATCH4
D25 ADJUST_MAX_DEVIATION.@SCRATCH3
D26 atoi32.@SCRATCH2
D26 @PRINTF_LU_56.@SCRATCH1
D26 RESTORE_DATAS.@SCRATCH5
D26 @PRINTF_L32U_56.@SCRATCH1
D27 atoi32.@SCRATCH3
D27 @PRINTF_LU_56.@SCRATCH2
D27 RESTORE_DATAS.@SCRATCH6
D27 @PRINTF_L32U_56.@SCRATCH2
D28 atoi32.@SCRATCH4
D28 @PRINTF_LU_56.@SCRATCH3
D28 RESTORE_DATAS.@SCRATCH7
D28 @PRINTF_L32U_56.@SCRATCH3
D29 atoi32.@SCRATCH5
D29 @PRINTF_LU_56.@SCRATCH4
D29 @PRINTF_L32U_56.@SCRATCH4
D2A atoi32.@SCRATCH6
D2A @PRINTF_LU_56.@SCRATCH5
D2A @PRINTF_L32U_56.@SCRATCH5
D2B @PRINTF_LU_56.@SCRATCH6
D2B @PRINTF_L32U_56.@SCRATCH6
D2C @PRINTF_LU_56.@SCRATCH7
D2C @PRINTF_L32U_56.@SCRATCH7
D2D @PRINTF_L32U_56.@SCRATCH8
D2E @PUTCHAR_1_.P1
D2E-D31 @DIV3232.P2
D32-D35 @DIV3232.P1
D36 @DIV3232.@SCRATCH1
D37 @DIV3232.@SCRATCH2
D38 @DIV3232.@SCRATCH3
D39 @DIV3232.@SCRATCH4
D3A @DIV3232.@SCRATCH5
F83 PSP_DATA
FB4.6 C1OUT
FB4.7 C2OUT
FBB-FBC CCP_2
FBB CCP_2_LOW
FBC CCP_2_HIGH
FBE CCP_1_LOW
FBE-FBF CCP_1
FBF CCP_1_HIGH
FE9-FEA @READ_PROGRAM_MEMORY.P1
FE9-FEA @WRITE_PROGRAM_MEMORY.P2
FF6-FF8 @WRITE_PROGRAM_MEMORY.P1
FF6-FF8 @READ_PROGRAM_MEMORY.P2
ROM Allocation:
20BC @delay_ms1
29E2 @delay_us1
12CA @PUTCHAR_1_
237A @GETCH_1_
2666 @MUL88
12A8 @MUL1616
26B6 atoi
23C6 atoi32
3190 @DIV1616
2170 WRITE_AD_COM_REG
22D6 WRITE_AD_MODE_REG
21E2 WRITE_AD_FILTER_REG
21A4 WRITE_AD_DAC_REG
2284 WRITE_AD_OFFSET_REG
2232 WRITE_AD_GAIN_REG
5796 READ_DAC_REG
2AF2 READ_DATA_REG
5666 READ_OFFSET_REG
56FE READ_GAIN_REG
13CA STORE_DATAS
0004 @const554
130E @PRINTF_LU_56
0736 RESTORE_DATAS
20E4 INIT_MOTOR_UP
212A INIT_MOTOR_DOWN
2DB4 NEXT_STEP_UP
2E10 @goto11830
2964 NEXT_STEP_DW
29C0 @goto11843
2FFE VIBRATOR_PULSE
231C INIT_LOADCELL
285A SEND_RS485
3E52 RECV_RS485
2B8A @DIV3232
2C0A @PRINTF_L32U_56
3DA4 @DIV88
3DD0 @PRINTF_U_56
6356 FUNCTION_DECODE
2F22 GET_READY_FOR_START
31D6 DISCHARGE_CHANNEL
39A2 FEED_PRODUCT_FROM_CUP_UP
4050 REFRESH_CHANNEL_IDS
416C SEND_CHANNEL_ID
41E0 ADJUST_TARGET_WEIGHT_C1C2
41E4 ADJUST_TARGET_WEIGHT_C3C4
41E8 ADJUST_GENERAL_PARAMETERS
0022 @const595
4434 ADJUST_TARGET_WEIGHT
004E @const596
4520 ADJUST_MAX_DEVIATION
0074 @const599
0092 @const600
470A ADJUST_CHANNEL_DISABLE
00B0 @const601
48CA ADJUST_SEQUENTIAL_DISCHARGE_DELAY
00D8 @const602
4964 ADJUST_REMOVE_TARE_PERIOD
010A @const603
4A04 ADJUST_NOT_IN_COMBINATION_LIMIT
4A08 ADJUST_FILLING_PERCENTAGE
0134 @const604
4AA2 ADJUST_STEP_DELAY_MOTOR_UP
015E @const605
4B42 ADJUST_STEP_DELAY_MOTOR_DOWN
018A @const606
4BE2 ADJUST_HOLD_TIME_MOTOR_UP
