/dev/human
Joined: 01 Sep 2008 Posts: 19 Location: Earth / Europe / Germany
| Strange code results using an array [solved] |
Posted: Wed Apr 22, 2009 11:03 pm |
Hi All
I programmed a simple piece of code to handle a simple stack.
float32 TemppH;
float32 TempT;
int loop;
StackHnd (0, 0, Clear);
for (loop = 0; loop < 20; loop++) {
TempT = loop+1;
TemppH = loop+1;
StackHnd (&TemppH, &TempT, Push);
int StackHnd (float32* pH, float32* T, int Cmd) {
static int StackPntr = 0;
float32 phStack [Stacksize];
float32 TStack [Stacksize];
switch (Cmd) {
case Clear:
for (StackPntr = 0; StackPntr < Stacksize; StackPntr++) {
pHStack [StackPntr] = 0.0;
TStack [StackPntr] = 0.0;
case Push:
for (StackPntr = 1; StackPntr < Stacksize; StackPntr++) { // Top of stack is "StackSize", bottom is 0
phStack [StackPntr -1] = phStack [StackPntr]; // Push all pH values down
TStack [StackPntr -1] = TStack [StackPntr]; // Push all temp values down
pHStack [StackSize-1] = *pH; // Put actual value on top
TStack [StackSize-1] = *T; // Put actual value on top
case Calc:
default:
return 0;
This piece does not seem to difficult to me but checking the stack I do see:
| Quote: |
pHStack: (2.172,3.000,4.000,5.000,6.000,7.000,8.000,9.000,10.000,11.000)
TStack: (2.000,3.000,4.000,5.000,6.000,7.000,8.000,9.000,10.000,11.000)
Any ideas for pHStack [0]
Thanks in advance! _________________ Never check your brain at the door!
Posted: Wed Apr 22, 2009 11:30 pm |
The problem could be traced, if you had provided complete code, but you preferred not to do.
I guess, that phStack is overwritten, cause it's not declared static. Can be easily checked in the projects *.sym file. Generally, the compiler can be expected (respectively is required) to overlay phStack with other variables outside the function, to save RAM space. |
/dev/human
Posted: Thu Apr 23, 2009 10:51 pm |
Thanks, stupidly blind. The ram space was actually used by another var.
... and yeah, I actually preferred not to send the remaining about 564 lines of code.  _________________ Never check your brain at the door! |
