g.desvaux
| DsPic - How to configure audio Digital-to-analog converter ? |
Posted: Tue May 19, 2009 9:13 am |
Hello all,
I would like to use the audio digital-to-analog converter of a DSPIC33FJ64GP802, but there are no explanations in the CCS manual.
I find this in file 33FJ64GP802.h in the CCS Folder :
// Digital to Analog Functions: SETUP_DAC(), DAC_WRITE()
// Constants used in SETUP_DAC() are:
#define DAC_OFF 0
#define DAC_RIGHT_ON 0x00808000
#define DAC_LEFT_ON 0x80008000
#define DAC_RIGHT_MIDPOINT 0x00A08000
#define DAC_LEFT_MIDPOINT 0xA0008000
#define DAC_SIGNED 0x100
#define DAC_SLEEP_ON 0x1000
#define DAC_IDLE_OFF 0x2000
// Constants used as the first param in DAC_WRITE() are:
#define DAC_DEFAULT 0
#define DAC_RIGHT 1
#define DAC_LEFT 2 |
When I use these function, the compiler ask two parameters P1 and P2 :
| Code: | SETUP_DAC(P1,P2)
DAC_WRITE(P1,P2) |
What values can I use for P1 and P2 ?
Can you post a code example ?
Thanks, |
g.desvaux
Posted: Fri May 29, 2009 3:37 am |
it's Ok.
Hardware configuration :
- DsPicc33FJ64GP802 (No DAC Midpoint output)
- Osc = 20MHz, Clock = 40MHz (PLL use)
Function setup_dac is not working properly.
I configure DAC Register with the following code in ASM :
| Code: | #asm
MOV #0x80, W4
MOV W4, 0x03F2
MOV #0x9003, W4
MOV W4, 0x03F0
#endasm |
DAC registers are configured for : DAC enables , Continue Module operation in Idle Mode, Analog output amplifier is enable during sleep/modeStop-in Idle mode bit, Data Unsigned, Divide input clock by 2, DAC right output Enable. |