01B8 @const607
4C7C ADJUST_HOLD_TIME_MOTOR_DOWN
01E2 @const608
4D16 ADJUST_CENTER_POINT_OF_MOTOR_UP
020E @const609
4DB6 ADJUST_CENTER_POINT_OF_MOTOR_DOWN
023E @const610
4E56 ADJUST_VIB_TO_CUP_UP_DELAY
0270 @const611
4EF6 ADJUST_CUP_UP_TO_CUP_DOWN_DELAY
029C @const612
4F96 ADJUST_CUP_DOWN_TO_MAIN_DOOR_DELAY
4F9A ADJUST_AD_SETTLING_TIME
02CC @const613
503A ADJUST_MAX_DEVIATION_C1C2C3C4
503E ADJUST_SLOW_DISCHARGE_ANGLE
02F4 @const614
50DE ADJUST_VIBRATOR_INTENSITY
0320 @const615
51BE ADJUST_VIBRATOR_DURATION
034A @const616
5298 ADJUST_STEP_DELAY_MOTOR_MAIN_A
0374 @const617
5338 ADJUST_STEP_DELAY_MOTOR_MAIN_B
03A4 @const618
53D8 ADJUST_STEP_DELAY_MOTOR_MAIN_C
03D4 @const619
5478 ADJUST_STEP_DELAY_MOTOR_MAIN_D
0404 @const620
5512 ADJUST_HOLD_TIME_MOTOR_MAIN_D
0434 @const624
2E32 TEST_MOTOR_UP
2A02 TEST_MOTOR_DOWN
55AC TEST_VIBRATOR
2CCE REMOVE_TARE
0462 @const629
0490 @const630
5840 MAKE_CALIBRATION
04B6 @const632
04E8 @const633
0518 @const634
57F6 @PRINTF_X_56
0542 @const638
056C @const639
0596 @const641
05C8 @const648
05E4 @const650
0602 @const652
304C GET_AD
0622 @const654
617C GET_GR
6272 SET_PROGRAM
063E @const656
6322 SAVE_PROGRAM
6352 DELETE_PROGRAM
6696 CONT_
0666 @const670
068A @const672
06AE @const674
06D2 @const676
06EA @const677
0706 @const678
0720 @const680
6946 MAIN
6946 @cinit
0136 StrtoulGO
0136 StrtolGO
Project Directory:
D:\P_FILES\PROJECTS\MARMAK\MARMAK_WBLOCK\Software\
Project Files:
MW_71.c
MW_71.h
C:\Program Files\PICC\devices\18F4620.h
C:\Program Files\PICC\drivers\string.h
C:\Program Files\PICC\drivers\stddef.h
C:\Program Files\PICC\drivers\ctype.h
C:\Program Files\PICC\drivers\stdlib.h
Units:
D:\P_FILES\PROJECTS\MARMAK\MARMAK_WBLOCK\Software\MW_71.c (main)
Compiler Settings:
Processor: PIC18F4620
Pointer Size: 16
ADC Range: 0-255
Opt Level: 9
Short,Int,Long: UNSIGNED: 1,8,16
Float,Double: 32,32
Output Files:
Errors: MW_71.err
Ext Symbols: MW_71.esym
INHX32: MW_71.hex
Symbols: MW_71.sym
List: MW_71.lst
Debug/COFF: MW_71.cof
Project: MW_71.PJT
Call Tree: MW_71.tre
Statistics: MW_71.sta
the sym below working
000 @SCRATCH
001 @SCRATCH
001 _RETURN_
002 @SCRATCH
003 @SCRATCH
004 @SCRATCH
005-006 strtok.save
007-00A _Randseed
015 CHANNEL_ID
058-059 AD_COEFF
05A PROGRAM_ID
05B-05C PID_OFFSET
05D STEP_CNTUP
05E STEP_CNTDW
05F VIB_CNT
060 PHASE_UP
061 PHASE_DW
062 PHASE_VIB
063 STEP_OUTPUT
06C-06D TIMER0_CNT
070-071 TIMER0_IS
072-075 DATA485_
076 FUNC485_
077-07A CHID485_
C32 AD_COM_REG
C33 AD_STATUS_REG
C34-C37 AD_DATA_REG
