How to use MMC card as large eeprom ?
match0927
treat MMC card as a big EEPROM
PostPosted: Tue May 26, 2009 8:48 am     Reply with quote
If I just wanna use MMC card as an EEPROM. e.g. just read or write a byte to some address. Is there a simple code to implement? I do not need create a file on the card then read it via the PC. Thanks.
asmallri
Re: treat MMC card as a big EEPROM
PostPosted: Tue May 26, 2009 9:48 pm     Reply with quote
You just need the basic low level SPI drivers. You need to take into account that unlike an EEPROM you cannot just change the location of a single byte but instead must read in the target sector into RAM (512 bytes) modify one or more bytes of interest, then write back the modified sector. Another important consideration is that the write endurance of an EEPROM is orders of magnitude higher than an MMC card.
Regards, Andrew
PostPosted: Wed May 27, 2009 6:19 am     Reply with quote
So is there such a kind of code here? Very thanks?
arunb
RE:
PostPosted: Fri May 29, 2009 4:21 am     Reply with quote
Do this mean MMC will wear out faster than EEPROM ??
thanks
arunb
asmallri
Re: RE:
PostPosted: Fri May 29, 2009 6:56 am     Reply with quote
thanks
arunb
Yes.
Regards, Andrew
