		| Author | Message |
		| treitmey
				| is I2C FORCE_HW compatible with status check of write ? |
				|  Posted: Fri May 15, 2009 1:27 pm |   |
				| V3.249 18F4525 @ 18432000Hz I'm using a Microchip 24LC256 chip and I'm rewriting the driver for
 page write and for going across chip boundaries.
 my question: is I2C FORCE_HW compatible with status check of write?
 I am using the write_ext_eeprom() from 24256.c as a start.
 When I change to FORCE_HW my routine locks and can't complete the write.  It seems to be stuck at the status check.
 If I turn off FORCE_HW then it works.
 C:\Program Files\PICC\Drivers\24256.C
  	  | Code: |  	  | void write_ext_eeprom(long int address, BYTE data) {
 //parts are missing for the copyrights sake
 .....stop...
 i2c_start();
 status=i2c_write(0xa0);
 while(status==1)
 i2c_start();
 this is changed in the driver
 #use i2c(master,SDA=EEPROM_SDA,SCL=EEPROM_SCL,FORCE_HW) //start with slow
  	  | Code: |  	  | //05/14/2009 9:54AM Single 24LC256 EEPROM #define FIRM_MAJOR (int8) 'i'
 #define FIRM_MINOR  (int8) 8
 #include <18F4525.h>
 #fuses hs,nowdt,noprotect,nolvp,put
 #use delay(clock=18432000,RESTART_WDT)
 #use rs232(baud=19200,xmit=PIN_D7,invert,stream=DEBUG)
 #case
 #zero_ram
 #include <STDLIB.H>
 #define AddrVal       0
 #define EEPROM_SDA  PIN_C4
 #define EEPROM_SCL  PIN_C3
 #include "24256.C" //local copy of driver.. I'm messing with this
 void init(void);
 void init_ext_eeprom(void);
 void display_binary(char c);
 void write_ext_eeprom(int16 address,int8 data);
 int8 read_ext_eeprom(int16 address);
 int8 i,tmp;
 int8 w[70];//1024 byte write array with random data
 int8 r[70];//1024 byte read array with read in data
 int16 addr;//array is written to and read from address
 int16 cnt;//counter for setting up array
 init();
 init_ext_eeprom();
 addr=AddrVal;
 for (cnt=0;cnt<sizeof(w);cnt++) w[cnt]=rand();
 for(addr=AddrVal,cnt=0;cnt<sizeof(w);cnt++,addr++)
 write_ext_eeprom(addr,w[cnt]);
 fprintf(DEBUG,".");
 r[cnt]=read_ext_eeprom(addr);
 if(r[cnt]!=w[cnt])
 fprintf(DEBUG,"\w\rError r=%03u w=%03u cnt=%lu\n\r",r[cnt],w[cnt],cnt);
 fprintf(DEBUG,"\n\rDone!\n\r");
 //========================= Functions ==============================//
 //=== init ===//  setup the initial settings
 #define BEEP  PIN_C0
 #define RELAY PIN_C1
 #define XMTHEN PIN_C5
 void init(void)
 int8 tmp;
 output_low(BEEP);
 output_low(RELAY);
 output_low(XMTHEN);
 //set_tris_a(0xFF);set_tris_b(0xFF);set_tris_c(0xFF);set_tris_d(0xFF);set_tris_e(0xFF);
 setup_adc_ports(NO_ANALOGS); setup_adc(ADC_OFF);
 port_b_pullups(FALSE);
 fprintf(DEBUG,"Start\n\r");
		| PCM programmer
				|  Posted: Fri May 15, 2009 2:12 pm |   |
				|  	  | Quote: |  	  | i2c_start();
 while(status==1)
 i2c_start();
 i2c_stop();
 I noticed one difference between your code and 24256.c.
 CCS has an i2c_stop at the end.  Your code does not.
		| treitmey
				|  Posted: Fri May 15, 2009 2:15 pm |   |
				| The stop you mentioned fixed it. This is what I have.. Ill delete if someone could only verify it. Thanks
 Ver 3.249
 edit ...
 snip..
 or should there be a stop after the while(status==1) block of the write
		| PCM programmer
		| treitmey
				|  Posted: Fri May 15, 2009 5:03 pm |   |
				| I did see that errata.  Tried to pop in a 18F452 at about noon time to eliminate that from the equation. ...but by now my brain is mush and I don't know what was tried/eliminated or not.
 I've got it working now.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