C3C-C3F AD_MODE_REG
C40-C43 AD_CONF_REG
C48 AD_DAC_REG
C4D-C50 AD_GAIN_REG
C51-C54 AD_TEST_REG
C5D-C66 U_DATA
C67-C75 P_NAME
C76.0 RCV_TOGGLE
C77 CNT1
C81 REJECT_SIGNAL
C82 MAIN_DOOR
C85-C86 UPPER_LIMIT
C87-C88 LOWER_LIMIT
C91 C1MAX_DEVIATION
C92 C2MAX_DEVIATION
C93 C3MAX_DEVIATION
C94 C4MAX_DEVIATION
C9E-CA1 DATA485
CA2 FUNC485
CA3-CA6 CHID485
CA7-CA8 CONT_.CNT16
CA7 MAIN.@SCRATCH1
CA8 MAIN.@SCRATCH2
CA9-CAC ADJUST_TARGET_WEIGHT_C1C2.TWEIGHT_
CA9-CAC WRITE_AD_GAIN_REG.AD_GAIN_REG_
CA9-CAC ADJUST_MAX_DEVIATION.MAX_DEVIATION_
CA9-CAA atoi.s
CA9-CAA atoi32.s
CA9-CAC WRITE_AD_OFFSET_REG.AD_OFFSET_REG_
CA9 MAKE_CALIBRATION.CNT1
CA9 DISCHARGE_CHANNEL.temp
CA9 TEST_VIBRATOR.CNT1
CA9-CAC ADJUST_TARGET_WEIGHT_C3C4.TWEIGHT_
CA9 FEED_PRODUCT_FROM_CUP_UP.temp
CA9 GET_READY_FOR_START.CNT1
CA9-CAC ADJUST_GENERAL_PARAMETERS.GENERAL_PARAMETERS_
CA9 REFRESH_CHANNEL_IDS.CNT1
CA9 @GETCH_1_.@SCRATCH1
CA9 FUNCTION_DECODE.@SCRATCH1
CA9 SEND_CHANNEL_ID.@SCRATCH1
CA9 GET_GR.@SCRATCH1
CA9 CONT_.@SCRATCH1
CA9 MAIN.@SCRATCH3
CAA READ_GAIN_REG.CNT1
CAA TEST_MOTOR_DOWN.CNT1
CAA SAVE_PROGRAM.PROGRAM_ID_
CAA ADJUST_REMOVE_TARE_PERIOD.REMOVE_TARE_PERIOD_
CAA READ_DAC_REG.CNT1
CAA ADJUST_CENTER_POINT_OF_MOTOR_DOWN.CENTER_POINT_OF_MOTOR_DOWN_
CAA ADJUST_AD_SETTLING_TIME.AD_SETTLING_TIME_
CAA-CAD ADJUST_MAX_DEVIATION_C1C2C3C4.DEVIATION_C1C2C3C4_
CAA-CAB @DIV1616.P1
CAA ADJUST_VIB_TO_CUP_UP_DELAY.VIB_TO_CUP_UP_DELAY_
CAA ADJUST_HOLD_TIME_MOTOR_DOWN.HOLD_TIME_MOTOR_DOWN_
CAA REMOVE_TARE.CNT1
CAA ADJUST_SLOW_DISCHARGE_ANGLE.SLOW_DISCHARGE_ANGLE_
CAA ADJUST_CHANNEL_DISABLE.CHANNEL_DISABLE_
CAA ADJUST_STEP_DELAY_MOTOR_UP.STEP_DELAY_MOTOR_UP_
CAA ADJUST_STEP_DELAY_MOTOR_MAIN_D.STEP_DELAY_MOTOR_MAIN_D_
CAA ADJUST_STEP_DELAY_MOTOR_DOWN.STEP_DELAY_MOTOR_DOWN_
CAA ADJUST_SEQUENTIAL_DISCHARGE_DELAY.SEQUENTIAL_DISCHARGE_DELAY_
CAA ADJUST_STEP_DELAY_MOTOR_MAIN_B.STEP_DELAY_MOTOR_MAIN_B_
CAA ADJUST_STEP_DELAY_MOTOR_MAIN_C.STEP_DELAY_MOTOR_MAIN_C_
CAA ADJUST_HOLD_TIME_MOTOR_UP.HOLD_TIME_MOTOR_UP_
CAA ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.CUP_UP_TO_CUP_DOWN_DELAY_
CAA DELETE_PROGRAM.PROGRAM_ID_
CAA ADJUST_FILLING_PERCENTAGE.FILLING_PERCENTAGE_
CAA GET_AD.CNT1
CAA REFRESH_CHANNEL_IDS.CNT2
CAA SET_PROGRAM.PROGRAM_ID_
CAA ADJUST_HOLD_TIME_MOTOR_MAIN_D.HOLD_TIME_MOTOR_MAIN_D_
CAA TEST_MOTOR_UP.CNT1
CAA ADJUST_CENTER_POINT_OF_MOTOR_UP.CENTER_POINT_OF_MOTOR_UP_
CAA WRITE_AD_DAC_REG.AD_DAC_REG_
CAA ADJUST_STEP_DELAY_MOTOR_MAIN_A.STEP_DELAY_MOTOR_MAIN_A_
