Lion Guest
| I am confused......... |
Posted: Tue May 26, 2009 11:16 pm |
Hello everyone,
First of all, I am so sorry to post my question again in new topic but I really can not figure out.
I am using PIC 16F877 and CCS 3.222 version, MPLAB V8.1 .
My question is that I am using UV tron flame detector.
When the sensor detect the fire, it will output_high.
I am using UV tron and Temperature sensor at the same time.
I know that I can use " while(! input(PIN_D5)) " to wait for the PIN_D5 go high or use "while(input(PIN_D5))" to wait for the PIN_D5 go low.
My question is that may I use "if" to do the same thing? I mean that I have two conditions for " if " loop. One is " Temp>30 " and the other one is the output_high of UV sensor .
May I use " if (Temp> 30 && input(PIN_D5))" ? ==> to check Temp>30 and wait for PIN_D5 output_high.
So far, I tried many ways but it can not get in the " if loop " Sometimes when Temp> 30 but PIN_D5 does not high. The code get in the loop.
I am confused. I use many "goto" command in my code. Does it damage the code structure?
In "Problem 1",(see the code) I try to check two conditions but it can not get in the "Problem 1" code in the beginning but I tries many method.
Now it always gets in the "Problem One" code but the flame detector do not detect the fire (if detect the fire, flame detector will output high). I do not understand why the code does not consider the condition?
My second question:
May I use the condition like (input(PIN_A2)!=0) or (input(PIN_A2)>1)
or (input(PIN_A2)==0)
The syntax is correct or not? If the PIN_A2 is used to check the flame detector output is high or low.
I really need someone help me to figure out.
Any help will be really really apprecitated.
Thank you so much
#include <16F877.h>
#device ADC=10
#use delay(clock=10000000)
#include<stdio.h>
#include <math.h> // for temperature sensor
enable_interrupts(global);
//while(1)
delay_ms(3000);
output_high(PIN_D0); //go forward ; this pin do not decide yet.
output_high(PIN_D1); // go forward ; this pin do not decide yet.
output_high(PIN_C0); //Start Fire Gun
output_high(PIN_C1); //Start barbette
delay_ms(5000); // initial ans settle down everything
start1:
//*** Temperature Sensor Code in this line ***///
printf("Temperature now is in start1 %d\n\r",Temp);
delay_ms(700);
Ultrasonic();
delay_ms(700);
if (Temp>29 && input(PIN_A2)) ==============> Problem 1
output_low(PIN_D0); //stop Mother Vehicle
output_low(PIN_D1); //stop Mother Vehicle
delay_ms(1000); //This delay is due to inertia of DC motor
output_low(PIN_C0); //
delay_ms(2000);
output_low(PIN_C1);
//printf("Find the Fire\n\r");
else if(Temp>29)
start2:
if(distance6<27&&distance6>16&&distance5>12&&distance5<19)
printf("Distance 6 and 5 are good .Temperature is %d \n\r ", Temp);
delay_ms(3000);
output_low(PIN_D0); // Stop Forward ;
output_low(PIN_D1); // Stop Forward ;
output_low(PIN_C0); // Stop Fire Gun;
output_low(PIN_C1); // Stop the barbette;
output_high(PIN_E0); //Open the door.
output_high(PIN_C2); //Open the door.
output_low(PIN_C2);
//**now DV1 and DV2 come out **//
delay_ms(1500);
connect_again:
output_low(PIN_C5);
output_high(PIN_C5);
delay_ms(1500);
//*** wireless connect code. I do not show in this line***//
delay_ms(3000);
if(kbhit())
TempDV1=getc();
delay_ms(2500);
output_low(PIN_C5); // For some function purpose
output_high(PIN_C5);// For some function purpose
delay_ms(1500);
delay_ms(3000);
if(kbhit())
TempDV2=getc(); //In here, maybe I need put TempDV2ACK=getc(); to get ACK return
delay_ms(2000);
output_low(PIN_C5);
if (TempDV1>28 && TempDV1<120 || TempDV2>28 &&
TempDV2<120)
if (TempDV2>TempDV1+3) //DV2 is higher than DV1
output_high(PIN_D3);
output_high(PIN_D4); //turn_right
delay_ms(7000);
output_low(PIN_D3); //stop turn_right ;
output_low(PIN_D4); //Stop turn_right ;
delay_ms(1500); //for relay, it needs time to release.
output_high(PIN_D0); // go_straight();
output_high(PIN_D1); // go_straight();
DV1_Detect:
if ( Temp>29&& input(PIN_A2))
output_low(PIN_D0); //stop();
output_low(PIN_D1);
//motor
output_low(PIN_C0); //Stop Fire Gun
delay_ms(2000); //this delay is due to inertia of DC
//motor
output_low(PIN_C1); //Stop the barbette
goto DV1_Detect;
else if(TempDV1>TempDV2+3)
output_high(PIN_B3); //turn_left();
output_high(PIN_C3); //turn_left();
delay_ms(7000);
output_low(PIN_B3); //stop turn_left;
output_low(PIN_C3); //Stop turn_left;
delay_ms(1500);
DV2_Detect:
if( Temp>29 && input(PIN_A2)) //Detect Temp>29 and check
//flame detector is
//output_high
output_low(PIN_D1); //stop();
//motor
//motor
printf("Find the FIRE ")
goto DV2_Detect;
goto connect_again;
goto connect_again;
goto start2;
goto start1;
SherpaDoug
Posted: Wed May 27, 2009 10:25 am |
If you can cut your program down to 20 or 30 lines you will get more help.
I would start by drawing a simple flowchart of your code, and maybe read a book about programming structure. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed May 27, 2009 4:23 pm |
| SherpaDoug wrote: | If you can cut your program down to 20 or 30 lines you will get more help.
I would start by drawing a simple flowchart of your code, and maybe read a book about programming structure. |
Thank you for your suggestion.
I will cut it down and ask them in next topic.
Thank you so much. |
Posted: Thu May 28, 2009 2:33 am |
No.
Don't keep launching new topics. Doing so, will not help, and makes it impossible for people to see what has 'passed'.When you add a post to the old topic, it automatically moves up the board, so keep the questions about a single problem, in a single thread. Only launch a new topic, once the problem is abandoned or solved, and you are asking about something else.
Launching new topics about the same question, is a way to annoy some of the people here, and reduce the chance of getting answers....
apcaye
Posted: Thu May 28, 2009 10:31 am |
Totally agreed, Ttelmah. I was trying to help Lion in a previous thread with the same problem as this one, but now I don't feel motivated to continue supporting him/her.
Adriano. |
