Part number of the LCD1 on PICDEM 2 PLUS "RoHS" ve
sung
PostPosted: Mon Jul 13, 2009 9:28 am     Reply with quote
Would anyone please tell me the part number of the LCD1 that is mounted on the PICDEM 2 PLUS "RoHS" version?
I am trying to search for its data sheet in order to get some instruction sets.
Thank you
PostPosted: Mon Jul 13, 2009 11:03 am     Reply with quote
Learn to use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Type these search terms into the top box:
Rohs lcd part number
Select the tickbox for: Search for all terms.
Then click the Search button.
sung
Thanks!
PostPosted: Mon Jul 13, 2009 4:13 pm     Reply with quote
I also searched the Microchip's website.
The part number for the RoHS version was OM16214 made from Ocular.
Thanks so much!
sung
Finding the data sheet
PostPosted: Mon Jul 13, 2009 4:56 pm     Reply with quote
Does anyone have the data sheet for Ocular OM16214 LCD?
I tried to look it up online, but failed to find it.
Thank you
dyeatman
PostPosted: Mon Jul 13, 2009 5:11 pm     Reply with quote
I used Google with the words "OM16214" and "datasheet" and found the
following hit from Google by PCM on another website that provides most of what you need top get the display to work:
http://www.mcuspace.com/mcuforum/viewtopic.php?p=112&sid=f923aef98b9762bbd5cd0ff3947c4d9c
Be sure and read the entire thread for all the info on how to use the display...
Here is the main datasheet for the NT7605 controller:
http://www.pacificdisplay.com/cdm/CDM-20215.pdf
More Novatek NT7605 datasheet info here:
http://www.pacificdisplay.com/ics_app%20notes/novatek/NT7605_v2.2.pdf
Google and Forum Search are some of your best tools