CAA READ_OFFSET_REG.CNT1
CAA-CAB WRITE_AD_MODE_REG.AD_MODE_REG_
CAA ADJUST_VIBRATOR_INTENSITY.VIB_INTENSITY_
CAA ADJUST_CUP_DOWN_TO_MAIN_DOOR_DELAY.CUP_DOWN_TO_MAIN_DOOR_DELAY
CAA ADJUST_NOT_IN_COMBINATION_LIMIT.NOT_IN_COMBINATION_LIMIT_
CAA ADJUST_VIBRATOR_DURATION.VIB_DURATION_
CAA-CAD WRITE_AD_FILTER_REG.AD_FILTER_REG_
CAA FUNCTION_DECODE.@SCRATCH2
CAA GET_READY_FOR_START.@SCRATCH1
CAA DISCHARGE_CHANNEL.@SCRATCH1
CAA FEED_PRODUCT_FROM_CUP_UP.@SCRATCH1
CAA TEST_VIBRATOR.@SCRATCH1
CAA MAKE_CALIBRATION.@SCRATCH1
CAA GET_GR.@SCRATCH2
CAA MAIN.@SCRATCH4
CAB atoi.result
CAB @PRINTF_X_56.P1
CAB READ_DATA_REG.CNT1
CAB REFRESH_CHANNEL_IDS.CNT3
CAB RESTORE_DATAS.CNT1
CAB WRITE_AD_DAC_REG.CNT1
CAB STORE_DATAS.CNT1
CAB-CAE atoi32.result
CAB READ_OFFSET_REG.@SCRATCH1
CAB READ_GAIN_REG.@SCRATCH1
CAB FUNCTION_DECODE.@SCRATCH3
CAB DISCHARGE_CHANNEL.@SCRATCH2
CAB FEED_PRODUCT_FROM_CUP_UP.@SCRATCH2
CAB ADJUST_CHANNEL_DISABLE.@SCRATCH1
CAB ADJUST_SEQUENTIAL_DISCHARGE_DELAY.@SCRATCH1
CAB ADJUST_REMOVE_TARE_PERIOD.@SCRATCH1
CAB ADJUST_FILLING_PERCENTAGE.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_UP.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_DOWN.@SCRATCH1
CAB ADJUST_HOLD_TIME_MOTOR_UP.@SCRATCH1
CAB ADJUST_HOLD_TIME_MOTOR_DOWN.@SCRATCH1
CAB ADJUST_CENTER_POINT_OF_MOTOR_UP.@SCRATCH1
CAB ADJUST_CENTER_POINT_OF_MOTOR_DOWN.@SCRATCH1
CAB ADJUST_VIB_TO_CUP_UP_DELAY.@SCRATCH1
CAB ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.@SCRATCH1
CAB ADJUST_AD_SETTLING_TIME.@SCRATCH1
CAB ADJUST_SLOW_DISCHARGE_ANGLE.@SCRATCH1
CAB ADJUST_VIBRATOR_INTENSITY.@SCRATCH1
CAB ADJUST_VIBRATOR_DURATION.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_MAIN_A.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_MAIN_B.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_MAIN_C.@SCRATCH1
CAB ADJUST_STEP_DELAY_MOTOR_MAIN_D.@SCRATCH1
CAB ADJUST_HOLD_TIME_MOTOR_MAIN_D.@SCRATCH1
CAB TEST_MOTOR_UP.@SCRATCH1
CAB TEST_MOTOR_DOWN.@SCRATCH1
CAB TEST_VIBRATOR.@SCRATCH2
CAB REMOVE_TARE.@SCRATCH1
CAB MAKE_CALIBRATION.@SCRATCH2
CAB GET_AD.@SCRATCH1
CAB GET_GR.@SCRATCH3
CAB SET_PROGRAM.@SCRATCH1
CAB SAVE_PROGRAM.@SCRATCH1
CAB MAIN.@SCRATCH5
CAC atoi.sign
CAC @PRINTF_X_56.P1
CAC RESTORE_DATAS.TEMP1
CAC RECV_RS485.CNT1
CAC-CAD @DIV1616.P1
CAC WRITE_AD_MODE_REG.CNT1
CAC SEND_RS485.CNT1
CAC READ_DATA_REG.@SCRATCH1
CAC STORE_DATAS.@SCRATCH1
CAC FUNCTION_DECODE.@SCRATCH4
CAC DISCHARGE_CHANNEL.@SCRATCH3
CAC FEED_PRODUCT_FROM_CUP_UP.@SCRATCH3
CAC REFRESH_CHANNEL_IDS.@SCRATCH1
