PIC16F88 UART interrupt problem?
onuruygur
PostPosted: Fri Jul 17, 2009 8:47 am     Reply with quote
Hi all,
I am working on PIC16F88. Here is the project task:
When the right id is received on UART HW RX, PIC16F88 will send a sensor measurement word.
I have to use HW UART because i need INT_RDA routine. But when I simulate the code on ISIS and send any character on virtual terminal, I receive the error: logic contentions.
"This message has been generated because one or more logic contentions have occurred on the specified net. A logic contention occurs when two or more outputs of the same strength attempt to drive the net into opposing logic states. A logic contention is also reported if a strong logic state is overridden by a generator or power rail. "
PIC doesn't run the code in the int_rda routine and goes to main's loops.
This is a basic application I guess...? what is the problem?
Here is my basic HW_UART code:
#include <16F88.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES MCLR                     //Master Clear pin enabled
#FUSES PROTECT                  //Code protected from reads
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8,stream=MODEM,errors)
and the C file is:
#int_RDA
RDA_isr()
output_bit(PIN_B1,1); //This is just for indication.
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(False);
   // TODO: USER CODE!!
while(TRUE){
fprintf(MODEM,"hi all");
delay_ms(500);}
Thanks in advance.
Smile
mkuang
PostPosted: Fri Jul 17, 2009 9:06 am     Reply with quote
You are using the standard hardware uart ports on this PIC. You can omit the stream name MODEM in your #use RS232 declaration. In your main code you can just use printf instead.
Also you need to enable serial interrupt. Add these lines of code in main():
clear_interrupt(INT_RDA);
enable_interrupts(INT_RDA);
dyeatman
PostPosted: Fri Jul 17, 2009 9:40 am     Reply with quote
They will also have to perform a getc() in the ISR to clear the interrupt.
 byte inputchar;
 inputchar=getc();
Google and Forum Search are some of your best tools
onuruygur
PostPosted: Fri Jul 17, 2009 11:23 am     Reply with quote
Thank you for your replies, Wink
I am sorry that I have forgotten to put the codes related with enabling interrupts although I was already placed in my own code. Here is the new code which also includes your advices. But nothing have changed.
Would you share your comments pls?
#include <16F88.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PROTECT                  //Code protected from reading
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8,errors)
and the main.c is:
#include "f88_hw_uart.h"
byte inputchar;
#int_RDA
void  RDA_isr(void)
inputchar=getc();
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   printf("Hi all!\n\r");
while(TRUE){
putc(inputchar);
The problem is same on ISIS:
At startup:
CFGWORD2 not implemented,
and when any char is sent over virtual terminal :
Logic contention is detected on PIC_RX.
Thanks is advance...
PostPosted: Fri Jul 17, 2009 11:34 am     Reply with quote
setup_adc(ADC_OFF);
That line sets the TRIS for the hardware SPI pins. The SPI module
shares the SDO pin with the Rx pin for the UART. The SDO pin is
an output pin, but the Rx pin is an input pin. This is causing the
"logic contention". Remove the line shown in bold.
onuruygur
PostPosted: Fri Jul 17, 2009 1:41 pm     Reply with quote
PCM programmer wrote:
setup_adc(ADC_OFF);
Very good orientation! That solved the problem. Thank you very much to all, of course to PCM Programmer also. Very Happy
