Which card MMC or SD may be better in the long run..
arunb
PostPosted: Thu Jun 11, 2009 10:39 pm     Reply with quote
I am trying to standardize on a design that uses a RS MMC card, I find that this card is not easily available as Nokia and Siemens stopped using them in their designs.
My question is
1. Are the SD cards more likely to be available in the future than the MMC ones ?
2. I am able to get MMC Plus cards, will the CCS drivers for the RS MMC be compatible with the MMC Plus cards ?
3. If I start using the SD Cards, will the drivers for the SD Card be compatible with microSD card ?
thanks
arunb
asmallri
Re: Which card MMC or SD may be better in the long run..
PostPosted: Thu Jun 11, 2009 11:17 pm     Reply with quote
arunb wrote:
My question is
The SD form factor is far more readily available than the MMC form factor
Only in so far that you will have MMC basic functionality
Yes provided the vendor of the microSD card supports the SPI mode.
SPI mode support is not a mandatory requirement for microSD cards under the SD card specification. Most microSD card vendors offer passive adapters to enable microSD cards to be used for miniSD and full size SD card applications enabling these vendors to increase their addressable market so it is unlikely these vendors will drop SPI support from their microSD products.
I develop SD/MMC based software products and have tested using my software a range of microSD cards from various vendors both standard and SDHC variants and have not found any cards that do not support SPI mode.
Regards, Andrew
arunb
RE:
PostPosted: Thu Jun 11, 2009 11:23 pm     Reply with quote
So SD card may be a better option??
Does one have to become member for accessing SD card specs ??
thanks
arunb
asmallri
Re: RE:
PostPosted: Thu Jun 11, 2009 11:48 pm     Reply with quote
No. There is (was) no ambiguity with licensing with MMC. You only needed a license if you were actually manufacturing MMC cards. This may have changed as the MMCA Board of Directors and Executive Members have approved a motion to dissolve MMCA and transfer assets (including specifications, works in progress, copyrights and certain other assets) to the JEDEC Solid State Technology Association.
Note that the latest version of the MMC specification also dropped SPI support (obsoleted it).
thanks
arunb
They offer a free light weigh version of the specification here: http://www.sdcard.org/developers/tech/sdcard/pls/
Free is a relative term. Buyer beware.
Regards, Andrew