CAC ADJUST_SEQUENTIAL_DISCHARGE_DELAY.@SCRATCH2
CAC ADJUST_REMOVE_TARE_PERIOD.@SCRATCH2
CAC ADJUST_FILLING_PERCENTAGE.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_UP.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_DOWN.@SCRATCH2
CAC ADJUST_HOLD_TIME_MOTOR_UP.@SCRATCH2
CAC ADJUST_HOLD_TIME_MOTOR_DOWN.@SCRATCH2
CAC ADJUST_CENTER_POINT_OF_MOTOR_UP.@SCRATCH2
CAC ADJUST_CENTER_POINT_OF_MOTOR_DOWN.@SCRATCH2
CAC ADJUST_VIB_TO_CUP_UP_DELAY.@SCRATCH2
CAC ADJUST_CUP_UP_TO_CUP_DOWN_DELAY.@SCRATCH2
CAC ADJUST_AD_SETTLING_TIME.@SCRATCH2
CAC ADJUST_SLOW_DISCHARGE_ANGLE.@SCRATCH2
CAC ADJUST_VIBRATOR_INTENSITY.@SCRATCH2
CAC ADJUST_VIBRATOR_DURATION.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_MAIN_A.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_MAIN_B.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_MAIN_C.@SCRATCH2
CAC ADJUST_STEP_DELAY_MOTOR_MAIN_D.@SCRATCH2
CAC ADJUST_HOLD_TIME_MOTOR_MAIN_D.@SCRATCH2
CAC TEST_MOTOR_UP.@SCRATCH2
CAC TEST_MOTOR_DOWN.@SCRATCH2
CAC TEST_VIBRATOR.@SCRATCH3
CAC MAKE_CALIBRATION.@SCRATCH3
CAC GET_AD.@SCRATCH2
CAC GET_GR.@SCRATCH4
CAC SAVE_PROGRAM.@SCRATCH2
CAD atoi.base
CAD-CAE ADJUST_TARGET_WEIGHT.TARGET_WEIGHT_
CAD @delay_ms1.P1
CAD WRITE_AD_OFFSET_REG.CNT1
CAD-CAE ADJUST_MAX_DEVIATION.TEMP1
CAD-CAE @MUL1616.P1
CAD WRITE_AD_GAIN_REG.CNT1
CAD @PRINTF_U_56.P1
CAD RESTORE_DATAS.TEMP2
CAD STORE_DATAS.@SCRATCH2
CAD SEND_RS485.@SCRATCH1
CAD RECV_RS485.@SCRATCH1
CAD DISCHARGE_CHANNEL.@SCRATCH4
CAD FEED_PRODUCT_FROM_CUP_UP.@SCRATCH4
CAD ADJUST_GENERAL_PARAMETERS.@SCRATCH1
CAD ADJUST_VIBRATOR_INTENSITY.@SCRATCH3
CAD ADJUST_VIBRATOR_DURATION.@SCRATCH3
CAD TEST_MOTOR_UP.@SCRATCH3
CAD TEST_MOTOR_DOWN.@SCRATCH3
CAD MAKE_CALIBRATION.@SCRATCH4
CAD GET_AD.@SCRATCH3
CAE RESTORE_DATAS.TEMP3
CAE atoi.index
CAE WRITE_AD_FILTER_REG.CNT1
CAE @PRINTF_U_56.P1
CAE @DIV1616.@SCRATCH1
CAE WRITE_AD_OFFSET_REG.@SCRATCH1
CAE WRITE_AD_GAIN_REG.@SCRATCH1
CAE STORE_DATAS.@SCRATCH3
CAE SEND_RS485.@SCRATCH2
CAE ADJUST_GENERAL_PARAMETERS.@SCRATCH2
CAE ADJUST_VIBRATOR_INTENSITY.@SCRATCH4
CAE ADJUST_VIBRATOR_DURATION.@SCRATCH4
CAE TEST_MOTOR_UP.@SCRATCH4
CAE TEST_MOTOR_DOWN.@SCRATCH4
CAE GET_AD.@SCRATCH4
CAF atoi.c
CAF @DIV88.P1
CAF WRITE_AD_COM_REG.AD_COM_REG_
CAF-CB0 ADJUST_MAX_DEVIATION.TEMP2
CAF RESTORE_DATAS.TEMP4
CAF-CB0 @MUL1616.P1
CAF atoi32.sign
CAF @delay_us1.P1
CAF WRITE_AD_FILTER_REG.@SCRATCH1
CAF STORE_DATAS.@SCRATCH4
CAF ADJUST_GENERAL_PARAMETERS.@SCRATCH3
CAF ADJUST_TARGET_WEIGHT.@SCRATCH1
