pl7
Using printf to output hexadecimal |
Posted: Thu Apr 30, 2009 7:55 am |
An easy question, I hope. I'm puzzled by the behaviour of printf on a PIC 18F452.
int8 a;
a = 1;
printf("%d", a);
produces 1, but
int8 a;
a = 1;
printf("%x", a);
produces 01.
This seems to be incorrect to me. I expected a single hex character for values of a < 16. Is the extra zero a CCS "feature"? Does anyone know how to achieve a single character using the printf format specification?
Thanks,
Phil |
treitmey
Posted: Thu Apr 30, 2009 8:37 am |
If your just trying to print a 1 thats easy.
Do it via printing the character.
The character 1 is ascii 49.
So to change 0x01 to 0x31 you add 0x30.
The more common way is to add '0' Code: | #include <18F4620.h>
#fuses hs,nowdt,noprotect,nolvp,put
#use delay(clock=18432000,RESTART_WDT)
#use rs232(baud=19200,xmit=PIN_E0,invert,stream=DEBUG)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,bits=8,stream=CIM)
#case
int8 k=1;
k=k+'0';
//fprintf(DEBUG,"%X\n\r",k);
fprintf(DEBUG,"%C\n\r",k);
while (1)
Posted: Thu Apr 30, 2009 9:13 am |
Use standard a format string (%x seems to default to %02x):
pl7
Posted: Thu Apr 30, 2009 9:30 am |
FvM wrote: | Use standard a format string (%x seems to default to %02x):
This was my first thought too, but the width part of the format string specifies a minimum number of digits, not a maximum, so it seems strange to specify a minimum width when really I want to shorten the output. However, I'm sure you are right: CCS is simply substituting %02x for %x, so your solution will work.
Sorry, I would normally have just tried this myself but I have no access to any hardware at the moment.
Thanks for the input,
Phil |
Posted: Thu Apr 30, 2009 9:35 am |
I suspect the 'reason', is quite logical, when you think that a int8, is inherently two hex digits.
Just another CCS oddity.
Posted: Thu Apr 30, 2009 1:18 pm |
Quote: | Sorry, I would normally have just tried this myself but I have no access to any hardware at the moment. | You don't actually need it. I was using MPLAB SIM, cause I didn't want to re-flash a board for this trivial test.
Quote: | Just another CCS oddity. | Yes. I'm satisfied so far, if CCS C understands standard format specifiers, which is the case, fortunately. |
