		| Author | Message |
		| john2003 Guest
				| bug I2C PCD |
				|  Posted: Sun May 17, 2009 9:30 pm |   |
				| I use dspic30f4012 pcd 4.088
  	  | Code: |  	  | void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec) {
 i2c_start();
 i2c_write(0xD0);
 i2c_write(0x00);
 i2c_start();
 i2c_write(0xD1);
 sec = bcd2bin(i2c_read() & 0x7f);  //read data is 0x00 always. no change.
 min = bcd2bin(i2c_read() & 0x7f);  //read data ok. change every minute.
 hr  = bcd2bin(i2c_read(0) & 0x3f); //read data ok. change every hour.
 i2c_stop();
 void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
 i2c_start();
 i2c_write(0xD0);
 i2c_write(0x03);            // Start at REG 3 - Day of week
 i2c_start();
 i2c_write(0xD1);
 dow  = bcd2bin(i2c_read() & 0x7f);   //read data ok
 day  = bcd2bin(i2c_read() & 0x3f);   //read data ok
 mth  = bcd2bin(i2c_read() & 0x1f);   //read data ok
 year = bcd2bin(i2c_read(0));           //read data ok
 i2c_stop();
		| john2003 Guest
				|  Posted: Sun May 17, 2009 9:41 pm |   |
				| but this code i use 16f876 no problem. |  |
		| ckielstra
				|  Posted: Mon May 18, 2009 1:22 am |   |
				| It helps if you say what your problem is...
 Also, the code is incomplete. Post a very small program demonstrating your problem. The program must be complete including fuses, etc., so it can be copy/pasted without changes.
		| Ttelmah Guest
				|  Posted: Mon May 18, 2009 3:38 am |   |
				| One 'obvious' thing would be the clock rate, and speed settings for the I2C bus. I'd guess that you are likely to be clocking the DSPic a lot faster than the 876, and unless you are explicity selecting 100K I2C, the bus may well be too fast for the chip.... A 'mini' program, that just shows the fault, so other people can compile it, and see what is wrong, is the only way to really go.
		| john2003 Guest
				|  Posted: Mon May 18, 2009 3:58 am |   |
				|  	  | Code: |  	  | // I can not read second. data second is 0x00 alway not change. // but I can read minute and hour.
 #include <30f4012.h>
 #use delay(clock=32M,restart_wdt)
 #fuses XT_PLL8,PROTECT,NOWDT,NOWRT,NOCKSFSM,CKSNOFSM,NODEBUG,NOCOE
 #use rs232(baud=9600,UART1A,ENABLE=PIN_D1)
 #define RTC_SDA  PIN_F2
 #define RTC_SCL  PIN_F3
 #use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
 BYTE bin2bcd(BYTE binary_value);
 BYTE bcd2bin(BYTE bcd_value);
 unsigned int8 hr,min,sec,min_buf,sec_buf;
 void ds1307_init(void)
 BYTE seconds = 0;
 i2c_start();
 i2c_write(0xD0);      // WR to RTC
 i2c_write(0x00);      // REG 0
 i2c_start();
 i2c_write(0xD1);      // RD from RTC
 seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
 i2c_stop();
 seconds &= 0x7F;
 delay_us(3);
 i2c_start();
 i2c_write(bin2bcd(seconds));     // Start oscillator with current "seconds value
 i2c_start();
 i2c_write(0x07);      // Control Register
 i2c_write(0x80);     // Disable squarewave output pin
 i2c_stop();
 i2c_start();
 i2c_write(0xD0);
 i2c_write(0x00);            // Start at REG 0 - Seconds
 i2c_start();
 i2c_write(0xD1);
 sec = bcd2bin(i2c_read() & 0x7f);     // REG 0
 min = bcd2bin(i2c_read() & 0x7f);     // REG 1
 hr  = bcd2bin(i2c_read(0) & 0x3f);     // REG 2
 i2c_stop();
 BYTE temp;
 BYTE retval;
 temp = binary_value;
 retval = 0;
 while(true)
 // Get the tens digit by doing multiple subtraction
 // of 10 from the binary value.
 if(temp >= 10)
 temp -= 10;
 retval += 0x10;
 else // Get the ones digit by adding the remainder.
 retval += temp;
 return(retval);
 // Input range - 00 to 99.
 BYTE temp;
 temp = bcd_value;
 // Shifting upper digit right by 1 is same as multiplying by 8.
 temp >>= 1;
 // Isolate the bits for the upper digit.
 temp &= 0x78;
 // Now return: (Tens * 8) + (Tens * 2) + Ones
 return(temp + (temp >> 2) + (bcd_value & 0x0f));
 ds1307_init();
 while(true){
 ds1307_get_time(hr,min,sec);
 if(sec_buf!=sec){
 sec_buf=sec;
 printf("%X:%X:%X"hr,min,sec);
 if(min_buf!=min){
 sec_buf=min;
		| john2003 Guest
				|  Posted: Mon May 18, 2009 4:04 am |   |
				|  	  | Code: |  	  | #include <30f4012.h> #use delay(clock=32M,restart_wdt)
 BYTE seconds = 0;
 i2c_start();
 i2c_start();
 i2c_stop();
 seconds &= 0x7F;
 delay_us(3);
 i2c_start();
 i2c_start();
 i2c_stop();
 i2c_start();
 i2c_write(0xD0);
 i2c_start();
 i2c_write(0xD1);
 i2c_stop();
 BYTE temp;
 BYTE retval;
 retval = 0;
 while(true)
 if(temp >= 10)
 temp -= 10;
 retval += 0x10;
 retval += temp;
 return(retval);
 BYTE temp;
 temp = bcd_value;
 temp >>= 1;
 temp &= 0x78;
 ds1307_init();
 while(true){
 if(sec_buf!=sec){
 sec_buf=sec;
 if(min_buf!=min){
 min_buf=min;
		| Ttelmah Guest
				|  Posted: Mon May 18, 2009 4:17 am |   |
				| So try specifying a clock rate for the I2C:
 #use i2c(master, sda=RTC_SDA, scl=RTC_SCL, SLOW)
		| john2003 Guest
				|  Posted: Mon May 18, 2009 4:33 am |   |
				| // not work
		| FvM
				|  Posted: Mon May 18, 2009 3:20 pm |   |
				| I tried your last code version on a PIC24FJ128GA106 with a DS1337 RTC connected and it did display seconds as expected.
 But I found a PCD bug with I2CBRG setup. For a clock frequency of 32 MHz, it should be set to 0x0122. Unfortunately, only an 8-Bit value is set. The programmer seems to have forgotten, that he's dealing with a 16-Bit processor.
  	  | Code: |  	  | 02C6  B3C220     mov.b #0x22,0x0000 02C8  B7E204     mov.b 0x0000,0x0204
 The erroneous setting results in about 850 kHz I2C clock.
 Set I2CBRG manually in your code as a workaround.
  	  | Code: |  	  | #word I2CBRG = 0x204 I2CBRG = 0x122;
 Best regards,
 Frank
		| john2003 Guest
				|  Posted: Mon May 18, 2009 11:26 pm |   |
				| Why i can read hour and minute. but i can not read second. |  |
		| FvM
				|  Posted: Tue May 19, 2009 12:02 am |   |
				| Don't know. It may be related to the wrong frequency. Don't ask, please try.
 I used most recent PCD V4.092. I didn't check for possible additional bugs with V4.088 or special
 issues with dsPIC30 code. However, PIC24 I2C code has been operational for me since V4.079.
 Because my application has a 16 MHz clock, I wasn't aware of the said bug.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