CAF ADJUST_VIBRATOR_INTENSITY.@SCRATCH5
CAF ADJUST_VIBRATOR_DURATION.@SCRATCH5
CAF GET_AD.@SCRATCH5
CB0-CB3 @PRINTF_L32U_56.P1
CB0 @DIV88.P2
CB0 WRITE_AD_COM_REG.CNT1
CB0 atoi32.base
CB0 @MUL88.P1
CB0 atoi.@SCRATCH1
CB0 STORE_DATAS.@SCRATCH5
CB0 RESTORE_DATAS.@SCRATCH1
CB0 ADJUST_GENERAL_PARAMETERS.@SCRATCH4
CB0 ADJUST_TARGET_WEIGHT.@SCRATCH2
CB1 atoi32.index
CB1 @MUL88.P1
CB1 @MUL1616.@SCRATCH1
CB1 atoi.@SCRATCH2
CB1 RESTORE_DATAS.@SCRATCH2
CB1 @DIV88.@SCRATCH1
CB1 ADJUST_TARGET_WEIGHT.@SCRATCH3
CB1 ADJUST_MAX_DEVIATION.@SCRATCH1
CB2 atoi32.c
CB2-CB3 @PRINTF_LU_56.P1
CB2 RESTORE_DATAS.@SCRATCH3
CB2 ADJUST_MAX_DEVIATION.@SCRATCH2
CB3 atoi32.@SCRATCH1
CB3 RESTORE_DATAS.@SCRATCH4
CB3 ADJUST_MAX_DEVIATION.@SCRATCH3
CB4 atoi32.@SCRATCH2
CB4 @PRINTF_LU_56.@SCRATCH1
CB4 RESTORE_DATAS.@SCRATCH5
CB4 @PRINTF_L32U_56.@SCRATCH1
CB5 atoi32.@SCRATCH3
CB5 @PRINTF_LU_56.@SCRATCH2
CB5 RESTORE_DATAS.@SCRATCH6
CB5 @PRINTF_L32U_56.@SCRATCH2
CB6 atoi32.@SCRATCH4
CB6 @PRINTF_LU_56.@SCRATCH3
CB6 RESTORE_DATAS.@SCRATCH7
CB6 @PRINTF_L32U_56.@SCRATCH3
CB7 atoi32.@SCRATCH5
CB7 @PRINTF_LU_56.@SCRATCH4
CB7 @PRINTF_L32U_56.@SCRATCH4
CB8 atoi32.@SCRATCH6
CB8 @PRINTF_LU_56.@SCRATCH5
CB8 @PRINTF_L32U_56.@SCRATCH5
CB9 @PRINTF_LU_56.@SCRATCH6
CB9 @PRINTF_L32U_56.@SCRATCH6
CBA @PRINTF_LU_56.@SCRATCH7
CBA @PRINTF_L32U_56.@SCRATCH7
CBB @PRINTF_L32U_56.@SCRATCH8
CBC-CBF @DIV3232.P1
CBC @PUTCHAR_1_.P2
CC0-CC3 @DIV3232.P1
CC4 @DIV3232.@SCRATCH1
CC5 @DIV3232.@SCRATCH2
CC6 @DIV3232.@SCRATCH3
CC7 @DIV3232.@SCRATCH4
CC8 @DIV3232.@SCRATCH5
F83 PSP_DATA
FB4.6 C1OUT
FB4.7 C2OUT
FBB CCP_2_LOW
FBB-FBC CCP_2
FBC CCP_2_HIGH
FBE CCP_1_LOW
FBE-FBF CCP_1
FBF CCP_1_HIGH
FE9-FEA @WRITE_PROGRAM_MEMORY.P1
FE9-FEA @READ_PROGRAM_MEMORY.P2
FF6-FF8 @READ_PROGRAM_MEMORY.P1
FF6-FF8 @WRITE_PROGRAM_MEMORY.P2
ROM Allocation:
203A @delay_ms1
2960 @delay_us1
1274 @PUTCHAR_1_
22F8 @GETCH_1_
25E4 @MUL88
1252 @MUL1616
2634 atoi
2344 atoi32
30E8 @DIV1616
20EE WRITE_AD_COM_REG
2254 WRITE_AD_MODE_REG
2160 WRITE_AD_FILTER_REG
2122 WRITE_AD_DAC_REG
2202 WRITE_AD_OFFSET_REG
21B0 WRITE_AD_GAIN_REG
5646 READ_DAC_REG
2A70 READ_DATA_REG
5526 READ_OFFSET_REG
55B6 READ_GAIN_REG
1374 STORE_DATAS
0004 @const546
12B8 @PRINTF_LU_56
0736 RESTORE_DATAS
2062 INIT_MOTOR_UP
20A8 INIT_MOTOR_DOWN
2D24 NEXT_STEP_UP
2D80 @goto11830
28E2 NEXT_STEP_DW
293E @goto11843
2F66 VIBRATOR_PULSE
229A INIT_LOADCELL
27D8 SEND_RS485
3DA6 RECV_RS485
2B00 @DIV3232
2B80 @PRINTF_L32U_56
3CF8 @DIV88
3D24 @PRINTF_U_56
61D6 FUNCTION_DECODE
