Handy Firmware Revision trick
john Goss
PostPosted: Sun Jan 26, 2003 7:20 pm     Reply with quote
In my code, I store a constant set of charactors near the very end of ROM memory that contains the current rev of code I am working on. When the program resets or turns on, it prints out my current firmware revision on the RS232 port.
I keep this at the top of main() so when I make a change to the code, I quickly update the rev. number too.
// Include header files for functions
#include <16f872.h>       // Register definitions for PIC16F872 microcontroller
#include <stdio.h>      // Standard I/O - provided by CCS
#include <stdlib.h>      // Standard library functions - provided by CCS
#include <string.h>      // String Functions - provided by CCS
#include <mod.h>      // Port Pin Declarations, Function Prototypes, global variables for this program
// Do CCS C-Compiler directives
#use delay(clock=3686400)
#fuses XT,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT, NOLVP
// !! UPDATE FIRMWARE REVISION HERE !!
#org 0x07F0, 0x07FF
const char Revision[] = {"Rev 0.04"};
//*   M   M   AAA   IIIII  N   N                                            *
//*   MM MM  A   A    I    NN  N                                            *
//*   M M M  AAAAA    I    N N N                                            *
//*   M   M  A   A    I    N  NN                                            *
//*   M   M  A   A  IIIII  N   N                                            *
   void
main(void)
//---------- Occurs once on Reset or Power up ---------------------------------
   printf("Reset\n\r");
   printf("Rev: \%S\n\r",Revision);
___________________________
Original Post ID: 11018
Re: Handy Firmware Revision trick
PostPosted: Mon Jan 27, 2003 1:49 pm     Reply with quote
That's a good idea. I came up with a variation that
would make it be more automatic. The code displays
the following text in the terminal window:
Build: 27-Jan-03 11:44:17
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
// I have the position backed off by 256 bytes from
// the end of ROM, because I'm using a bootloader there.
#org 0x1EE0, 0x1EEF
const char Build_Date[] = __DATE__;
#org 0x1EF0, 0x1EFF
const char Build_Time[] = __TIME__;
main()
printf("Build: \%s  \%s\n\r", Build_Date, Build_Time);
Original Post ID: 11046
Last edited by PCM programmer on Mon Sep 14, 2009 12:09 pm; edited 1 time in total
Neutone
PostPosted: Mon Jan 27, 2003 4:50 pm     Reply with quote
Does this statement substitute the actual date of compile or do you have to enter it with each compile?
#org 0x1EE0, 0x1EEF const char Build_Date[] = __DATE__;
Original Post ID: 11055
PostPosted: Mon Jan 27, 2003 4:57 pm     Reply with quote
The compiler gets the date from the operating system
(Win98, etc.) and inserts it as a string, in place of __DATE__.
Original Post ID: 11056
Last edited by PCM programmer on Mon Sep 14, 2009 12:10 pm; edited 1 time in total
Sergio
PostPosted: Mon Jan 27, 2003 10:10 pm     Reply with quote
Clever.
Thanks.
:=That's a good idea. I came up with a variation that
:=would make it be more automatic. The code displays
:=the following text in the terminal window:
:=Build: 27-Jan-03 11:44:17
:=#include "c:\program files\picc\devices\16F877.h"
:=#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
:=#use Delay(clock=8000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
:=// I have the position backed off by 256 bytes from
:=// the end of ROM, because I'm using a bootloader there.
:=#org 0x1EE0, 0x1EEF
:=const char Build_Date[] = __DATE__;
:=#org 0x1EF0, 0x1EFF
:=const char Build_Time[] = __TIME__;
:=main()
:=printf("Build: \%s \%s\n\r", Build_Date, Build_Time);
:=while(1);
:=--</font>
Original Post ID: 11063
adrian
PostPosted: Wed Jan 29, 2003 2:21 am     Reply with quote
:=:=Does this statement substitute the actual date of compile or do you have to enter it with each compile?
:=:=#org 0x1EE0, 0x1EEF const char Build_Date[] = __DATE__;
:=The compiler gets the date from the operating system
:=(Win98, etc.) and inserts it as a string, in place of __DATE__.
Which version of the compiler did __TIME__ get included? My lowly v3.061 will do __DATE__ but not __TIME__.
Also what should __DEVICE__ return? I get Error[27] Expression must evaluate to a constant.
Original Post ID: 11088
