asmboy
| the pseudo opcode CLRF |
Posted: Wed Apr 22, 2009 4:52 pm |
I notice that when I initialize
| Code: | | unsigned int16 adccon[4]={0,0,0,0}; |
that it generates very efficient code with
with a string of
| Code: | CLRF 3F pseudo op instrux
CLRF 40
CLRF 41
CLRF 42
etc etc |
however RE initing the array with a loop or whatever is very awkward
and code hoggy
since the 4.08x compiler (#ASM directive)
wont accept the pseudo op CLRF
I've been re initializing with code like this
#ASM
movlw 0
movwf 0x3F
etc and so on - matching the original static zeroing out code
#ENDASM
I know what i have to track and be careful of - in regard not getting compiler stung ( i think )
BUT is there better way to let the compiler do the reinit
like it did when i declared the vars ?
I have a number of small arrays, of different sizes - that i want to reinit together and i find that looping to do it,
sucks code space horribly- and the above ASM hack appears to do it with minimum clocks
I'd be grateful if there is a better way to let the compiler do it - but still achieve decent efficiency. |
Posted: Wed Apr 22, 2009 5:25 pm |
Both the methods shown below generate CLRF statements in the .LST file.
The first one is better since it's in C.
| Code: | #include <16F877.H>
int8 array[5];
array[0] = 0;
array[1] = 0;
array[2] = 0;
array[3] = 0;
array[4] = 0;
#asm
CLRF array[0]
CLRF array[1]
CLRF array[2]
CLRF array[3]
CLRF array[4]
#endasm