2E92 GET_READY_FOR_START
312E DISCHARGE_CHANNEL
38F6 FEED_PRODUCT_FROM_CUP_UP
3F5A REFRESH_CHANNEL_IDS
4068 SEND_CHANNEL_ID
40D6 ADJUST_TARGET_WEIGHT_C1C2
40DA ADJUST_TARGET_WEIGHT_C3C4
40DE ADJUST_GENERAL_PARAMETERS
0022 @const587
42FE ADJUST_TARGET_WEIGHT
004E @const588
43EA ADJUST_MAX_DEVIATION
0074 @const591
0092 @const592
45D4 ADJUST_CHANNEL_DISABLE
00B0 @const593
478E ADJUST_SEQUENTIAL_DISCHARGE_DELAY
00D8 @const594
4828 ADJUST_REMOVE_TARE_PERIOD
010A @const595
48C4 ADJUST_NOT_IN_COMBINATION_LIMIT
48C8 ADJUST_FILLING_PERCENTAGE
0134 @const596
4962 ADJUST_STEP_DELAY_MOTOR_UP
015E @const597
4A02 ADJUST_STEP_DELAY_MOTOR_DOWN
018A @const598
4AA2 ADJUST_HOLD_TIME_MOTOR_UP
01B8 @const599
4B3C ADJUST_HOLD_TIME_MOTOR_DOWN
01E2 @const600
4BD6 ADJUST_CENTER_POINT_OF_MOTOR_UP
020E @const601
4C76 ADJUST_CENTER_POINT_OF_MOTOR_DOWN
023E @const602
4D16 ADJUST_VIB_TO_CUP_UP_DELAY
0270 @const603
4DB6 ADJUST_CUP_UP_TO_CUP_DOWN_DELAY
029C @const604
4E56 ADJUST_CUP_DOWN_TO_MAIN_DOOR_DELAY
4E5A ADJUST_AD_SETTLING_TIME
02CC @const605
4EFA ADJUST_MAX_DEVIATION_C1C2C3C4
4EFE ADJUST_SLOW_DISCHARGE_ANGLE
02F4 @const606
4F9E ADJUST_VIBRATOR_INTENSITY
0320 @const607
507E ADJUST_VIBRATOR_DURATION
034A @const608
5158 ADJUST_STEP_DELAY_MOTOR_MAIN_A
0374 @const609
51F8 ADJUST_STEP_DELAY_MOTOR_MAIN_B
03A4 @const610
5298 ADJUST_STEP_DELAY_MOTOR_MAIN_C
03D4 @const611
5338 ADJUST_STEP_DELAY_MOTOR_MAIN_D
0404 @const612
53D2 ADJUST_HOLD_TIME_MOTOR_MAIN_D
0434 @const616
2DA2 TEST_MOTOR_UP
2980 TEST_MOTOR_DOWN
546C TEST_VIBRATOR
2C44 REMOVE_TARE
0462 @const621
0490 @const622
56E8 MAKE_CALIBRATION
04B6 @const624
04E8 @const625
0518 @const626
569E @PRINTF_X_56
0542 @const630
056C @const631
0596 @const633
05C8 @const640
05E4 @const642
0602 @const644
2FB4 GET_AD
0622 @const646
600A GET_GR
60F2 SET_PROGRAM
063E @const648
61A2 SAVE_PROGRAM
61D2 DELETE_PROGRAM
6514 CONT_
0666 @const662
068A @const664
06AE @const666
06D2 @const668
06EA @const669
0706 @const670
0720 @const672
67BE MAIN
67BE @cinit
0136 StrtoulGO
0136 StrtolGO
Project Directory:
Project Files:
MW_71.c
MW_71.h
Units:
Compiler Settings:
Pointer Size: 16
ADC Range: 0-255
Opt Level: 9
Float,Double: 32,32
Output Files:
Errors: MW_71.err
INHX32: MW_71.hex
Symbols: MW_71.sym
List: MW_71.lst
Project: MW_71.PJT
dc_eng
| PROBLEM SOLVED ( I GUESS ) |
Posted: Thu Jul 23, 2009 7:24 am |
I was keep working on the receiver side since adding just a variable when the transmitter side is fixed causes problems.
