conversion float to int8
dynamitron
PostPosted: Tue Jun 09, 2009 4:31 pm     Reply with quote
I am developing a thermostat based on a DS18b20.
I would like to compared the temperature stored in a float variable to an integer 8 bit.
For this purpose I would like to convert the float variable into a int8 and then make the comparison ?
How to do this conversion assuming that I am not interested in the decimal part of the float ?
Thanks in advance for the hints !! ,
Dynamitron
PostPosted: Tue Jun 09, 2009 4:58 pm     Reply with quote
Do it by casting the float to an int. C tutorial page:
http://www.cs.cf.ac.uk/Dave/C/node9.html#SECTION00930000000000000000
nostep
PostPosted: Wed Jun 10, 2009 5:05 am     Reply with quote
You don't necessarily have to convert it then compare it. You could do this:
// declare variables
int num_int;
float num_float;
// Get your data into the variables as you need to
num_int=127;
number_float=124.3;
// Here's the comparison using a "cast" method
if(num_int > (int)num_float) // do what you need to do now
dynamitron
PostPosted: Wed Jun 10, 2009 1:57 pm     Reply with quote
Thanks to both of you, this is exactly what I wanted.
I like the "no conversion" comparison.
Dynamitron
PostPosted: Wed Jun 10, 2009 2:11 pm     Reply with quote
If you had looked at the link PCM programmer gave, you would see exactly the same suggestion. This _is_ a cast, and what you are doing, is converting the float to an int, before the conversion.....
