koenbielen
| Bootloader for 18F4525 |
Posted: Sat Apr 25, 2009 6:00 am |
My name is koen and I have been looking around here for a good bootloader.
The tiny bootloaders seems a good option.
How to implement this is a big ? for me.
So as I understand I need to do 4 things to get this up and running
1) program the PIC via MPLAB ICD2.
I did use the tinybld18F2620.HEX.
Do I need to change something in this file?
Do I need to compile?
2) after having the PIC programmed I startup the TinyBld software
I have used the good comport but after reset and pressing the button Check PIC
Connected to \\.\COM1 at 115200
Searching for PIC ...Not found,
ERROR!
3) In the source code below I need to add a ORG statement or something else?
Where should I place this and what exactly?
I am using the CCS compiler version 4.065
#include <18F4525.h>
#device adc=10
#FUSES INTRC_IO //High speed osc with HW enabled 4X PLL
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES RESERVED //Used to set the reserved FUSE bits
#use delay(clock=32000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,DISABLE_INTS,STREAM=NETWERK)
#INT_RDA
void SerialDataAvailable() {
if(kbhit(NETWERK))
ReadSerialData();
setup_oscillator (osc_8MHZ | OSC_PLL_ON);
setup_uart(1);
delay_ms(300);
set_tris_a (0xFF);
set_tris_b (0x7F);
set_tris_c (0xB9);
set_tris_d (0xF0);
set_tris_e (0XF8);
while (1)
output_bit(PIN_D1 ,1);
delay_ms(2);
output_bit(PIN_D1 ,0);
delay_ms(2);
4) after compiling this I and good connection to the hardware (need to solve Question 2 first)
I need to open this hexfile and download it to the processor.
And then hocus pocus it should run... not for me... (Bummer)
So if there is someone who would like to help me or has a link to a good manual I would be thankful
Thanks in advance
Kind Regards
Koen Bielen |
koenbielen
| Bootloader is up and running |
Posted: Sat Apr 25, 2009 4:13 pm |
Kind Regards
Koen |
misperry
Posted: Tue May 19, 2009 9:49 am |
How did you get your problem fixed if I might ask cuz I am running into the same thing.
Thanks! |
Posted: Wed May 20, 2009 5:12 am |
I added some code
#define MAX_FLASH 0xC000 //for PICs with 48KB of mem
#define LOADER_SIZE 0xFF //tinybld size + a bit more (200 bytes is enough)
#org MAX_FLASH-LOADER_SIZE , MAX_FLASH-1 {}
as below and changed the internal osc in the bootloader file.
#device adc=10
#INT_RDA
if(kbhit(NETWERK))
ReadSerialData();
setup_uart(1);
delay_ms(300);
set_tris_a (0xFF);
set_tris_b (0x7F);
set_tris_c (0xB9);
set_tris_d (0xF0);
set_tris_e (0XF8);
while (1)
delay_ms(2);
delay_ms(2);
Hope this helps
Byby
