Luiz Guest
| Two serial and several speeds |
Posted: Wed Jun 03, 2009 7:05 am |
Hello to all
As I do to change the speed of the stream COM2,
#use rs232 (baud=10400, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
set_uart_speed (9600); / / it WORKS LIKE THIS
set_uart_speed (19200);
set_uart_speed (4800);
Is it here as I can do to change the speed?
#use rs232 (baud=9600, parity=N, rcv=PIN_A4, bits=8, STREAM=COM2)
Luiz. |
Posted: Wed Jun 03, 2009 7:57 am |
According to the CCS manual set_uart_speed() provides for an optional Stream parameter
| Quote: | set_uart_speed( )
Syntax: set_uart_speed (baud, [stream, clock])
Parameters: baud is a constant 100-115200 representing the number of bits per second.
stream is an optional stream identifier.
clock is an optional parameter to indicate what the current clock is if it is
different from the #use delay value
_________________ Google and Forum Search are some of your best tools |
Luiz Guest
Posted: Wed Jun 03, 2009 8:20 am |
Would it be like this, but and how much the clock?
set_uart_speed(9600,[COM2, ??);
set_uart_speed(10400,[COM2, ??);
set_uart_speed(4800,[COM2, ??); |
Posted: Wed Jun 03, 2009 8:22 am |
The clock parameter is also optional so:
set_uart_speed(9600,COM2); should be all you need. _________________ Google and Forum Search are some of your best tools |
Luiz Guest
Posted: Wed Jun 03, 2009 9:08 am |
I am using like this.
#include < 18F2685.h>
#use delay (clock = 8000000)
#use rs232 (baud=19200, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
#use rs232 (baud=19200, parity=N, rcv=PIN_A4, bits=8, STREAM=COM2)
#int_RDA
void RDA_isr () {CK [PD] = getch (); PD++;IF (PD==0) ck [2] = 0;IF (PD==2) PD=0; }
void main (void)
putc (0x70);
delay_ms (10);
rx=CK [0];
if (rx==0x0D){
PD=0;
set_uart_speed (4800, COM2);
fputc (0x0A);
delay_ms (10);
set_uart_speed (9600, COM2);
rx1=fgetc (COM2);
// Here it doesn't work, the speed doesn't change!
Posted: Wed Jun 03, 2009 5:12 pm |
From the CCS manual | Quote: | Syntax: set_uart_speed (baud, [stream, clock])
Returns: undefined
Function: Changes the baud rate of the built-in hardware RS232 serial port at run-time.
Availability: This function is only available on devices with a built in UART. | The stream on COM2 does not use a hardware UART, so you can't change the baudrate this way.
Solutions to change the baudrate for a soft UART have been posted on this forum. |
Luiz Guest
Posted: Thu Jun 04, 2009 6:37 am |
| Could you give an example? |
Posted: Thu Jun 04, 2009 11:31 am |
| Like I said, solutions have been posted on this forum before, use the Search function of this forum to find them. I don't have time now to search these solutions so why don't you give it a try. If you can't find them, post again. |