One thing come to my mind. What if Receiver can't cope with the data rate when the program length increases.
I do the following I decrease the data rate than the function that does not work starts to work. So, I guess increasing my code by means of functions or variables makes PIC to go different page block. And it makes a slower execution.
But as I remember CCS C do not include variables and functions that doesn't used in code in order to save space.
My sym output file says opposite. |
Wayne_
Posted: Thu Jul 23, 2009 8:13 am |
Right!
Put KILLBILL as an int in a place it doesn't work.
Change it to an int16, does it work ?
Change it to an int32 does it work ?
Place KILLBILL as an int in a place it works.
Do not make t an array of 50 chars!
Do not put it at the top or bottom just for the sake of it.
As you move the variable around and change it's size it changes the location and boundary of other vars.
I am trying to find out if the boundary makes a difference.
Also if you move it 1 line at a time you may find out what variable is being moved that causes the problem.
You can start at a place where it works and start moving it up or down until it fails. When it fails you coninue to move it to see if it starts working again. It may work in several places it may not, all this is helpfull info if you show where it works and doesn't work. I don't mean to keep listing the .lst file or complete code each time but just make a note of it and then post the code with comments.
These are just simple ways to try and trace the problem.
If you just move it arbitarily then it doesn't help!
It may not be anything to do with the location of the var at all and this is just a waste of time Have fun. |
dc_eng
| LESSON LEARNED |
Posted: Thu Jul 23, 2009 9:08 am |
Problem definitely solved.
1) If you have time critical jobs for PIC declare all related variables close each other.
2) Local variables can share same address with other variables that are not related so global declaration (static) helps to organize location of your related variables. Keeps them in same Memory Bank.
With these I can run my code without reducing data rate.
dc |
Wayne_
Posted: Thu Jul 23, 2009 9:12 am |
Bad practise to rely on your variables being placed in the same memory locations each time you compile.
You should use globals where required and not just because it makes your life easier. Use locals when the info is not required in the calling program and you cannot pass the values back OR you can get a speed increase by using globals.
If your program/pic is struggling at the speed you are using then you should consider a different pic/approach!
It sounds like you have not fixed the problem just hidden it. |
Gabriel
Posted: Tue Aug 11, 2009 3:47 pm |
| Quote: | If I declare a variable like below it works
INT MODBUS_PACKET[17];
If I declare a variable like below it won't
INT MODBUS_PACKET[18];
Just a thought... I didnt read much into the post but...
if that array is a buffer and your expecting 18 characters
17 is the right dimension for your array...
If you are waiting for the array to be filled... well it wont happen... because by declaring a zize of 18 your "real" zize is of 19.....( 0-18 )
I'm probably telling you somthing you already know... but I am bored in my office and... well... sometimes its the dumbest things that make your program fail...and I recently made that mistake...also hehehe.
g _________________ CCS PCM 4.135 - PIC: 16F886, 88', 876' 877A |
Wayne_
Posted: Thu Aug 13, 2009 2:36 am |
| Gabriel wrote: | | Quote: | If I declare a variable like below it works
g |
You are completely wrong.
Declaring an array
int modbus_packet[17]; allocates 17 ints (bytes) worth of storage (0 to 16), NOT 18 (0 to 17) as you state!
The number in the []'s is the amount of storage you need 17 ints in this case the fact that C has a zero based index for arrays does NOT mean it gives you an extra index!
int modebus_packet[17];
int myval;
main ()
modbus_packet[0] = 0xFF; // OK
modbus_packet[16] = 0xFF; // OK
modbus_packet[17] = 0xFF; // This will overwrite myval IF the 2 vars are stored as they are defined
