'A numeric expression must appear here'...Should it?!
Angus
PostPosted: Tue May 19, 2009 7:29 am     Reply with quote
Hi all,
This may well be a really stupid question, but I am having problems calling a function which is expecting an 8 bit integer. The function is as follows:
void set_uart_speed(int8 s)
   switch(s)      // Set UART baud rate
      case 0: set_uart_speed(9600); break;
      case 1: set_uart_speed(19200); break;
      case 2: set_uart_speed(38400); break;
And I need to pass it a local variable to set the UART speed accordingly, example as follows:
a = 1;
set_uart_speed(a);
However this results in the 'A numeric expression must appear here' error. Passing it a constant (i.e. 'set_uart_speed(0);') works fine. What am I missing?!
Thanks!
Angus
asmallri
PostPosted: Tue May 19, 2009 8:26 am     Reply with quote
It is likely the problem occurs before the
set_uart_speed(a);
Look for a missing ; or brace.
Regards, Andrew
PostPosted: Tue May 19, 2009 2:23 pm     Reply with quote
That function doesn't accept a variable as a parameter. It must be
a constant. From the manual:
set_uart_speed( )
Syntax: set_uart_speed (baud, [stream, clock])
Parameters: baud is a constant
The reason for this is undoubtedly to create more compact code.
The conversion of '9600' to suitable register values is done at
compile-time, and it compiles to only 5 lines. If this was done
at run-time it would require much more code.
00314 .................... set_uart_speed(9600);
0017 3019       00315 MOVLW  19
0018 1683       00316 BSF    03.5
0019 0099       00317 MOVWF  19
001A 30A6       00318 MOVLW  A6
001B 0098       00319 MOVWF  18
The basic CCS philosophy is to keep the ROM-usage low by doing
computations at compile-time, if possible. This means that in many
cases the functions are less flexible, because they don't accept
variables as parameters. It's a trade-off that makes sense for the
16F-series and small-to-medium 18F PICs.
PostPosted: Wed May 20, 2009 2:46 am     Reply with quote
The actual core of the problem, is that a lot of CCS 'functions', are not. In many cases, they are internal macros. Now the original code, is attempting to overload the CCS function, by allowing an 8bit integer to select which of the CCS 'set_uart_speed' functions should be called. If the CCS code, was a function, and it's variable typed as an int16, this would work, but since it is actually a macro, and written to require a constant only, the overload won't work.
The basic code will work fine, if you just change the name. Call the function (say) my_set_uart_speed, and it'll work.
Angsu
Thanks!
PostPosted: Fri May 22, 2009 2:41 am     Reply with quote
Just a quick thanks to everyone - I wasn't aware of these limitations - I'll find a workaround I'm sure.
Thanks,
Angus
